[postgis-tickets] [SCM] PostGIS branch master updated. 3.3.0beta2-40-g7d50d1b3c
    git at osgeo.org
    git at osgeo.org
    Fri Aug  5 23:07:14 PDT 2022
the project "PostGIS".
       via  7d50d1b3c7e3e41b6b3a066f51270e29d35de1e7 (commit)
      from  c885bc7b97a33a6888fb0777a6fac64aa993e7f2 (commit)
revisions in full, below.
commit 7d50d1b3c7e3e41b6b3a066f51270e29d35de1e7
Author: Sandro Santilli <strk at kbt.io>
Date:   Sat Aug 6 07:52:48 2022 +0200
    Fix extraction of integer array version on upgrade
    References #5202 in master branch (3.3.0dev)
diff --git a/utils/create_upgrade.pl b/utils/create_upgrade.pl
index 2fb2e4705..25635aa02 100755
--- a/utils/create_upgrade.pl
+++ b/utils/create_upgrade.pl
@@ -747,6 +747,8 @@ DO $$
 DECLARE
     old_scripts text;
     new_scripts text;
+    old_ver_int int[];
+    new_ver_int int[];
     old_maj text;
     new_maj text;
     postgis_upgrade_info RECORD;
@@ -772,17 +774,34 @@ BEGIN
     END;
     SELECT into new_scripts 'NEWVERSION';
-    -- Guard against downgrade
-    IF
-       pg_catalog.string_to_array(
-            pg_catalog.regexp_replace(new_scripts, '(dev|alpha|beta)[0-9]*', ''),
+    BEGIN
+        new_ver_int := pg_catalog.string_to_array(
+            pg_catalog.regexp_replace(
+                new_scripts,
+                '[^\d.].*',
-        )::int[]
-            pg_catalog.regexp_replace(old_scripts, '(dev|alpha|beta)[0-9]*', ''),
+        )::int[];
+    EXCEPTION WHEN OTHERS THEN
+        RAISE EXCEPTION 'Cannot parse new version % into integers', new_scripts;
+    END;
+    BEGIN
+        old_ver_int := pg_catalog.string_to_array(
+                old_scripts,
+                '[^\d.].*',
-        )::int[]
+        )::int[];
+        RAISE EXCEPTION 'Cannot parse old version % into integers', old_scripts;
+    END;
+    -- Guard against downgrade
+    IF new_ver_int < old_ver_int
     THEN
         RAISE EXCEPTION 'Downgrade of MODULE from version % to version % is forbidden', old_scripts, new_scripts;
     END IF;
Summary of changes:
 utils/create_upgrade.pl | 37 ++++++++++++++++++++++++++++---------
 1 file changed, 28 insertions(+), 9 deletions(-)
hooks/post-receive
