[postgis-tickets] [SCM] PostGIS branch master updated. 3.3.0beta2-38-g497e79349
Fri Aug 5 22:06:56 PDT 2022
the project "PostGIS".
       via  497e793493ccf96492665cbeab7482484e3f2a36 (commit)
      from  2f08c4f1e916a0ff6412d4ee0980377e74e61d01 (commit)
revisions in full, below.
commit 497e793493ccf96492665cbeab7482484e3f2a36
Author: Sandro Santilli <strk at kbt.io>
Date:   Sat Aug 6 07:06:02 2022 +0200
    Guard against downgrades
    References #5202 in master branch (3.3.0dev)
diff --git a/utils/create_upgrade.pl b/utils/create_upgrade.pl
index dfa429dd2..2bd235f45 100755
--- a/utils/create_upgrade.pl
+++ b/utils/create_upgrade.pl
@@ -769,6 +769,24 @@ BEGIN
         SELECT into old_scripts MODULE_scripts_installed();
     END;
     SELECT into new_scripts 'NEWVERSION';
+    -- Guard against downgrade
+    IF
+       pg_catalog.string_to_array(
+            pg_catalog.regexp_replace(new_scripts, '(dev|alpha|beta)[0-9]*', ''),
+        )::int[]
+            pg_catalog.regexp_replace(old_scripts, '(dev|alpha|beta)[0-9]*', ''),
+        )::int[]
+    THEN
+        RAISE EXCEPTION 'Downgrade of MODULE from version % to version % is forbidden', old_scripts, new_scripts;
+    END IF;
+    -- Check for hard-upgrade being required
     SELECT into old_maj pg_catalog.substring(old_scripts, 1, 1);
     SELECT into new_maj pg_catalog.substring(new_scripts, 1, 1);
Summary of changes:
 utils/create_upgrade.pl | 18 ++++++++++++++++++
 1 file changed, 18 insertions(+)
hooks/post-receive
