[postgis-tickets] [PostGIS] #5165: CREATE EXTENSION scripts should use CREATE instead of CREATE OR REPLACE
PostGIS trac at osgeo.org
Sun Aug 14 08:26:18 PDT 2022
  Reporter:  robe                   |      Owner:  strk
      Type:  defect                 |     Status:  closed
  Priority:  medium                 |  Milestone:  PostGIS PostgreSQL
 Component:  build/upgrade/install  |    Version:  master
Resolution:  wontfix                |   Keywords:
Comment (by strk):
 The workaround changes are now in all supported branches.
 The 2-years old #4648 is still needed or can we close that one too ?
Ticket URL: <https://trac.osgeo.org/postgis/ticket/5165#comment:11>
