[postgis-tickets] [SCM] PostGIS branch stable-3.0 updated. 3.0.6-7-ga0c29068d
git at osgeo.org
git at osgeo.org
Thu Aug 11 23:52:31 PDT 2022
the project "PostGIS".
The branch, stable-3.0 has been updated
via a0c29068d31774ee9e85acc2c0ce685d7a4e3741 (commit)
from 1b5a2575832dd228637d3e85d649001fe47d330e (commit)
revisions in full, below.
commit a0c29068d31774ee9e85acc2c0ce685d7a4e3741
Author: Sandro Santilli <strk at kbt.io>
Date: Fri Aug 12 08:52:24 2022 +0200
Backport run_test.pl from master branch
diff --git a/regress/run_test.pl b/regress/run_test.pl
index bc2b1284e..efafb29ae 100755
--- a/regress/run_test.pl
+++ b/regress/run_test.pl
@@ -1,4 +1,4 @@
-#!/usr/bin/perl
+#!/usr/bin/env perl
# PostGIS - Spatial Types for PostgreSQL
@@ -15,6 +15,7 @@
#$| = 1;
use File::Basename;
use File::Temp 'tempdir';
+use Time::HiRes qw(time);
#use File::Which;
use File::Copy;
use File::Path;
@@ -38,6 +39,9 @@ BEGIN {
# Run the <testname>.sql script
# Check output against <testname>_expected
+# Use `-` as the testname to drop into an interactive shell
@@ -46,9 +50,10 @@ BEGIN {
our $DB = $ENV{"POSTGIS_REGRESS_DB"} || "postgis_reg";
our $REGDIR = abs_path(dirname($0));
-our $SHP2PGSQL = $REGDIR . "/../loader/shp2pgsql";
-our $PGSQL2SHP = $REGDIR . "/../loader/pgsql2shp";
-our $RASTER2PGSQL = $REGDIR . "/../raster/loader/raster2pgsql";
+our $TOP_BUILDDIR = $ENV{"POSTGIS_TOP_BUILD_DIR"} || ${REGDIR} . '/..';
+our $SHP2PGSQL = $TOP_BUILDDIR . "/loader/shp2pgsql";
+our $PGSQL2SHP = $TOP_BUILDDIR . "/loader/pgsql2shp";
+our $RASTER2PGSQL = $TOP_BUILDDIR . "/raster/loader/raster2pgsql";
our $sysdiff = !system("diff --strip-trailing-cr $0 $0 2> /dev/null");
@@ -60,17 +65,22 @@ my $OPT_NODROP = 0;
my $OPT_NOCREATE = 0;
my $OPT_UPGRADE = 0;
my $OPT_DUMPRESTORE = 0;
+my $OPT_WITH_TIGER = 0;
my $OPT_WITH_TOPO = 0;
my $OPT_WITH_RASTER = 0;
my $OPT_WITH_SFCGAL = 0;
my $OPT_EXPECT = 0;
my $OPT_EXTENSIONS = 0;
+my @OPT_HOOK_AFTER_CREATE;
+my @OPT_HOOK_BEFORE_UNINSTALL;
+my @OPT_HOOK_BEFORE_UPGRADE;
+my @OPT_HOOK_AFTER_UPGRADE;
my $OPT_EXTVERSION = '';
my $OPT_UPGRADE_PATH = '';
our $OPT_UPGRADE_FROM = '';
my $OPT_UPGRADE_TO = '';
-my $VERBOSE = 0;
-my $OPT_SCHEMA = 'public';
+our $VERBOSE = 0;
+our $OPT_SCHEMA = 'public';
GetOptions (
'verbose' => \$VERBOSE,
@@ -80,12 +90,17 @@ GetOptions (
'upgrade-path=s' => \$OPT_UPGRADE_PATH,
'dumprestore' => \$OPT_DUMPRESTORE,
'nocreate' => \$OPT_NOCREATE,
+ 'tiger' => \$OPT_WITH_TIGER,
'topology' => \$OPT_WITH_TOPO,
'raster' => \$OPT_WITH_RASTER,
'sfcgal' => \$OPT_WITH_SFCGAL,
'expect' => \$OPT_EXPECT,
'extensions' => \$OPT_EXTENSIONS,
- 'schema=s' => \$OPT_SCHEMA
+ 'schema=s' => \$OPT_SCHEMA,
+ 'after-create-script=s' => \@OPT_HOOK_AFTER_CREATE,
