[postgis-tickets] [SCM] PostGIS branch stable-2.5 updated. 2.5.7-6-g35b17931f
Thu Aug 11 23:51:09 PDT 2022
the project "PostGIS".
The branch, stable-2.5 has been updated
       via  35b17931fdaa743c3f4f215ae9e8fc48f777dd02 (commit)
      from  e5f7f23bf9957be5fdef5a77df84b5468d606fc2 (commit)
revisions in full, below.
commit 35b17931fdaa743c3f4f215ae9e8fc48f777dd02
Author: Sandro Santilli <strk at kbt.io>
Date:   Fri Aug 12 08:50:59 2022 +0200
    Backport run_test.pl from master branch
diff --git a/regress/run_test.pl b/regress/run_test.pl
index e95f1534c..efafb29ae 100755
--- a/regress/run_test.pl
+++ b/regress/run_test.pl
@@ -1,4 +1,4 @@
-#!/usr/bin/perl
+#!/usr/bin/env perl
 # PostGIS - Spatial Types for PostgreSQL
@@ -15,6 +15,7 @@
 #$| = 1;
 use File::Basename;
 use File::Temp 'tempdir';
+use Time::HiRes qw(time);
 #use File::Which;
 use File::Copy;
 use File::Path;
@@ -38,6 +39,9 @@ BEGIN {
 #  Run the <testname>.sql script
 #  Check output against <testname>_expected
+#  Use `-` as the testname to drop into an interactive shell
@@ -46,9 +50,10 @@ BEGIN {
 our $DB = $ENV{"POSTGIS_REGRESS_DB"} || "postgis_reg";
 our $REGDIR = abs_path(dirname($0));
-our $SHP2PGSQL = $REGDIR . "/../loader/shp2pgsql";
-our $PGSQL2SHP = $REGDIR . "/../loader/pgsql2shp";
-our $RASTER2PGSQL = $REGDIR . "/../raster/loader/raster2pgsql";
+our $TOP_BUILDDIR = $ENV{"POSTGIS_TOP_BUILD_DIR"} || ${REGDIR} . '/..';
+our $SHP2PGSQL = $TOP_BUILDDIR . "/loader/shp2pgsql";
+our $PGSQL2SHP = $TOP_BUILDDIR . "/loader/pgsql2shp";
+our $RASTER2PGSQL = $TOP_BUILDDIR . "/raster/loader/raster2pgsql";
 our $sysdiff = !system("diff --strip-trailing-cr $0 $0 2> /dev/null");
@@ -60,17 +65,22 @@ my $OPT_NODROP = 0;
 my $OPT_NOCREATE = 0;
 my $OPT_UPGRADE = 0;
 my $OPT_DUMPRESTORE = 0;
+my $OPT_WITH_TIGER = 0;
 my $OPT_WITH_TOPO = 0;
 my $OPT_WITH_RASTER = 0;
 my $OPT_WITH_SFCGAL = 0;
 my $OPT_EXPECT = 0;
 my $OPT_EXTENSIONS = 0;
+my @OPT_HOOK_AFTER_CREATE;
+my @OPT_HOOK_BEFORE_UNINSTALL;
+my @OPT_HOOK_BEFORE_UPGRADE;
+my @OPT_HOOK_AFTER_UPGRADE;
 my $OPT_EXTVERSION = '';
 my $OPT_UPGRADE_PATH = '';
 our $OPT_UPGRADE_FROM = '';
 my $OPT_UPGRADE_TO = '';
-my $VERBOSE = 0;
-my $OPT_SCHEMA = 'public';
+our $VERBOSE = 0;
+our $OPT_SCHEMA = 'public';
 GetOptions (
 	'verbose' => \$VERBOSE,
@@ -80,12 +90,17 @@ GetOptions (
 	'upgrade-path=s' => \$OPT_UPGRADE_PATH,
 	'dumprestore' => \$OPT_DUMPRESTORE,
 	'nocreate' => \$OPT_NOCREATE,
+	'tiger' => \$OPT_WITH_TIGER,
 	'topology' => \$OPT_WITH_TOPO,
 	'raster' => \$OPT_WITH_RASTER,
 	'sfcgal' => \$OPT_WITH_SFCGAL,
 	'expect' => \$OPT_EXPECT,
 	'extensions' => \$OPT_EXTENSIONS,
-	'schema=s' => \$OPT_SCHEMA
+	'schema=s' => \$OPT_SCHEMA,
+	'after-create-script=s' => \@OPT_HOOK_AFTER_CREATE,
+	'before-uninstall-script=s' => \@OPT_HOOK_BEFORE_UNINSTALL,
+	'before-upgrade-script=s' => \@OPT_HOOK_BEFORE_UPGRADE,
+	'after-upgrade-script=s' => \@OPT_HOOK_AFTER_UPGRADE
 if ( @ARGV < 1 )
@@ -95,10 +110,6 @@ if ( @ARGV < 1 )
 if ( $OPT_UPGRADE_PATH )
-  if ( ! $OPT_EXTENSIONS )
-    die "--upgrade-path is only supported with --extension"
   $OPT_UPGRADE = 1; # implied
   my @path = split ('--', $OPT_UPGRADE_PATH);
   $OPT_UPGRADE_FROM = $path[0]
@@ -108,13 +119,18 @@ if ( $OPT_UPGRADE_PATH )
   print "Upgrade path: ${OPT_UPGRADE_FROM} --> ${OPT_UPGRADE_TO}\n";
-if ( $OPT_EXTENSIONS )
+# Split-raster extension was introduced in PostGIS-3.0.0
+sub has_split_raster_ext
-	$OPT_WITH_RASTER = 1; # implied
+  my $fullver = shift;
+  # unpackaged is always current, so does have
+  # split raster already.
