[postgis-tickets] [PostGIS] #5165: CREATE EXTENSION scripts should use CREATE instead of CREATE OR REPLACE
PostGIS trac at osgeo.org
Tue Aug 9 07:10:09 PDT 2022
  Reporter:  robe                   |      Owner:  strk
      Type:  defect                 |     Status:  new
  Priority:  medium                 |  Milestone:  PostGIS Fund Me
 Component:  build/upgrade/install  |    Version:  master
Resolution:                         |   Keywords:
Comment (by tbussmann):
 > The danger for ALTER EXTENSION here is if a regular untrusted user knows
 a function exists in postgis in a newer version not yet installed. They go
 create a function with that signature with the future expectation that
 postgis will be upgraded. Then when ALTER EXTENSION UPDATE is done, our
 function would now make a function they own be part of postgis, and they
 could then change that function putting malicious things in there. If a
 super user then runs this coopted function, they could accidentally
 elevate the privileges of said user (cause it would be running under super
 user rights).
 That describes what is my understanding of CVE-2022-2625. The upcoming
 PostgreSQL releases of this week 10.22, 11.17, 12.12, 13.8, 14.5 will
 therefore forbid to use `CREATE OR REPLACE` on a function that is not
 owned by the extension (see postgresql commit
 b9b21acc766db54d8c337d508d0fe2f5bf2daab0). This breaks the PostGIS
 regression tests and likely the possibility to upgrade from unpackaged to
 extension and thus the 2.x -> 3.x upgrades where `postgis_raster` was
 repackaged. But these deserve their own tickets after being confirmed.
Ticket URL: <https://trac.osgeo.org/postgis/ticket/5165#comment:9>
