[postgis-tickets] [SCM] PostGIS branch stable-3.2 updated. 3.2.2-7-g60244502e
Fri Aug 5 22:08:22 PDT 2022
the project "PostGIS".
The branch, stable-3.2 has been updated
       via  60244502e3ee1cf2c56b67be334c678ab28f0b27 (commit)
      from  80ff12916c20ad5b59a7151f803a867c4f876395 (commit)
revisions in full, below.
commit 60244502e3ee1cf2c56b67be334c678ab28f0b27
Author: Sandro Santilli <strk at kbt.io>
Date:   Sat Aug 6 07:07:48 2022 +0200
    Guard against downgrades
    References #5202 in 3.2 branch (3.2.3dev)
diff --git a/utils/postgis_proc_upgrade.pl b/utils/postgis_proc_upgrade.pl
index 6173af8e2..cbaf06e36 100755
--- a/utils/postgis_proc_upgrade.pl
+++ b/utils/postgis_proc_upgrade.pl
@@ -719,6 +719,24 @@ BEGIN
         SELECT into old_scripts MODULE_scripts_installed();
     END;
     SELECT into new_scripts 'NEWVERSION';
+    -- Guard against downgrade
+    IF
+       pg_catalog.string_to_array(
+            pg_catalog.regexp_replace(new_scripts, '(dev|alpha|beta)[0-9]*', ''),
+        )::int[]
+            pg_catalog.regexp_replace(old_scripts, '(dev|alpha|beta)[0-9]*', ''),
+        )::int[]
+    THEN
+        RAISE EXCEPTION 'Downgrade of MODULE from version % to version % is forbidden', old_scripts, new_scripts;
+    END IF;
+    -- Check for hard-upgrade being required
     SELECT into old_maj pg_catalog.substring(old_scripts,1, 1);
     SELECT into new_maj pg_catalog.substring(new_scripts,1, 1);
Summary of changes:
 utils/postgis_proc_upgrade.pl | 18 ++++++++++++++++++
 1 file changed, 18 insertions(+)
hooks/post-receive
