[postgis-tickets] [PostGIS] #5209: Upgrade issue with topology
PostGIS trac at osgeo.org
Thu Aug 11 23:46:01 PDT 2022
  Reporter:  robe      |      Owner:  strk
      Type:  defect    |     Status:  new
  Priority:  blocker   |  Milestone:  PostGIS 3.2.3
 Component:  topology  |    Version:  3.2.x
Resolution:            |   Keywords:
Comment (by strk):
 To correct what's written in comment:1 the reported problem happens when
 upgrading from _unpackaged_ postgis. It's reported to happen in versions
 2.5.5 and 3.2.1 but I know it will also happen in versions 3.0.6 and
 3.1.6.
 It was reported that with 3.2.2 the problem can be reproduced running:
 `make installcheck-upgrade` from the build dir.
Ticket URL: <https://trac.osgeo.org/postgis/ticket/5209#comment:4>