+ 'before-uninstall-script=s' => \@OPT_HOOK_BEFORE_UNINSTALL,
+ 'before-upgrade-script=s' => \@OPT_HOOK_BEFORE_UPGRADE,
+ 'after-upgrade-script=s' => \@OPT_HOOK_AFTER_UPGRADE
if ( @ARGV < 1 )
@@ -95,10 +110,6 @@ if ( @ARGV < 1 )
if ( $OPT_UPGRADE_PATH )
- if ( ! $OPT_EXTENSIONS )
- die "--upgrade-path is only supported with --extension"
$OPT_UPGRADE = 1; # implied
my @path = split ('--', $OPT_UPGRADE_PATH);
$OPT_UPGRADE_FROM = $path[0]
@@ -142,7 +153,7 @@ $ENV{"PGOPTIONS"} = $PGOPTIONS;
my $PATH = $ENV{"PATH"}; # this is useless
# Calculate the regression directory locations
-my $STAGED_INSTALL_DIR = $REGDIR . "/00-regress-install";
+my $STAGED_INSTALL_DIR = $TOP_BUILDDIR . "/regress/00-regress-install";
my $STAGED_SCRIPTS_DIR = $STAGED_INSTALL_DIR . "/share/contrib/postgis";
my $OBJ_COUNT_PRE = 0;
@@ -164,7 +175,8 @@ foreach my $exec ( ($SHP2PGSQL, $PGSQL2SHP) )
else
print "failed\n";
- die "Unable to find $exec executable.\n";
+ print STDERR "Unable to find $exec executable.\n";
+ die "HINT: set POSTGIS_TOP_BUILD_DIR env variable to the build dir.\n";
@@ -213,7 +225,13 @@ print "TMPDIR is $TMPDIR\n";
# Prepare the database
-my @dblist = grep(/\b$DB\b/, split(/\n/, `psql -Xl`));
+my @dblist = grep(/1/, split(/\n/, `
+psql -tAc "
+ SELECT 1 FROM pg_catalog.pg_database
+ WHERE datname = '${DB}'
+" template1
my $dbcount = @dblist;
if ( $dbcount == 0 )
@@ -243,6 +261,7 @@ else
+my $pgvernum = sql("SELECT current_setting('server_version_num')");
my $libver = sql("select postgis_lib_version()");
my $defextver = sql("select default_version from pg_available_extensions where name = 'postgis'");
@@ -287,114 +306,15 @@ sub semver_lessthan
return @bcomp ? 1 : 0;
-sub create_upgrade_test_objects
- # TODO: allow passing the "upgrade-init" script via commandline
- my $query = "create table upgrade_test(g1 geometry, g2 geography";
- $query .= ", r raster" if ( $OPT_WITH_RASTER );
- $query .= ")";
- my $ret = sql($query);
- unless ( $ret =~ /^CREATE/ ) {
- `dropdb $DB`;
- print "\nSomething went wrong creating upgrade_test table: $ret.\n";
- exit(1);
- $query = "insert into upgrade_test(g1,g2) values ";
- $query .= "('POINT(0 0)', 'LINESTRING(0 0, 1 1)'), ";
- $query .= "('POINT(1 0)', 'LINESTRING(0 1, 1 1)');";
- unless ( $ret =~ /^INSERT/ ) {
- `dropdb $DB`;
- print "\nSomething went wrong populating upgrade_test table: $ret.\n";
- exit(1);
- # my $query = "create view upgrade_view_test as ";
- # $query .= "select st_union(g1) from upgrade_test;";
- # my $ret = sql($query);
- # unless ( $ret =~ /^CREATE/ ) {
- # `dropdb $DB`;
- # print "\nSomething went wrong creating upgrade_view_test view: $ret.\n";
- # exit(1);
- if ( $OPT_WITH_RASTER )
- $query = "UPDATE upgrade_test SET r = ";
