[postgis-tickets] [PostGIS] #5202: It seems I can downgrade with ANY
PostGIS trac at osgeo.org
Fri Aug 5 23:25:47 PDT 2022
  Reporter:  robe                   |      Owner:  robe
      Type:  defect                 |     Status:  reopened
  Priority:  blocker                |  Milestone:  PostGIS 3.2.3
 Component:  build/upgrade/install  |    Version:  3.2.x
Resolution:                         |   Keywords:
Comment (by Sandro Santilli <strk@…>):
 In [changeset:"a04d348ca58be6f161206ad38f432b8462275817/git"
 a04d348c/git]:
 {{{#!CommitTicketReference repository="git"
 revision="a04d348ca58be6f161206ad38f432b8462275817"
 Fix extraction of integer array version on upgrade
 References #5202 in 3.2 branch (3.2.3dev)
Ticket URL: <https://trac.osgeo.org/postgis/ticket/5202#comment:10>
