[postgis-tickets] [PostGIS] #5197: out-of-tree build not working under mingw
PostGIS trac at osgeo.org
Mon Aug 1 16:44:29 PDT 2022
 Reporter:  robe                   |      Owner:  strk
     Type:  defect                 |     Status:  new
 Priority:  medium                 |  Milestone:  PostGIS 3.3.0
Component:  build/upgrade/install  |    Version:  master
 Keywords:                         |
 Not sure if it's just my setup or all mingw64, but I was trying to build
 with out-of-tree, to debug the issue I caused with out-of-tree on my
 commit for #5195.
 However my build always fails before it gets to that point:
 with:
 /mingw64/bin/cpp -traditional-cpp -w -P -I./../../postgis
 /projects/postgis/postgis-
 git/extensions/postgis/../../postgis/postgis.sql.in | grep -v '^#' | \
 /usr/bin/perl -lpe \
         "s'MODULE_PATHNAME'\$libdir/postgis-3.3'g" \
         | /usr/bin/perl -pe 's/BEGIN\;//g ; s/COMMIT\;//g' >
 sql/postgis_for_extension.sql
 /bin/sh: line 4: sql/postgis_for_extension.sql: No such file or directory
 <built-in>: fatal error: when writing output to : Invalid argument
 compilation terminated.
 make[2]: *** [Makefile:138: sql/postgis_for_extension.sql] Error 1
 make[2]: Leaving directory '/projects/postgis/tmp/postgis-
 build/3.3/extensions/postgis'
 make[1]: *** [Makefile:29: all] Error 1
 make[1]: Leaving directory '/projects/postgis/tmp/postgis-
 build/3.3/extensions'
 make: *** [GNUmakefile:24: all] Error 1
Ticket URL: <https://trac.osgeo.org/postgis/ticket/5197>