- $query .= " ST_AddBand(ST_MakeEmptyRaster(10, 10, 1, 1, 2, 2, 0, 0,4326), 1, '8BSI'::text, -129, NULL);";
- $ret = sql($query);
- unless ( $ret =~ /^UPDATE/ ) {
- `dropdb $DB`;
- print "\nSomething went wrong setting raster into upgrade_test table: $ret.\n";
- exit(1);
- $query = "set client_min_messages to error; select AddRasterConstraints('upgrade_test', 'r')";
- unless ( $ret =~ /^t$/ ) {
- `dropdb $DB`;
- print "\nSomething went wrong adding raster constraints to upgrade_test: " . $ret . "\n";
- exit(1);
- if ( $OPT_WITH_TOPO )
- $query = "select topology.createTopology('upgrade_test');";
- unless ( $ret =~ /^[1-9][0-9]*$/ ) {
- `dropdb $DB`;
- print "\nSomething went wrong adding upgrade_test topology: " . $ret . "\n";
- exit(1);
- # Break current binary postgis functions
- $query = "UPDATE pg_proc SET probin = probin || '-uninstalled' WHERE probin like '%postgis%'";
- `dropdb $DB`;
- print "\nSomething went wrong breaking postgis funx probin: $ret.\n";
- exit(1);
-sub drop_upgrade_test_objects
- # TODO: allow passing the "upgrade-cleanup" script via commandline
- # my $ret = sql("drop view upgrade_view_test;");
- # unless ( $ret =~ /^DROP/ ) {
- # `dropdb $DB`;
- # print "\nSomething went wrong dropping spatial view: $ret.\n";
- # exit(1);
- my $ret = sql("drop table upgrade_test;");
- unless ( $ret =~ /^DROP/ ) {
- `dropdb $DB`;
- print "\nSomething went wrong dropping spatial tables: $ret.\n";
- exit(1);
- my $query = "SELECT topology.DropTopology('upgrade_test');";
- unless ( $ret =~ /^Topology 'upgrade_test' dropped$/ ) {
- `dropdb $DB`;
- print "\nSomething went wrong dropping upgrade_test topology: " . $ret . "\n";
- exit(1);
if ( $OPT_UPGRADE )
- create_upgrade_test_objects();
+ print "Upgrading from postgis $libver\n";
+ foreach my $hook (@OPT_HOOK_BEFORE_UPGRADE)
+ print "Running before-upgrade-script $hook\n";
+ die unless load_sql_file($hook, 1);
if ( $OPT_EXTENSIONS )
@@ -405,7 +325,11 @@ if ( $OPT_UPGRADE )
upgrade_spatial();
- drop_upgrade_test_objects();
+ foreach my $hook (@OPT_HOOK_AFTER_UPGRADE)
+ print "Running after-upgrade-script $hook\n";
# Update libver
@@ -423,17 +347,20 @@ if ( $OPT_DUMPRESTORE )
my $geosver = sql("select postgis_geos_version()");
my $projver = sql("select postgis_proj_version()");
-my $svnrev = sql("select postgis_svn_version()");
my $libbuilddate = sql("select postgis_lib_build_date()");
my $pgsqlver = sql("select version()");
my $gdalver = sql("select postgis_gdal_version()") if $OPT_WITH_RASTER;
my $sfcgalver = sql("select postgis_sfcgal_version()") if $OPT_WITH_SFCGAL;
my $scriptver = sql("select postgis_scripts_installed()");
+# postgis_lib_revision was introduced in 3.1.0
+my $librev = semver_lessthan($scriptver, "3.1.0") ?
