[postgis-tickets] [SCM] PostGIS branch stable-3.2 updated. 3.2.2-9-ga04d348ca
Fri Aug 5 23:25:35 PDT 2022
the project "PostGIS".
The branch, stable-3.2 has been updated
       via  a04d348ca58be6f161206ad38f432b8462275817 (commit)
      from  1f3c83b49f36cb882f3712ca5cb836e098016653 (commit)
revisions in full, below.
commit a04d348ca58be6f161206ad38f432b8462275817
Author: Sandro Santilli <strk at kbt.io>
Date:   Sat Aug 6 07:52:48 2022 +0200
    Fix extraction of integer array version on upgrade
    References #5202 in 3.2 branch (3.2.3dev)
diff --git a/utils/postgis_proc_upgrade.pl b/utils/postgis_proc_upgrade.pl
index 028535a05..f58d9aa34 100755
--- a/utils/postgis_proc_upgrade.pl
+++ b/utils/postgis_proc_upgrade.pl
@@ -697,6 +697,8 @@ DO $$
 DECLARE
     old_scripts text;
     new_scripts text;
+    old_ver_int int[];
+    new_ver_int int[];
     old_maj text;
     new_maj text;
     postgis_upgrade_info RECORD;
@@ -722,17 +724,34 @@ BEGIN
     END;
     SELECT into new_scripts 'NEWVERSION';
-    -- Guard against downgrade
-    IF
-       pg_catalog.string_to_array(
-            pg_catalog.regexp_replace(new_scripts, '(dev|alpha|beta)[0-9]*', ''),
+    BEGIN
+        new_ver_int := pg_catalog.string_to_array(
+            pg_catalog.regexp_replace(
+                new_scripts,
+                '[^\d.].*',
-        )::int[]
-            pg_catalog.regexp_replace(old_scripts, '(dev|alpha|beta)[0-9]*', ''),
+        )::int[];
+    EXCEPTION WHEN OTHERS THEN
+        RAISE EXCEPTION 'Cannot parse new version % into integers', new_scripts;
+    END;
+    BEGIN
+        old_ver_int := pg_catalog.string_to_array(
+                old_scripts,
+                '[^\d.].*',
-        )::int[]
+        )::int[];
+        RAISE EXCEPTION 'Cannot parse old version % into integers', old_scripts;
+    END;
+    -- Guard against downgrade
+    IF new_ver_int < old_ver_int
     THEN
         RAISE EXCEPTION 'Downgrade of MODULE from version % to version % is forbidden', old_scripts, new_scripts;
     END IF;
Summary of changes:
 utils/postgis_proc_upgrade.pl | 37 ++++++++++++++++++++++++++++---------
 1 file changed, 28 insertions(+), 9 deletions(-)
hooks/post-receive