+  return 1 if $fullver =~ /^unpackaged/;
+  my @ver = split(/\./, $fullver);
+  return 0 if ( $ver[0] < 3 );
+  return 1;
 # Set the locale to "C" so error messages match
 # Save original locale to set back
@@ -137,7 +153,7 @@ $ENV{"PGOPTIONS"} = $PGOPTIONS;
 my $PATH = $ENV{"PATH"}; # this is useless
 # Calculate the regression directory locations
-my $STAGED_INSTALL_DIR = $REGDIR . "/00-regress-install";
+my $STAGED_INSTALL_DIR = $TOP_BUILDDIR . "/regress/00-regress-install";
 my $STAGED_SCRIPTS_DIR = $STAGED_INSTALL_DIR . "/share/contrib/postgis";
 my $OBJ_COUNT_PRE = 0;
@@ -149,21 +165,6 @@ my $OBJ_COUNT_POST = 0;
 print "PATH is $PATH\n";
-#foreach my $exec ( ("psql", "createdb", "createlang", "dropdb") )
-#	my $execdir = which( $exec );
-#	print "Checking for $exec ... ";
-#	if ( $execdir )
-#		print "found $execdir\n";
-#	else
-#		print "failed\n";
-#		die "Unable to find $exec executable. Please ensure it is on your PATH.\n";
 foreach my $exec ( ($SHP2PGSQL, $PGSQL2SHP) )
 	printf "Checking for %s ... ", basename($exec);
@@ -174,7 +175,8 @@ foreach my $exec ( ($SHP2PGSQL, $PGSQL2SHP) )
 	else
 		print "failed\n";
-		die "Unable to find $exec executable.\n";
+		print STDERR "Unable to find $exec executable.\n";
+		die "HINT: set POSTGIS_TOP_BUILD_DIR env variable to the build dir.\n";
@@ -219,12 +221,17 @@ my $REGRESS_LOG = "${TMPDIR}/regress_log";
 # Report
 print "TMPDIR is $TMPDIR\n";
 # Prepare the database
-my @dblist = grep(/\b$DB\b/, split(/\n/, `psql -Xl`));
+my @dblist = grep(/1/, split(/\n/, `
+psql -tAc "
+    SELECT 1 FROM pg_catalog.pg_database
+    WHERE datname = '${DB}'
+" template1
 my $dbcount = @dblist;
 if ( $dbcount == 0 )
@@ -248,13 +255,15 @@ else
 	else
-		print "Database $DB already exists.\n";
-		print "Drop it, or run with the --nocreate flag to use it.\n";
-		exit(1);
+		print STDERR "Database $DB already exists, dropping.\n";
+		`dropdb $DB`;
+		create_spatial();
+my $pgvernum = sql("SELECT current_setting('server_version_num')");
 my $libver = sql("select postgis_lib_version()");
+my $defextver = sql("select default_version from pg_available_extensions where name = 'postgis'");
 if ( ! $libver )
@@ -264,6 +273,23 @@ if ( ! $libver )
 	exit(1);
+sub scriptdir
+	my ( $version, $systemwide ) = @_;
+	my $scriptdir;
+	if ( $systemwide or ( $version and $version ne $libver ) ) {
+		my $pgis_majmin = $version;
+		$pgis_majmin =~ s/^([1-9]*\.[0-9]*).*/\1/;
+		$scriptdir = `pg_config --sharedir`;
+		chop $scriptdir;
+		$scriptdir .= "/contrib/postgis-" . $pgis_majmin;
+	} else {
+		$scriptdir = $STAGED_SCRIPTS_DIR;
+	#print "XXX: scriptdir: $scriptdir\n";
+	return $scriptdir;
 sub semver_lessthan
   my ($a,$b) = @_;
@@ -280,79 +306,15 @@ sub semver_lessthan
 	return @bcomp ? 1 : 0;
-sub create_upgrade_test_objects
-  # TODO: allow passing the "upgrade-init" script via commandline
-  my $query = "create table upgrade_test(g1 geometry, g2 geography";
-  $query .= ", r raster" if ( $OPT_WITH_RASTER );
-  $query .= ")";
-  my $ret = sql($query);
-  unless ( $ret =~ /^CREATE/ ) {
-    `dropdb $DB`;
-    print "\nSomething went wrong creating upgrade_test table: $ret.\n";
-    exit(1);
-  if ( $OPT_WITH_RASTER )
-    $query = "UPDATE upgrade_test SET r = ";
-    $query .= " ST_AddBand(ST_MakeEmptyRaster(10, 10, 1, 1, 2, 2, 0, 0,4326), 1, '8BSI'::text, -129, NULL);";
-    $ret = sql($query);
-    unless ( $ret =~ /^UPDATE/ ) {
-      `dropdb $DB`;
-      print "\nSomething went wrong setting raster into upgrade_test table: $ret.\n";
-      exit(1);
-    $query = "set client_min_messages to error; select AddRasterConstraints('upgrade_test', 'r')";
-    unless ( $ret =~ /^t$/ ) {
-      `dropdb $DB`;
-      print "\nSomething went wrong adding raster constraints to upgrade_test: " . $ret . "\n";
-      exit(1);
-  if ( $OPT_WITH_TOPO )
-    $query = "select topology.createTopology('upgrade_test');";
-    unless ( $ret =~ /^[1-9][0-9]*$/ ) {
-      `dropdb $DB`;
-      print "\nSomething went wrong adding upgrade_test topology: " . $ret . "\n";
-      exit(1);
-sub drop_upgrade_test_objects
-  # TODO: allow passing the "upgrade-cleanup" script via commandline
-  my $ret = sql("drop table upgrade_test;");
-  unless ( $ret =~ /^DROP/ ) {
-    `dropdb $DB`;
-    print "\nSomething went wrong dropping spatial tables: $ret.\n";
-    exit(1);
-    my $query = "SELECT topology.DropTopology('upgrade_test');";
-    unless ( $ret =~ /^Topology 'upgrade_test' dropped$/ ) {
-      `dropdb $DB`;
-      print "\nSomething went wrong dropping upgrade_test topology: " . $ret . "\n";
-      exit(1);
 if ( $OPT_UPGRADE )
-  create_upgrade_test_objects();
+	print "Upgrading from postgis $libver\n";
+	foreach my $hook (@OPT_HOOK_BEFORE_UPGRADE)
+		print "Running before-upgrade-script $hook\n";
+		die unless load_sql_file($hook, 1);
@@ -363,7 +325,11 @@ if ( $OPT_UPGRADE )
 	  upgrade_spatial();
-  drop_upgrade_test_objects();
+	foreach my $hook (@OPT_HOOK_AFTER_UPGRADE)
+		print "Running after-upgrade-script $hook\n";
   # Update libver
@@ -381,17 +347,20 @@ if ( $OPT_DUMPRESTORE )
 my $geosver =  sql("select postgis_geos_version()");
 my $projver = sql("select postgis_proj_version()");
-my $svnrev = sql("select postgis_svn_version()");
 my $libbuilddate = sql("select postgis_lib_build_date()");
 my $pgsqlver = sql("select version()");
 my $gdalver = sql("select postgis_gdal_version()") if $OPT_WITH_RASTER;
 my $sfcgalver = sql("select postgis_sfcgal_version()") if $OPT_WITH_SFCGAL;
 my $scriptver = sql("select postgis_scripts_installed()");
+# postgis_lib_revision was introduced in 3.1.0
+my $librev = semver_lessthan($scriptver, "3.1.0") ?