+ sql("select postgis_svn_version()") :
+ sql("select postgis_lib_revision()");
my $raster_scriptver = sql("select postgis_raster_scripts_installed()")
print "$pgsqlver\n";
-print " Postgis $libver - r${svnrev} - $libbuilddate\n";
+print " Postgis $libver - (${librev}) - $libbuilddate\n";
print " scripts ${scriptver}\n";
print " raster scripts ${raster_scriptver}\n" if ( $OPT_WITH_RASTER );
print " GEOS: $geosver\n" if $geosver;
@@ -456,10 +383,37 @@ our $TEST = "";
print "\nRunning tests\n\n";
+foreach my $hook (@OPT_HOOK_AFTER_CREATE)
+ start_test("after-create-script $hook");
+ show_progress();
+ pass() if load_sql_file($hook, 1);
foreach $TEST (@ARGV)
my $TEST_OBJ_COUNT_PRE;
my $TEST_OBJ_COUNT_POST;
+ my $TEST_START_TIME;
+ if ( "${TEST}" eq '-' )
+ my $scriptdir = scriptdir($libver, $OPT_EXTENSIONS);
+ print "-- Entering interactive shell --\n";
+ # TODO: add more variables?
+ my $cmd = "psql -Xq"
+ . " -v \"regdir=$REGDIR\""
+ . " -v \"top_builddir=$TOP_BUILDDIR\""
+ . " -v \"scriptdir=$scriptdir\""
+ . " -v \"schema=$OPT_SCHEMA.\""
+ # TODO: inject search_path somehow
+ #. " -c \"SET search_path TO public,$OPT_SCHEMA,topology\""
+ . " ${DB}"
+ my $rv = system($cmd);
+ print "-- Moving on with tests, if any --\n";
+ next;
# catch a common mistake (strip trailing .sql)
$TEST =~ s/.sql$//;
@@ -468,7 +422,12 @@ foreach $TEST (@ARGV)
$TEST_OBJ_COUNT_PRE = count_postgis_objects();
# Check for a "-pre.pl" file in case there are setup commands
- eval_file("${TEST}-pre.pl");
+ unless ( eval_file("${TEST}-pre.pl") )
+ chop($@);
+ fail("Failed evaluating ${TEST}-pre.pl: $@");
+ next;
# Check for a "-pre.sql" file in case there is setup SQL needed before
# the test can be run.
@@ -482,23 +441,37 @@ foreach $TEST (@ARGV)
# create the .sql
# Check for .dbf not just .shp since the loader can load
# .dbf files without a .shp.
+ $TEST_START_TIME = time;
if ( -r "${TEST}.dbf" )
- pass() if ( run_loader_test() );
+ pass("in ".int(1000*(time-$TEST_START_TIME))." ms") if ( run_loader_test() );
elsif ( -r "${TEST}.tif" )
- my $rv = run_raster_loader_test();
- pass() if $rv;
+ my $rv = run_raster_loader_test("${TEST}.tif");
+ pass("in ".int(1000*(time-$TEST_START_TIME))." ms") if $rv;
+ elsif ( -r "${TEST}.tif.ref" )
+ open(REF, "${TEST}.tif.ref");
+ my $raster_ref = <REF>;
+ close(REF);
+ chop $raster_ref;
+ #print "Raster ref: [$raster_ref]\n";
+ # Resolve raster_ref relative to ${TEST} dirname
+ my $raster_path = dirname(${TEST}) . '/' . $raster_ref;
+ #print "Raster path: [$raster_path]\n";
+ my $rv = run_raster_loader_test($raster_path);
elsif ( -r "${TEST}.sql" )
my $rv = run_simple_test("${TEST}.sql", "${TEST}_expected");
- pass() if $rv;
elsif ( -r "${TEST}.dmp" )
- pass() if run_dumper_test();
+ pass("in ".int(1000*(time-$TEST_START_TIME))." ms") if run_dumper_test();
else
@@ -518,18 +491,24 @@ foreach $TEST (@ARGV)
# Check for a "-post.pl" file in case there are teardown commands
- eval_file("${TEST}-post.pl");
+ eval_file("${TEST}-post.pl");
$TEST_OBJ_COUNT_POST = count_postgis_objects();
if ( $TEST_OBJ_COUNT_POST != $TEST_OBJ_COUNT_PRE )
fail("PostGIS object count pre-test ($TEST_OBJ_COUNT_POST) != post-test ($TEST_OBJ_COUNT_PRE)");
- return 0;
+foreach my $hook (@OPT_HOOK_BEFORE_UNINSTALL)
+ start_test("before-uninstall-script $hook");
+ show_progress();
# Uninstall postgis (serves as an uninstall test)
@@ -559,7 +538,6 @@ if ( $OPT_CLEAN )
if ( ! ($OPT_NODROP || $OPT_NOCREATE) )
- sleep(1);
system("dropdb $DB");
else
@@ -592,17 +570,32 @@ Options:
to specify a script version to start from.
