[postgis-tickets] [SCM] PostGIS branch master updated. 3.3.0beta2-29-g523502dc1
Mon Aug 1 15:45:04 PDT 2022
the project "PostGIS".
       via  523502dc1f07203b75a5cfeddccdfb3856e78e53 (commit)
       via  7e529fb3aec485c2cd2ed1fdacdb9a3d09a8bb6f (commit)
      from  ca37a62b4759ed1c7d35bcb43c62c0e9f835771e (commit)
revisions in full, below.
commit 523502dc1f07203b75a5cfeddccdfb3856e78e53
Author: Regina Obe <lr at pcorp.us>
Date:   Mon Aug 1 18:43:08 2022 -0400
    Change address_standardizer and postgis_tiger_geocoder
    CREATE EXTENSION to use CREATE  instead of CREATE OR REPLACE.
    References #5195 and #5196 for PostGIS 3.3.0
diff --git a/NEWS b/NEWS
index 0c1fbf4c3..80deb6cca 100644
--- a/NEWS
+++ b/NEWS
@@ -18,6 +18,9 @@ Changes since PostGIS 3.3.0beta2:
   - #5025, Ensure that additional operators are not appended
            when the function and opfamily disagree
            about dimensionality (Paul Ramsey)
+  - #5195, #5196  Change address_standardizer
+           and postgis_tiger_geocoder CREATE EXTENSION to use CREATE
+           instead of CREATE OR REPLACE. (Regina Obe)
diff --git a/extensions/address_standardizer/Makefile.in b/extensions/address_standardizer/Makefile.in
index 6c9a90270..0fa8f7d13 100644
--- a/extensions/address_standardizer/Makefile.in
+++ b/extensions/address_standardizer/Makefile.in
@@ -38,13 +38,16 @@ MODULE_big = address_standardizer- at POSTGIS_MAJOR_VERSION@. at POSTGIS_MINOR_VERSION
 MODULEPATH    = $$libdir/address_standardizer- at POSTGIS_MAJOR_VERSION@. at POSTGIS_MINOR_VERSION@
 endif
 EXTENSION = address_standardizer
+EXTENSION_SCRIPTS = \
+ 		sql/address_standardizer_types.sql \
+    sql/address_standardizer_functions.sql
 DATA_built = \
 	$(EXTENSION).control \
 	$(EXTENSION)_data_us.control \
 	$(NULL)
-all:  sql/address_standardizer.sql sql/address_standardizer--1.0--$(EXTVERSION).sql sql/$(EXTENSION)--$(EXTVERSION).sql sql/$(EXTENSION)--ANY--$(EXTVERSION).sql \
+all:  sql/address_standardizer_pre.sql sql/address_standardizer.sql sql/address_standardizer--1.0--$(EXTVERSION).sql sql/$(EXTENSION)--$(EXTVERSION).sql sql/$(EXTENSION)--ANY--$(EXTVERSION).sql \
  sql/$(EXTENSION)_data_us.sql sql/address_standardizer-- at POSTGIS_LIB_VERSION@.sql sql/$(EXTENSION)_data_us-- at POSTGIS_LIB_VERSION@.sql  sql/$(EXTENSION)_data_us--$(EXTVERSION)--$(EXTVERSION)next.sql \
 sql/$(EXTENSION)_data_us--$(EXTVERSION)next--$(EXTVERSION).sql sql/$(EXTENSION)_data_us--ANY--$(EXTVERSION).sql \
 sql/test-init-extensions.sql sql/test-parseaddress.sql sql/test-standardize_address_1.sql sql/test-standardize_address_2.sql
@@ -69,23 +72,29 @@ sql/%.sql: %.sql.in
 		| $(PERL) -lpe "s'@EXTVERSION@'$(EXTVERSION)'g" \
-sql/address_standardizer-- at POSTGIS_LIB_VERSION@_raw.sql: sql/address_standardizer_types.sql \
-    sql/address_standardizer_functions.sql
+sql/address_standardizer_pre.sql: $(EXTENSION_SCRIPTS)
 	mkdir -p sql
 	cat $^ > $@
-sql/address_standardizer.sql: sql/address_standardizer_types.sql \
+sql/address_standardizer--$(EXTVERSION).sql: sql/address_standardizer_pre.sql ../../utils/create_or_replace_to_create.pl
 	mkdir -p sql
-	cat $^ > $@
+	cat $< \
+		| $(PERL) ../../utils/create_or_replace_to_create.pl sql/address_standardizer_pre.sql \
-sql/address_standardizer--1.0--$(EXTVERSION).sql:  sql/address_standardizer_functions.sql