+							sql("select postgis_svn_version()") :
+							sql("select postgis_lib_revision()");
 my $raster_scriptver = sql("select postgis_raster_scripts_installed()")
 print "$pgsqlver\n";
-print "  Postgis $libver - r${svnrev} - $libbuilddate\n";
+print "  Postgis $libver - (${librev}) - $libbuilddate\n";
 print "  scripts ${scriptver}\n";
 print "  raster scripts ${raster_scriptver}\n" if ( $OPT_WITH_RASTER );
 print "  GEOS: $geosver\n" if $geosver;
@@ -414,15 +383,51 @@ our $TEST = "";
 print "\nRunning tests\n\n";
+foreach my $hook (@OPT_HOOK_AFTER_CREATE)
+	start_test("after-create-script $hook");
+	show_progress();
+	pass() if load_sql_file($hook, 1);
 foreach $TEST (@ARGV)
+	my $TEST_OBJ_COUNT_PRE;
+	my $TEST_OBJ_COUNT_POST;
+	my $TEST_START_TIME;
+	if ( "${TEST}" eq '-' )
+		my $scriptdir = scriptdir($libver, $OPT_EXTENSIONS);
+		print "-- Entering interactive shell --\n";
+		# TODO: add more variables?
+		my $cmd = "psql -Xq"
+		  . " -v \"regdir=$REGDIR\""
+		  . " -v \"top_builddir=$TOP_BUILDDIR\""
+		  . " -v \"scriptdir=$scriptdir\""
+		  . " -v \"schema=$OPT_SCHEMA.\""
+		  # TODO: inject search_path somehow
+		  #. " -c \"SET search_path TO public,$OPT_SCHEMA,topology\""
+		  . " ${DB}"
+		my $rv = system($cmd);
+		print "-- Moving on with tests, if any --\n";
+		next;
 	# catch a common mistake (strip trailing .sql)
 	$TEST =~ s/.sql$//;
 	start_test($TEST);
+	$TEST_OBJ_COUNT_PRE = count_postgis_objects();
 	# Check for a "-pre.pl" file in case there are setup commands
-    eval_file("${TEST}-pre.pl");
+	unless ( eval_file("${TEST}-pre.pl") )
+		chop($@);
+		fail("Failed evaluating ${TEST}-pre.pl: $@");
+		next;
 	# Check for a "-pre.sql" file in case there is setup SQL needed before
 	# the test can be run.
@@ -436,23 +441,37 @@ foreach $TEST (@ARGV)
 	# create the .sql
 	# Check for .dbf not just .shp since the loader can load
 	# .dbf files without a .shp.
+	$TEST_START_TIME = time;
 	if ( -r "${TEST}.dbf" )
-		pass() if ( run_loader_test() );
+		pass("in ".int(1000*(time-$TEST_START_TIME))." ms") if ( run_loader_test() );
 	elsif ( -r "${TEST}.tif" )
-		my $rv = run_raster_loader_test();
-		pass() if $rv;
+		my $rv = run_raster_loader_test("${TEST}.tif");
+		pass("in ".int(1000*(time-$TEST_START_TIME))." ms") if $rv;
+	elsif ( -r "${TEST}.tif.ref" )
+		open(REF, "${TEST}.tif.ref");
+		my $raster_ref = <REF>;
+		close(REF);
+		chop $raster_ref;
+		#print "Raster ref: [$raster_ref]\n";
+		# Resolve raster_ref relative to ${TEST} dirname
+		my $raster_path = dirname(${TEST}) . '/' . $raster_ref;
+		#print "Raster path: [$raster_path]\n";
+		my $rv = run_raster_loader_test($raster_path);
 	elsif ( -r "${TEST}.sql" )
 		my $rv = run_simple_test("${TEST}.sql", "${TEST}_expected");
-		pass() if $rv;
 	elsif ( -r "${TEST}.dmp" )
-		pass() if run_dumper_test();
+		pass("in ".int(1000*(time-$TEST_START_TIME))." ms") if run_dumper_test();
 	else
@@ -472,8 +491,22 @@ foreach $TEST (@ARGV)
 	# Check for a "-post.pl" file in case there are teardown commands
-    eval_file("${TEST}-post.pl");
+	eval_file("${TEST}-post.pl");
+	$TEST_OBJ_COUNT_POST = count_postgis_objects();
+	if ( $TEST_OBJ_COUNT_POST != $TEST_OBJ_COUNT_PRE )
+		fail("PostGIS object count pre-test ($TEST_OBJ_COUNT_POST) != post-test ($TEST_OBJ_COUNT_PRE)");
+foreach my $hook (@OPT_HOOK_BEFORE_UNINSTALL)
+	start_test("before-uninstall-script $hook");
+	show_progress();
@@ -505,7 +538,6 @@ if ( $OPT_CLEAN )
 if ( ! ($OPT_NODROP || $OPT_NOCREATE) )
-	sleep(1);
 	system("dropdb $DB");
 else
@@ -533,15 +565,37 @@ Options:
   -v, --verbose   be verbose about failures
   --nocreate      do not create the regression database on start
   --upgrade       source the upgrade scripts on start
-  --upgrade-path  upgrade path, format <from>--<to>
+  --upgrade-path  upgrade path, format <from>--<to>.