<to> can be specified as ":auto" to request
upgrades to default version, and be appended
- a question mark (ie: ":auto!" or "3.0.0!") to
+ an exclamation mark (ie: ":auto!" or "3.0.0!") to
request upgrade via postgis_extensions_upgrade()
if available.
--dumprestore dump and restore spatially-enabled db before running tests
--nodrop do not drop the regression database on exit
+ --schema where to install/find PostGIS (relocatable) PostGIS
+ (defaults to "public")
--raster load also raster extension
+ --tiger load also tiger_geocoder extension
--topology load also topology extension
--sfcgal use also sfcgal backend
--clean cleanup test logs on exit
--expect save obtained output as expected
--extension load using extensions
+ --after-create-script <path>
+ script to load after spatial db creation
+ (multiple switches supported, to be run in given order)
+ --before-uninstall-script <path>
+ script to load before spatial extension uninstall
+ --before-upgrade-script <path>
+ script to load before upgrade
+ --after-upgrade-script <path>
+ script to load after upgrade
@@ -632,8 +625,8 @@ sub show_progress
# pass <msg>
sub pass
- my $msg = shift;
- printf(" ok %s\n", $msg);
+ my $msg = shift;
+ printf(" ok %s\n", $msg);
# fail <msg> <log>
@@ -682,7 +675,10 @@ sub run_simple_sql
# Dump output to a temp file.
my $tmpfile = sprintf("%s/test_%s_tmp", $TMPDIR, $RUN);
- my $cmd = "psql -v \"VERBOSITY=terse\" -tXAq $DB < $sql > $tmpfile 2>&1";
+ my $cmd = "psql -v \"VERBOSITY=terse\" "
+ . " -tXAq $DB < $sql > $tmpfile 2>&1";
#print($cmd);
# Check if psql errored out.
@@ -719,7 +715,7 @@ sub drop_table
sub sql
my $sql = shift;
- my $result = `psql -tXA -d $DB -c "$sql"`;
+ my $result = `psql -tXA -d $DB -c 'SET search_path TO public,$OPT_SCHEMA' -c "$sql" | sed '/^SET\$/d'`;
$result =~ s/[\n\r]*$//;
$result;
@@ -730,12 +726,10 @@ sub eval_file
my $pl;
if ( -r $file )
- #open(PL, $file);
- #$pl = <PL>;
- #close(PL);
- #eval($pl);
- do $file;
+ do $file or return 0;
+ #system($^X, $file) == 0 or return 0;
+ 1;
@@ -775,13 +769,21 @@ sub run_simple_test
chmod 0777, $betmpdir;
- my $cmd = "psql -v \"VERBOSITY=terse\""
+ my ($sqlfile,$sqldir) = fileparse($sql);
+ my $cmd = "cd $sqldir; psql -v \"VERBOSITY=terse\""
. " -v \"tmpfile='$tmpfile'\""
- . " -tXAq $DB < $sql > $outfile 2>&1";
+ . " -c \"SET search_path TO public,$OPT_SCHEMA,topology\""
+ . " -tXAq -f $sqlfile $DB > $outfile 2>&1";
+ if ( $rv ) {
+ fail "psql exited with an error", $outfile;
+ die;
# Check for ERROR lines
open(FILE, "$outfile");
@@ -790,7 +792,7 @@ sub run_simple_test
# Strip the lines we don't care about
@lines = grep(!/^\$/, @lines);
- @lines = grep(!/^(INSERT|DELETE|UPDATE|SELECT|COPY|DO)/, @lines);
+ @lines = grep(!/^(INSERT|DELETE|UPDATE|SELECT [0-9]*|COPY|DO)$/, @lines);
@lines = grep(!/^(CONTEXT|RESET|ANALYZE)/, @lines);
@lines = grep(!/^(DROP|CREATE|ALTER|VACUUM)/, @lines);
@lines = grep(!/^(LOG|SET|TRUNCATE|DISCARD)/, @lines);
@@ -997,6 +999,7 @@ sub run_dumper_and_check_output
sub run_raster_loader_and_check_output
my $description = shift;
+ my $raster_file = shift;
my $tblname = shift;
my $expected_sql_file = shift;
my $expected_select_results_file = shift;
@@ -1015,7 +1018,7 @@ sub run_raster_loader_and_check_output
show_progress();