+sql/address_standardizer.sql: sql/address_standardizer_pre.sql ../../utils/create_or_replace_to_create.pl
 	mkdir -p sql
-	cat $^ > $@
+	cat $< \
 EXTENSION_UPGRADE_SCRIPTS = sql/address_standardizer_functions.sql
 # upgrade logic for us data extension (to go to original round-robin yoyo cludge for dev upgrading)
+sql/$(EXTENSION)--1.0--$(EXTVERSION).sql: sql/address_standardizer_functions.sql
+	mkdir -p sql
+	cat $^ > $@
 sql/$(EXTENSION)--$(EXTVERSION)next--$(EXTVERSION).sql: sql/address_standardizer_functions.sql
 	mkdir -p sql
 	cat $^ > $@
diff --git a/extensions/postgis_tiger_geocoder/Makefile.in b/extensions/postgis_tiger_geocoder/Makefile.in
index 8df3730e4..49cfd80a1 100644
--- a/extensions/postgis_tiger_geocoder/Makefile.in
+++ b/extensions/postgis_tiger_geocoder/Makefile.in
@@ -40,7 +40,7 @@ ifeq (@ADDRESS_STANDARDIZER@,address_standardizer)
 	REGRESS_OPTS += --load-extension=address_standardizer
 endif
-all: sql/$(EXTENSION)--$(EXTVERSION).sql sql/$(EXTENSION)--unpackaged--$(EXTVERSION).sql sql/$(EXTENSION)--ANY--$(EXTVERSION).sql sql/test-normalize_address.sql sql/test-pagc_normalize_address.sql expected/test-normalize_address.out expected/test-pagc_normalize_address.out sql/test-upgrade.sql expected/test-upgrade.out
+all: sql/$(EXTENSION)_pre.sql sql/$(EXTENSION)--$(EXTVERSION).sql sql/$(EXTENSION)--unpackaged--$(EXTVERSION).sql sql/$(EXTENSION)--ANY--$(EXTVERSION).sql sql/test-normalize_address.sql sql/test-pagc_normalize_address.sql expected/test-normalize_address.out expected/test-pagc_normalize_address.out sql/test-upgrade.sql expected/test-upgrade.out
 expected:
@@ -67,7 +67,7 @@ sql/test-upgrade.sql: | sql
 %.control: %.control.in Makefile
 	cat $< \
-		| sed -e 's|@EXTVERSION@|$(EXTVERSION)|g' \
+		| $(PERL) -lpe "s'@EXTVERSION@'$(EXTVERSION)'g" \
 expected/test-upgrade.out: sql/test-upgrade.sql | expected
@@ -76,9 +76,14 @@ expected/test-upgrade.out: sql/test-upgrade.sql | expected
 sql/test-pagc_normalize_address.sql: sql_bits/test_tuples_only_unaligned.sql.in ../../extras/tiger_geocoder/regress/pagc_normalize_address_regress.sql | sql
 	cat $^ > $@
-sql/$(EXTENSION).sql: sql/tiger_geocoder.sql  sql_bits/mark_editable_objects.sql.in sql_bits/tiger_geocoder_comments.sql | sql
+sql/$(EXTENSION)_pre.sql: sql/tiger_geocoder.sql  sql_bits/mark_editable_objects.sql.in sql_bits/tiger_geocoder_comments.sql | sql
 	cat $^ > $@
+sql/$(EXTENSION).sql: sql/$(EXTENSION)_pre.sql ../../utils/create_or_replace_to_create.pl
+	cat $< \
+		| $(PERL) ../../utils/create_or_replace_to_create.pl sql/$(EXTENSION)_pre.sql \
 sql/$(EXTENSION)--ANY--$(EXTVERSION).sql: ../postgis_extension_helper.sql sql_bits/remove_from_extension.sql.in sql/tiger_geocoder_upgrade_minor.sql sql_bits/mark_editable_objects.sql.in sql_bits/tiger_geocoder_comments.sql | sql
 	cat $^ > $@
 	echo "SELECT postgis_extension_drop_if_exists('${EXTENSION}', 'DROP SCHEMA tiger_data');" >> $@
diff --git a/utils/create_or_replace_to_create.pl b/utils/create_or_replace_to_create.pl
new file mode 100644
index 000000000..6b43953f8
--- /dev/null
+++ b/utils/create_or_replace_to_create.pl
@@ -0,0 +1,169 @@
+#!/usr/bin/env perl
+# PostGIS - Spatial Types for PostgreSQL
+# http://postgis.net
+# Copyright (C) 2022 Regina Obe <lr at pcorp.us>
+# This is free software; you can redistribute and/or modify it under
+# the terms of the GNU General Public Licence. See the COPYING file.