+                  <from> can be specified as "unpackaged<version>"
+                         to specify a script version to start from.
+                  <to> can be specified as ":auto" to request
+                       upgrades to default version, and be appended
+                       an exclamation mark (ie: ":auto!" or "3.0.0!") to
+                       request upgrade via postgis_extensions_upgrade()
+                       if available.
   --dumprestore   dump and restore spatially-enabled db before running tests
   --nodrop        do not drop the regression database on exit
+  --schema        where to install/find PostGIS (relocatable) PostGIS
+                  (defaults to "public")
   --raster        load also raster extension
+  --tiger      		load also tiger_geocoder extension
   --topology      load also topology extension
   --sfcgal        use also sfcgal backend
   --clean         cleanup test logs on exit
   --expect        save obtained output as expected
   --extension     load using extensions
+  --after-create-script <path>
+                  script to load after spatial db creation
+                  (multiple switches supported, to be run in given order)
+  --before-uninstall-script <path>
+                  script to load before spatial extension uninstall
+  --before-upgrade-script <path>
+                  script to load before upgrade
+  --after-upgrade-script <path>
+                  script to load after upgrade
@@ -571,8 +625,8 @@ sub show_progress
 # pass <msg>
 sub pass
-  my $msg = shift;
-  printf(" ok %s\n", $msg);
+    my $msg = shift;
+    printf(" ok %s\n", $msg);
 # fail <msg> <log>
@@ -621,7 +675,10 @@ sub run_simple_sql
 	# Dump output to a temp file.
 	my $tmpfile = sprintf("%s/test_%s_tmp", $TMPDIR, $RUN);
-	my $cmd = "psql -v \"VERBOSITY=terse\" -tXA $DB < $sql > $tmpfile 2>&1";
+	my $cmd = "psql -v \"VERBOSITY=terse\" "
+		. " -tXAq $DB < $sql > $tmpfile 2>&1";
 	#print($cmd);
 	# Check if psql errored out.
@@ -650,7 +707,7 @@ sub run_simple_sql
 sub drop_table
 	my $tblname = shift;
-	my $cmd = "psql -tXA -d $DB -c \"DROP TABLE IF EXISTS $tblname\" >> $REGRESS_LOG 2>&1";
+	my $cmd = "psql -tXAq -d $DB -c \"DROP TABLE IF EXISTS $tblname\" >> $REGRESS_LOG 2>&1";
 	die "Could not run: $cmd\n" if $rv;
@@ -658,7 +715,7 @@ sub drop_table
 sub sql
 	my $sql = shift;
-	my $result = `psql -tXA -d $DB -c "$sql"`;
+	my $result = `psql -tXA -d $DB -c 'SET search_path TO public,$OPT_SCHEMA' -c "$sql" | sed '/^SET\$/d'`;
 	$result =~ s/[\n\r]*$//;
 	$result;
@@ -669,12 +726,10 @@ sub eval_file
     my $pl;
     if ( -r $file )
-        #open(PL, $file);
-        #$pl = <PL>;
-        #close(PL);
-        #eval($pl);
-				do $file;
+				do $file or return 0;
+				#system($^X, $file) == 0 or return 0;
+		1;
@@ -713,24 +768,22 @@ sub run_simple_test
 	mkpath($betmpdir);
 	chmod 0777, $betmpdir;
-	my $scriptdir;
-	if ( $OPT_EXTENSIONS ) {
-		# TODO: allow override this default with env variable ?
-		my $pgis_majmin = $libver;
-		$pgis_majmin =~ s/^([1-9]*\.[1-9]*).*/\1/;
-		$scriptdir = `pg_config --sharedir`;
-		chop $scriptdir;
-		$scriptdir .= "/contrib/postgis-" . $pgis_majmin;
-	} else {
-		$scriptdir = $STAGED_SCRIPTS_DIR;
-	my $cmd = "psql -v \"VERBOSITY=terse\""
+	my ($sqlfile,$sqldir) = fileparse($sql);
+	my $cmd = "cd $sqldir; psql -v \"VERBOSITY=terse\""
           . " -v \"tmpfile='$tmpfile'\""
-          . " -tXA $DB < $sql > $outfile 2>&1";
+          . " -c \"SET search_path TO public,$OPT_SCHEMA,topology\""
+          . " -tXAq -f $sqlfile $DB > $outfile 2>&1";
+    if ( $rv ) {
+        fail "psql exited with an error", $outfile;
+        die;
 	# Check for ERROR lines
 	open(FILE, "$outfile");
@@ -739,7 +792,7 @@ sub run_simple_test
 	# Strip the lines we don't care about
 	@lines = grep(!/^\$/, @lines);
-	@lines = grep(!/^(INSERT|DELETE|UPDATE|SELECT|COPY|DO)/, @lines);
+	@lines = grep(!/^(INSERT|DELETE|UPDATE|SELECT [0-9]*|COPY|DO)$/, @lines);
 	@lines = grep(!/^(CONTEXT|RESET|ANALYZE)/, @lines);
 	@lines = grep(!/^(DROP|CREATE|ALTER|VACUUM)/, @lines);
 	@lines = grep(!/^(LOG|SET|TRUNCATE|DISCARD)/, @lines);
@@ -837,7 +890,7 @@ sub run_loader_and_check_output
 		if ( $rv )
-			fail(" $description: running shp2pgsql", "$errfile");
+			fail(" $description: running $cmd", "$errfile");
 			return 0;
@@ -946,6 +999,7 @@ sub run_dumper_and_check_output
 sub run_raster_loader_and_check_output
 	my $description = shift;
+	my $raster_file = shift;
 	my $expected_sql_file = shift;
 	my $expected_select_results_file = shift;
@@ -964,7 +1018,7 @@ sub run_raster_loader_and_check_output
 		show_progress();
