[postgis-tickets] [PostGIS] #5165: CREATE EXTENSION scripts should use CREATE instead of CREATE OR REPLACE
PostGIS trac at osgeo.org
Tue Aug 9 14:39:21 PDT 2022
  Reporter:  robe                   |      Owner:  strk
      Type:  defect                 |     Status:  closed
  Priority:  medium                 |  Milestone:  PostGIS PostgreSQL
 Component:  build/upgrade/install  |    Version:  master
Resolution:  wontfix                |   Keywords:
Changes (by robe):
 * status:  new => closed
 * resolution:   => wontfix
 * milestone:  PostGIS Fund Me => PostGIS PostgreSQL
Comment:
 So I suppose we can close this ticket out since it's been taken care of
 upstream.
 As far as the breaking unraveling raster from postgis (upgrading from 2.5
 to 3+), strk I recall you were working to make sure that we were covered
 by the above PostgreSQL commit change and your recent changes worked
 around that. But we might need to backport.  I'll test and confirm.
Ticket URL: <https://trac.osgeo.org/postgis/ticket/5165#comment:10>
