[postgis-tickets] [PostGIS] #5209: Upgrade issue with topology
PostGIS trac at osgeo.org
Thu Aug 11 23:50:09 PDT 2022
  Reporter:  robe      |      Owner:  strk
      Type:  defect    |     Status:  new
  Priority:  blocker   |  Milestone:  PostGIS 3.2.3
 Component:  topology  |    Version:  3.2.x
Resolution:            |   Keywords:
Comment (by strk):
 The problem can be reproduced in all stable branches with:
 > regress/run_test.pl -v --extension --upgrade --upgrade-path unpackaged--
 2.5.8dev regress/regress
 The target version has to be replaced with the currently-built and
 installed postgis version
Ticket URL: <https://trac.osgeo.org/postgis/ticket/5209#comment:5>