# Produce the output SQL file.
- $cmd = "$RASTER2PGSQL $loader_options ${TEST}.tif $tblname > $outfile 2> $errfile";
+ $cmd = "$RASTER2PGSQL $loader_options $raster_file $tblname > $outfile 2> $errfile";
$rv = system($cmd);
if ( $rv )
@@ -1076,10 +1079,14 @@ sub run_loader_test
if ( -r $opts_file )
open(FILE, $opts_file);
- my @opts = <FILE>;
+ my @opts;
+ while (<FILE>) {
+ next if /^\s*#/;
+ chop;
+ s/{regdir}/$REGDIR/;
+ push @opts, $_;
close(FILE);
- @opts = grep(!/^\s*#/, @opts);
- map(s/\n//, @opts);
$custom_opts = join(" ", @opts);
@@ -1088,6 +1095,7 @@ sub run_loader_test
# If we have some expected files to compare with, run in wkt mode.
if ( ! run_loader_and_check_output("wkt test", $tblname, "${TEST}-w.sql.expected", "${TEST}-w.select.expected", "-w $custom_opts") )
+ drop_table($tblname) unless $OPT_NODROP;
return 0;
drop_table($tblname);
@@ -1095,11 +1103,13 @@ sub run_loader_test
# If we have some expected files to compare with, run in geography mode.
if ( ! run_loader_and_check_output("geog test", $tblname, "${TEST}-G.sql.expected", "${TEST}-G.select.expected", "-G $custom_opts") )
return 0;
# If we have some expected files to compare with, run the dumper and compare shape files.
if ( ! run_dumper_and_check_output("dumper geog test", $tblname, "${TEST}-G.shp.expected") )
return 0;
@@ -1107,11 +1117,13 @@ sub run_loader_test
# Always run in wkb ("normal") mode, even if there are no expected files to compare with.
if( ! run_loader_and_check_output("wkb test", $tblname, "${TEST}.sql.expected", "${TEST}.select.expected", "$custom_opts", "true") )
return 0;
if( ! run_dumper_and_check_output("dumper wkb test", $tblname, "${TEST}.shp.expected") )
return 0;
@@ -1122,6 +1134,7 @@ sub run_loader_test
# If we have some expected files to compare with, run in wkt dump mode.
if ( ! run_loader_and_check_output("wkt dump test", $tblname, "${TEST}-wD.sql.expected") )
return 0;
@@ -1129,6 +1142,7 @@ sub run_loader_test
if ( ! run_loader_and_check_output("geog dump test", $tblname, "${TEST}-GD.sql.expected") )
return 0;
@@ -1136,6 +1150,7 @@ sub run_loader_test
# If we have some expected files to compare with, run in wkb dump mode.
if ( ! run_loader_and_check_output("wkb dump test", $tblname, "${TEST}-D.sql.expected") )
return 0;
@@ -1150,9 +1165,9 @@ sub run_loader_test
# Run dumper and compare output with various expectances
# test and run simple test with provided expected output.
-# input is ${TEST}.dmp, where last line is considered to be the
-# [table|query] argument for pgsql2shp and all the previous lines,
-# if any are
+# input is ${TEST}.dmp, where first line is considered to be the
+# [table|query] argument for pgsql2shp and all the next lines,
+# if any are options.