 		# Produce the output SQL file.
-		$cmd = "$RASTER2PGSQL $loader_options ${TEST}.tif $tblname > $outfile 2> $errfile";
+		$cmd = "$RASTER2PGSQL $loader_options $raster_file $tblname > $outfile 2> $errfile";
 		$rv = system($cmd);
 		if ( $rv )
@@ -1025,10 +1079,14 @@ sub run_loader_test
 	if ( -r $opts_file )
 		open(FILE, $opts_file);
-		my @opts = <FILE>;
+		my @opts;
+		while (<FILE>) {
+			next if /^\s*#/;
+			chop;
+			s/{regdir}/$REGDIR/;
+			push @opts, $_;
 		close(FILE);
-		@opts = grep(!/^\s*#/, @opts);
-		map(s/\n//, @opts);
 		$custom_opts = join(" ", @opts);
@@ -1037,6 +1095,7 @@ sub run_loader_test
 	# If we have some expected files to compare with, run in wkt mode.
 	if ( ! run_loader_and_check_output("wkt test", $tblname, "${TEST}-w.sql.expected", "${TEST}-w.select.expected", "-w $custom_opts") )
+		drop_table($tblname) unless $OPT_NODROP;
 		return 0;
 	drop_table($tblname);
@@ -1044,11 +1103,13 @@ sub run_loader_test
 	# If we have some expected files to compare with, run in geography mode.
 	if ( ! run_loader_and_check_output("geog test", $tblname, "${TEST}-G.sql.expected", "${TEST}-G.select.expected", "-G $custom_opts") )
 		return 0;
 	# If we have some expected files to compare with, run the dumper and compare shape files.
 	if ( ! run_dumper_and_check_output("dumper geog test", $tblname, "${TEST}-G.shp.expected") )
 		return 0;
@@ -1056,11 +1117,13 @@ sub run_loader_test
 	# Always run in wkb ("normal") mode, even if there are no expected files to compare with.
 	if( ! run_loader_and_check_output("wkb test", $tblname, "${TEST}.sql.expected", "${TEST}.select.expected", "$custom_opts", "true") )
 		return 0;
 	if( ! run_dumper_and_check_output("dumper wkb test", $tblname, "${TEST}.shp.expected") )
 		return 0;
@@ -1071,6 +1134,7 @@ sub run_loader_test
 		# If we have some expected files to compare with, run in wkt dump mode.
 		if ( ! run_loader_and_check_output("wkt dump test", $tblname, "${TEST}-wD.sql.expected") )
 			return 0;
@@ -1078,6 +1142,7 @@ sub run_loader_test
 		if ( ! run_loader_and_check_output("geog dump test", $tblname, "${TEST}-GD.sql.expected") )
 			return 0;
@@ -1085,6 +1150,7 @@ sub run_loader_test
 		# If we have some expected files to compare with, run in wkb dump mode.
 		if ( ! run_loader_and_check_output("wkb dump test", $tblname, "${TEST}-D.sql.expected") )
 			return 0;
@@ -1099,9 +1165,9 @@ sub run_loader_test
 #  Run dumper and compare output with various expectances
 #  test and run simple test with provided expected output.
-# input is ${TEST}.dmp, where last line is considered to be the
-# [table|query] argument for pgsql2shp and all the previous lines,
-# if any are
+# input is ${TEST}.dmp, where first line is considered to be the
+# [table|query] argument for pgsql2shp and all the next lines,
+# if any are options.
 sub run_dumper_test
@@ -1117,12 +1183,16 @@ sub run_dumper_test
   # Produce the output SHP file.
   open DUMPFILE, "$dump_file" or die "Cannot open dump file $dump_file\n";
-  sleep(1);
   my @dumplines = <DUMPFILE>;
   close DUMPFILE;
-  my $dumpstring = join '', @dumplines;
-  chop($dumpstring);
-  my @cmd = ("${PGSQL2SHP}", "-f", ${shpfile}, ${DB}, ${dumpstring});
+  chomp(@dumplines);
+  my $dumpstring = shift @dumplines;
+  @dumplines = map { local $_ = $_; s/{regdir}/$REGDIR/; $_ } @dumplines;
+  my @cmd = ("${PGSQL2SHP}", "-f", ${shpfile});
+  push @cmd, @dumplines;
+  push @cmd, ${DB};
+  push @cmd, $dumpstring;
+  #print "CMD: " . join (' ', @cmd) . "\n";
   open my $stdout_save, '>&', *STDOUT or die "Cannot dup stdout\n";
   open my $stderr_save, '>&', *STDERR or die "Cannot dup stdout\n";
   open STDOUT, ">${outfile}" or die "Cannot write to ${outfile}\n";
@@ -1130,7 +1200,6 @@ sub run_dumper_test
   my $rv = system(@cmd);
   open STDERR, '>&', $stderr_save;
   open STDOUT, '>&', $stdout_save;
-  #sleep(3);
   show_progress();
   if ( $rv )
@@ -1182,24 +1251,30 @@ sub run_dumper_test
 sub run_raster_loader_test
 	# See if there is a custom command-line options file
 	my $opts_file = "${TEST}.opts";
 	my $custom_opts="";
+		my $regdir = abs_path(dirname(${TEST}));
+		my @opts;
+		while (<FILE>) {
+			next if /^\s*#/;
+			chop;
+			s/{regdir}/$regdir/;
+			push @opts, $_;