+# This script produces an .sql file containing
+# CREATE OR REPLACE calls for each function
+# in postgis.sql
+# In addition, the transaction contains
+# a check for Major postgis_lib_version()
+# to match the one contained in lwpostgis.sql
+# This never happens by just running make install
+# as MODULE_FILENAME contains SO_MAJOR under
+# all architectures.
+eval "exec perl -w $0 $@"
+  if (0);
+use strict;
+use warnings;
+# Conditionally upgraded types and operators based
+# on their last updated version and the version of
+# the target database
+sub parse_last_updated
+    my $comment = shift;
+    if ( $comment =~ m/.*(?:Availability|Changed|Updated):\s([^\.])\.([^.]*)/s )
+        return $1*100 + $2;
+    return 0;
+sub parse_replaces
+    my @replaces = ();
+    my ($name, $args, $ver);
+    foreach my $line ( split /\n/, $comment )
+        if ( $line =~ m/.*Replaces\s\s*([^\(]*)\(([^\)]*)\)\s\s*deprecated in\s\s*([^\.]*)\.([^.]*)/ )
+            $name = $1;
+            $args = $2;
+            $ver = $3*100 + $4;
+            my @r = ($name, $args, $ver);
+            push @replaces, \@r;
+    return @replaces;
+sub parse_missing
+    my @missing = ();
+    if ( $comment =~ m/.*(?:Missing in):\s([^\.])\.([^.]*)/s )
+        push(@missing, $1*100 + $2);
+    return join(',', at missing);
+# Commandline argument handling
+($#ARGV == 0)
+  ||die
+"Usage: perl create_upgrade.pl <create_script.sql> [<schema>]\nCreates a new SQL script that has all CREATE OR REPLACE converted to CREATE so it is suitable for CREATE EXTENSION only.\n"
+  if ( @ARGV < 1 || @ARGV > 3 );
+my $sql_file = $ARGV[0];
+die "Unable to open input SQL file $sql_file\n"
+  if ( !-f $sql_file );
+# Go through the SQL file and strip out objects that cannot be
+# applied to an existing, loaded database: types and operators
+# and operator classes that have already been defined.
+my $comment = '';
+open( INPUT, $sql_file ) || die "Couldn't open file: $sql_file\n";
+while(<INPUT>)
+    if (/^create or replace function/i)
+        my $def .= $_;
+        my $endfunc = 0;
+		$def =~ s/CREATE OR REPLACE/CREATE/;
+		#print "-- entering create or replace loop\n";
+        while(<INPUT>)
+            $def .= $_;
+            $endfunc = 1 if /^\s*(\$\$\s*)?LANGUAGE /i;
+            last if ( $endfunc && /\;/ );
+        print $def;
+		#print "-- exiting create or replace loop\n";
+	elsif (/^do *language .*\$\$/i)
+        print;
+        while(<INPUT>)
+            print;
+            last if /\$\$/;
+    # Always output create ore replace view (see ticket #1097)
+    elsif (/^create or replace view\s+(\S+)\s*/i)
+		my $def = $_;
+        $def = $_;
+        while(<INPUT>)
+            $def .= $_;
+            last if /\;\s*$/;
+		print $def;
+    # Always output create ore replace rule
+    elsif (/^create or replace rule\s+(\S+)\s*/i)
+		my $def = $_;
+		$def = $_;
+        while(<INPUT>)
+            $def .= $_;
+            last if /\;\s*$/;
+		print $def;
+	else {
+		print;
+close(INPUT);
+#print "COMMIT;\n";
+1;
+__END__
commit 7e529fb3aec485c2cd2ed1fdacdb9a3d09a8bb6f
Date:   Mon Aug 1 12:12:11 2022 -0400
    Change to use perl regex instead of sed for control file
index ed18cbce0..6c9a90270 100644
@@ -66,10 +66,10 @@ sql/%.sql: %.sql.in
 	cat $< \
-sql/address_standardizer-- at POSTGIS_LIB_VERSION@.sql: sql/address_standardizer_types.sql \
+sql/address_standardizer-- at POSTGIS_LIB_VERSION@_raw.sql: sql/address_standardizer_types.sql \
 	mkdir -p sql
 	cat $^ > $@
Summary of changes:
 NEWS                                          |   3 +
 extensions/address_standardizer/Makefile.in   |  27 ++--
 extensions/postgis_tiger_geocoder/Makefile.in |  11 +-
 utils/create_or_replace_to_create.pl          | 169 ++++++++++++++++++++++++++
 4 files changed, 198 insertions(+), 12 deletions(-)
 create mode 100644 utils/create_or_replace_to_create.pl
hooks/post-receive
