[postgis-tickets] [PostGIS] #5202: It seems I can downgrade with ANY
PostGIS trac at osgeo.org
Fri Aug 5 23:07:29 PDT 2022
  Reporter:  robe                   |      Owner:  robe
      Type:  defect                 |     Status:  reopened
  Priority:  blocker                |  Milestone:  PostGIS 3.2.3
 Component:  build/upgrade/install  |    Version:  3.2.x
Resolution:                         |   Keywords:
Comment (by Sandro Santilli <strk@…>):
 In [changeset:"7d50d1b3c7e3e41b6b3a066f51270e29d35de1e7/git" 7d50d1b/git]:
 {{{#!CommitTicketReference repository="git"
 revision="7d50d1b3c7e3e41b6b3a066f51270e29d35de1e7"
 Fix extraction of integer array version on upgrade
 References #5202 in master branch (3.3.0dev)
Ticket URL: <https://trac.osgeo.org/postgis/ticket/5202#comment:9>