 		close(FILE);
 	my $tblname="loadedrast";
-	if ( ! run_raster_loader_and_check_output("test", $tblname, "${TEST}.sql.expected", "${TEST}.select.expected", $custom_opts, "true") )
+	if ( ! run_raster_loader_and_check_output("test", $raster_file, $tblname, "${TEST}.sql.expected", "${TEST}.select.expected", $custom_opts, "true") )
 		return 0;
@@ -1223,42 +1298,74 @@ sub count_db_objects
 		select count(*) from pg_operator union all
 		select count(*) from pg_opclass union all
 		select count(*) from pg_namespace
-			where nspname NOT LIKE 'pg_%' union all
-		select count(*) from pg_opfamily )
+			where nspname NOT LIKE 'pg_%'
+			  and nspname != '${OPT_SCHEMA}'
+		union all
+		select count(*) from pg_opfamily
+		select sum(count) from counts");
+ 	return $count;
+# Count postgis objects
+sub count_postgis_objects
+	my $count = sql("WITH counts as (
+		select count(*) from spatial_ref_sys
  	return $count;
 # Create the spatial database
 sub create_db
-	my $cmd = "createdb --encoding=UTF-8 --template=template0 --lc-collate=C $DB > $REGRESS_LOG";
-	return system($cmd);
+	my $createcmd = "createdb --encoding=UTF-8 --template=template0 --lc-collate=C $DB > $REGRESS_LOG";
+	return system($createcmd);
 sub create_spatial
-	my ($cmd, $rv);
-	print "Creating database '$DB' \n";
+    my ($cmd, $rv);
+    print "Creating database '$DB' \n";
-  $rv = create_db();
+    $rv = create_db();
+    # Count database objects before installing anything
+    $OBJ_COUNT_PRE = count_db_objects();
-	# Count database objects before installing anything
-	$OBJ_COUNT_PRE = count_db_objects();
+    if ( $OPT_EXTENSIONS )
+        prepare_spatial_extensions();
+    else
+        if ( ! $OPT_UPGRADE_FROM )
+            prepare_spatial();
+            return;
-		prepare_spatial_extensions();
-	else
-		prepare_spatial();
+        if ( $OPT_UPGRADE_FROM !~ /^unpackaged(.*)/ )
+            die "--upgrade-path without --extension is only supported with source unpackaged*";
+        if ( $OPT_UPGRADE_TO != ':auto' )
+            die "--upgrade-path without --extension is only supported with target :auto";
+        prepare_spatial($1);
@@ -1269,20 +1376,24 @@ sub load_sql_file
 	if ( $strict && ! -e $file )
-		die "Unable to find $file\n";
+		fail "Unable to find $file";
+		return 0;
 	if ( -e $file )
 		# ON_ERROR_STOP is used by psql to return non-0 on an error
 		my $psql_opts = "--no-psqlrc --variable ON_ERROR_STOP=true";
-		my $cmd = "psql $psql_opts -Xf $file $DB >> $REGRESS_LOG 2>&1";
-		print "  $file\n" if $VERBOSE;
+		my $cmd = "psql $psql_opts -c 'CREATE SCHEMA IF NOT EXISTS $OPT_SCHEMA' ";
+		$cmd .= "-c 'SET search_path TO $OPT_SCHEMA,topology'";
+		$cmd .= " -Xf $file $DB >> $REGRESS_LOG 2>&1";
+		#print "  $file\n" if $VERBOSE;
 		if ( $rv )
 		  fail "Error encountered loading $file", $REGRESS_LOG;
-		  exit 1
+		  #exit 1;
+			return 0;
 	return 1;
@@ -1293,15 +1404,27 @@ sub prepare_spatial_extensions
+	my $sql = "CREATE SCHEMA IF NOT EXISTS ${OPT_SCHEMA}";
+	my $cmd = "psql $psql_opts -c \"". $sql . "\" $DB >> $REGRESS_LOG 2>&1";
+	if ( $rv ) {
+	  fail "Error encountered creating target schema ${OPT_SCHEMA}", $REGRESS_LOG;
+	  die;
 	my $sql = "CREATE EXTENSION postgis";
 	if ( $OPT_UPGRADE_FROM ) {
-		if ( $OPT_UPGRADE_FROM eq "unpackaged" ) {
+		if ( $OPT_UPGRADE_FROM =~ /^unpackaged(.*)/ ) {
 			return;
 		$sql .= " VERSION '" . $OPT_UPGRADE_FROM . "'";
+	$sql .= " SCHEMA " . $OPT_SCHEMA;
 	print "Preparing db '${DB}' using: ${sql}\n";
@@ -1329,9 +1452,50 @@ sub prepare_spatial_extensions
+	if ( $OPT_WITH_TIGER )
+		my $sql = "CREATE EXTENSION postgis_tiger_geocoder CASCADE";
+		if ( $OPT_UPGRADE_FROM ) {
+			$sql .= " VERSION '" . $OPT_UPGRADE_FROM . "'";
+		print "Preparing db '${DB}' using: ${sql}\n";
+ 		$cmd = "psql $psql_opts -c \"" . $sql . "\" $DB >> $REGRESS_LOG 2>&1";
+		$rv = system($cmd);
+  	if ( $rv ) {
+  		fail "Error encountered creating EXTENSION POSTGIS_TIGER_GEOCODER", $REGRESS_LOG;
+  		die;
+	if ( $OPT_WITH_RASTER && (
+		# NOTE: this code is assuming that the default version
+		# (!$OPT_UPGRADE_FROM) has split raster extension
+		! $OPT_UPGRADE_FROM ||
+		has_split_raster_ext($OPT_UPGRADE_FROM)
+		my $sql = "CREATE EXTENSION postgis_raster";
