[postgis-tickets] [PostGIS] #5197: out-of-tree build not working under mingw
PostGIS trac at osgeo.org
Tue Aug 2 09:13:46 PDT 2022
  Reporter:  robe                   |      Owner:  strk
      Type:  defect                 |     Status:  closed
  Priority:  medium                 |  Milestone:  PostGIS 3.3.0
 Component:  build/upgrade/install  |    Version:  master
Resolution:  fixed                  |   Keywords:
Changes (by robe):
 * status:  new => closed
 * resolution:   => fixed
Comment:
 strk noted my sql folders (the ones in extensions\postgis\sql  and also
 all extension subfolder might be present in my repo folder.
 After deleting all of those it seems to work.
 So closing this out and will reopen if I still have issues
Ticket URL: <https://trac.osgeo.org/postgis/ticket/5197#comment:1>