+		if ( $rv ) {
+			fail "Error encountered creating EXTENSION POSTGIS_RASTER", $REGRESS_LOG;
+			die;
 	if ( $OPT_WITH_SFCGAL )
-		do {
 			my $sql = "CREATE EXTENSION postgis_sfcgal";
 				if ( semver_lessthan($OPT_UPGRADE_FROM, "2.2.0") )
@@ -1343,6 +1507,8 @@ sub prepare_spatial_extensions
@@ -1351,7 +1517,7 @@ sub prepare_spatial_extensions
 				fail "Error encountered creating EXTENSION POSTGIS_SFCGAL", $REGRESS_LOG;
 				die;
-		} while (0);
  	return 1;
@@ -1360,99 +1526,83 @@ sub prepare_spatial_extensions
 # Prepare the database for spatial operations (old method)
 sub prepare_spatial
+	my $version = shift;
+	my $scriptdir = scriptdir($version);
+	print "Loading unpackaged components from $scriptdir\n";
 	print "Loading PostGIS into '${DB}' \n";
 	# Load postgis.sql into the database
-	load_sql_file("${STAGED_SCRIPTS_DIR}/postgis.sql", 1);
-	load_sql_file("${STAGED_SCRIPTS_DIR}/postgis_comments.sql", 0);
-	load_sql_file("${STAGED_SCRIPTS_DIR}/postgis_proc_set_search_path.sql", 0);
+	load_sql_file("${scriptdir}/postgis.sql", 1);
+	load_sql_file("${scriptdir}/postgis_comments.sql", 0);
+	load_sql_file("${scriptdir}/spatial_ref_sys.sql", 0);
 		print "Loading Topology into '${DB}'\n";
-		load_sql_file("${STAGED_SCRIPTS_DIR}/topology.sql", 1);
-		load_sql_file("${STAGED_SCRIPTS_DIR}/topology_comments.sql", 0);
+		load_sql_file("${scriptdir}/topology.sql", 1);
+		load_sql_file("${scriptdir}/topology_comments.sql", 0);
 		print "Loading Raster into '${DB}'\n";
-		load_sql_file("${STAGED_SCRIPTS_DIR}/rtpostgis.sql", 1);
-		load_sql_file("${STAGED_SCRIPTS_DIR}/raster_comments.sql", 0);
-		load_sql_file("${STAGED_SCRIPTS_DIR}/rtpostgis_proc_set_search_path.sql", 0);
+		load_sql_file("${scriptdir}/rtpostgis.sql", 1);
+		load_sql_file("${scriptdir}/raster_comments.sql", 0);
 		print "Loading SFCGAL into '${DB}'\n";
-		load_sql_file("${STAGED_SCRIPTS_DIR}/sfcgal.sql", 1);
-		load_sql_file("${STAGED_SCRIPTS_DIR}/sfcgal_comments.sql", 0);
+		load_sql_file("${scriptdir}/sfcgal.sql", 1);
+		load_sql_file("${scriptdir}/sfcgal_comments.sql", 0);
 	return 1;
+sub package_extension_sql
+	my ($extname, $extver) = @_;
+	my $sql;
+	if ( $pgvernum lt 130000 ) {
+		$sql = "CREATE EXTENSION ${extname} VERSION '${extver}' FROM unpackaged;";
+	} else {
+		$sql = "CREATE EXTENSION ${extname} VERSION unpackaged;";
+		$sql .= "ALTER EXTENSION ${extname} UPDATE TO '${extver}'";
+	return $sql;
 # Upgrade an existing database (soft upgrade)
 sub upgrade_spatial
     print "Upgrading PostGIS in '${DB}' \n" ;
-    my $script = `ls ${STAGED_SCRIPTS_DIR}/postgis_upgrade.sql`;
-    chomp($script);
-    if ( -e $script )
-        print "Upgrading core\n";
-        load_sql_file($script);
-    else
-        die "$script not found\n";
+    my $script = "${STAGED_SCRIPTS_DIR}/postgis_upgrade.sql";
+    print "Upgrading core\n";
+    die unless load_sql_file($script, 1);
-        my $script = `ls ${STAGED_SCRIPTS_DIR}/topology_upgrade.sql`;
-        chomp($script);
-        if ( -e $script )
-            print "Upgrading topology\n";
-        else
+        $script = "${STAGED_SCRIPTS_DIR}/topology_upgrade.sql";
+        print "Upgrading topology\n";
-        my $script = `ls ${STAGED_SCRIPTS_DIR}/rtpostgis_upgrade.sql`;
-        chomp($script);
-        if ( -e $script )
-            print "Upgrading raster\n";
-        else
+        $script = "${STAGED_SCRIPTS_DIR}/rtpostgis_upgrade.sql";
+        print "Upgrading raster\n";
-        my $script = `ls ${STAGED_SCRIPTS_DIR}/sfcgal_upgrade.sql`;
-        chomp($script);
-        if ( -e $script )
-            print "Upgrading sfcgal\n";
-        else
+        $script = "${STAGED_SCRIPTS_DIR}/sfcgal_upgrade.sql";
+        print "Upgrading sfcgal\n";
     return 1;
@@ -1463,11 +1613,44 @@ sub upgrade_spatial_extensions
+    my $sql;
+    my $upgrade_via_function = 0;
+    if ( $OPT_UPGRADE_TO =~ /!$/ )
+      $OPT_UPGRADE_TO =~ s/!$//;
+      my $from = $OPT_UPGRADE_FROM;
+      $from =~ s/^unpackaged//;
+      if ( ! $from || ! semver_lessthan($from, "3.0.0") )
+        $upgrade_via_function = 1;
+      else
+        print "WARNING: postgis_extensions_upgrade()".
+              " not available or functional in version $from.".
+              " We'll use manual upgrade.\n";
+    if ( $OPT_UPGRADE_TO =~ /^:auto/ )
+      $OPT_UPGRADE_TO = $defextver;
     my $nextver = $OPT_UPGRADE_TO ? "${OPT_UPGRADE_TO}" : "${libver}next";
-    my $sql = "ALTER EXTENSION postgis UPDATE TO '${nextver}'";
-      $sql = "CREATE EXTENSION postgis VERSION '${nextver}' FROM unpackaged";
+    if ( $upgrade_via_function )
+      $sql = "SELECT postgis_extensions_upgrade()";
+    elsif ( $OPT_UPGRADE_FROM =~ /^unpackaged/ )
+			$sql = package_extension_sql('postgis', ${nextver});
+    else
+      $sql = "ALTER EXTENSION postgis UPDATE TO '${nextver}'";
     print "Upgrading PostGIS in '${DB}' using: ${sql}\n" ;
@@ -1476,24 +1659,95 @@ sub upgrade_spatial_extensions
     #print "CMD: " . $cmd . "\n";
     if ( $rv ) {
-      fail "Error encountered altering EXTENSION POSTGIS", $REGRESS_LOG;
+      fail "Error encountered updating EXTENSION POSTGIS", $REGRESS_LOG;
       die;
+    # Handle raster split if coming from pre-split and going
+    # to splitted raster
+    if ( $OPT_UPGRADE_FROM && has_split_raster_ext($OPT_UPGRADE_TO) &&
+         ! has_split_raster_ext($OPT_UPGRADE_FROM) )
+      if ( $OPT_WITH_RASTER )
+        # upgrade of postgis must have unpackaged raster, so
+        # we create it again here
+				my $sql = package_extension_sql('postgis_raster', ${nextver});
+        print "Upgrading PostGIS Raster in '${DB}' using: ${sql}\n" ;
+        my $cmd = "psql $psql_opts -c \"" . $sql . "\" $DB >> $REGRESS_LOG 2>&1";
+        if ( $rv ) {
+          fail "Error encountered creating EXTENSION POSTGIS_RASTER from unpackaged on upgrade", $REGRESS_LOG;
+          die;
+      else
+        # Raster support was not requested, so drop it if
+        # left unpackaged
+        print "Packaging PostGIS Raster in '${DB}' for later drop using: ${sql}\n" ;
+				$sql = package_extension_sql('postgis_raster', ${nextver});
+        if ( $rv ) {
+          die;
+        print "Dropping PostGIS Raster in '${DB}' using: ${sql}\n" ;
+        $sql = "DROP EXTENSION postgis_raster";
+        if ( $rv ) {
+          fail "Error encountered dropping EXTENSION POSTGIS_RASTER on upgrade", $REGRESS_LOG;
+          die;
+      # The function does everything
+      return 1;
+        my $sql = "ALTER EXTENSION postgis_raster UPDATE TO '${nextver}'";
+        if ( $OPT_UPGRADE_FROM =~ /^unpackaged/ ) {
+        if ( $rv ) {
+          fail "Error encountered updating EXTENSION POSTGIS_RASTER", $REGRESS_LOG;
+          die;
       my $sql = "ALTER EXTENSION postgis_topology UPDATE TO '${nextver}'";
-				$sql = "CREATE EXTENSION postgis_topology VERSION '${nextver}' FROM unpackaged";
+				$sql = package_extension_sql('postgis_topology', ${nextver});
-			print "Upgrading PostGIS Topology in '${DB}' using: ${sql}\n" ;
+      print "Upgrading PostGIS Topology in '${DB}' using: ${sql}\n";
       if ( $rv ) {
-        fail "Error encountered altering EXTENSION POSTGIS_TOPOLOGY", $REGRESS_LOG;
+        fail "Error encountered updating EXTENSION POSTGIS_TOPOLOGY", $REGRESS_LOG;
         die;
@@ -1502,8 +1756,8 @@ sub upgrade_spatial_extensions
 			my $sql;
-				$sql = "CREATE EXTENSION postgis_sfcgal VERSION '${nextver}' FROM unpackaged";
+				$sql = package_extension_sql('postgis_sfcgal', ${nextver});
 			elsif ( $OPT_UPGRADE_FROM && semver_lessthan($OPT_UPGRADE_FROM, "2.2.0") )
@@ -1574,10 +1828,29 @@ sub drop_spatial_extensions
         $ok = 0 if $rv;
+        $cmd = "psql $psql_opts -c \"DROP EXTENSION IF EXISTS postgis_raster;\" $DB >> $REGRESS_LOG 2>&1";
+      	$ok = 0 if $rv;
+        $cmd = "psql $psql_opts -c \"DROP EXTENSION IF EXISTS postgis_tiger_geocoder;
+                DROP EXTENSION IF EXISTS fuzzystrmatch;
+                DROP SCHEMA IF EXISTS tiger;
+                DROP SCHEMA IF EXISTS tiger_data;
+                \" $DB >> $REGRESS_LOG 2>&1";
+      	$ok = 0 if $rv;
     $cmd = "psql $psql_opts -c \"DROP EXTENSION postgis\" $DB >> $REGRESS_LOG 2>&1";
     $rv = system($cmd);
-  	die "\nError encountered dropping EXTENSION POSTGIS, see $REGRESS_LOG for details\n\n"
-  	    if $rv;
+    if ( $rv ) {
+        fail "Error encountered dropping EXTENSION POSTGIS", $REGRESS_LOG;
+        die;
     return $ok;
@@ -1586,6 +1859,7 @@ sub drop_spatial_extensions
 sub uninstall_spatial
 	my $ok;
 	start_test("uninstall");
@@ -1597,24 +1871,19 @@ sub uninstall_spatial
 		$ok = drop_spatial();
-	if ( $ok )
-		show_progress(); # on to objects count
-		$OBJ_COUNT_POST = count_db_objects();
+	return $ok if ! $ok;
-		if ( $OBJ_COUNT_POST != $OBJ_COUNT_PRE )
-			fail("Object count pre-install ($OBJ_COUNT_PRE) != post-uninstall ($OBJ_COUNT_POST)");
-			return 0;
-		else
-			pass("($OBJ_COUNT_PRE)");
-			return 1;
+	show_progress(); # on to objects count
+	$OBJ_COUNT_POST = count_db_objects();
+	if ( $OBJ_COUNT_POST != $OBJ_COUNT_PRE )
+		fail("Object count pre-install ($OBJ_COUNT_PRE) != post-uninstall ($OBJ_COUNT_POST)");
+		return 0;
-	return 0;
+	pass("($OBJ_COUNT_PRE)");
+	return 1;
 # Dump and restore the database
Summary of changes:
 regress/run_test.pl | 805 +++++++++++++++++++++++++++++++++++-----------------
 1 file changed, 537 insertions(+), 268 deletions(-)
hooks/post-receive