sub run_dumper_test
@@ -1168,12 +1183,16 @@ sub run_dumper_test
# Produce the output SHP file.
open DUMPFILE, "$dump_file" or die "Cannot open dump file $dump_file\n";
- sleep(1);
my @dumplines = <DUMPFILE>;
close DUMPFILE;
- my $dumpstring = join '', @dumplines;
- chop($dumpstring);
- my @cmd = ("${PGSQL2SHP}", "-f", ${shpfile}, ${DB}, ${dumpstring});
+ chomp(@dumplines);
+ my $dumpstring = shift @dumplines;
+ @dumplines = map { local $_ = $_; s/{regdir}/$REGDIR/; $_ } @dumplines;
+ my @cmd = ("${PGSQL2SHP}", "-f", ${shpfile});
+ push @cmd, @dumplines;
+ push @cmd, ${DB};
+ push @cmd, $dumpstring;
+ #print "CMD: " . join (' ', @cmd) . "\n";
open my $stdout_save, '>&', *STDOUT or die "Cannot dup stdout\n";
open my $stderr_save, '>&', *STDERR or die "Cannot dup stdout\n";
open STDOUT, ">${outfile}" or die "Cannot write to ${outfile}\n";
@@ -1181,7 +1200,6 @@ sub run_dumper_test
my $rv = system(@cmd);
open STDERR, '>&', $stderr_save;
open STDOUT, '>&', $stdout_save;
- #sleep(3);
show_progress();
if ( $rv )
@@ -1233,24 +1251,30 @@ sub run_dumper_test
sub run_raster_loader_test
# See if there is a custom command-line options file
my $opts_file = "${TEST}.opts";
my $custom_opts="";
+ my $regdir = abs_path(dirname(${TEST}));
+ my @opts;
+ while (<FILE>) {
+ next if /^\s*#/;
+ chop;
+ s/{regdir}/$regdir/;
+ push @opts, $_;
close(FILE);
my $tblname="loadedrast";
- if ( ! run_raster_loader_and_check_output("test", $tblname, "${TEST}.sql.expected", "${TEST}.select.expected", $custom_opts, "true") )
+ if ( ! run_raster_loader_and_check_output("test", $raster_file, $tblname, "${TEST}.sql.expected", "${TEST}.select.expected", $custom_opts, "true") )
return 0;
@@ -1274,7 +1298,9 @@ sub count_db_objects
select count(*) from pg_operator union all
select count(*) from pg_opclass union all
select count(*) from pg_namespace
- where nspname NOT LIKE 'pg_%' union all
+ where nspname NOT LIKE 'pg_%'
+ and nspname != '${OPT_SCHEMA}'
+ union all
select count(*) from pg_opfamily
select sum(count) from counts");
@@ -1309,22 +1335,37 @@ sub create_db
sub create_spatial
- my ($cmd, $rv);
- print "Creating database '$DB' \n";
+ my ($cmd, $rv);
+ print "Creating database '$DB' \n";
- $rv = create_db();
+ $rv = create_db();
- # Count database objects before installing anything
- $OBJ_COUNT_PRE = count_db_objects();
+ # Count database objects before installing anything
+ $OBJ_COUNT_PRE = count_db_objects();
- if ( $OPT_EXTENSIONS )
- prepare_spatial_extensions();
- else
- prepare_spatial();
+ if ( $OPT_EXTENSIONS )
+ prepare_spatial_extensions();
+ else
+ if ( ! $OPT_UPGRADE_FROM )
+ prepare_spatial();
+ return;
+ if ( $OPT_UPGRADE_FROM !~ /^unpackaged(.*)/ )
+ die "--upgrade-path without --extension is only supported with source unpackaged*";
+ if ( $OPT_UPGRADE_TO != ':auto' )
+ die "--upgrade-path without --extension is only supported with target :auto";
+ prepare_spatial($1);
@@ -1335,20 +1376,24 @@ sub load_sql_file
if ( $strict && ! -e $file )
- die "Unable to find $file\n";
+ fail "Unable to find $file";
+ return 0;
if ( -e $file )
# ON_ERROR_STOP is used by psql to return non-0 on an error
my $psql_opts = "--no-psqlrc --variable ON_ERROR_STOP=true";
- my $cmd = "psql $psql_opts -Xf $file $DB >> $REGRESS_LOG 2>&1";
- print " $file\n" if $VERBOSE;
+ my $cmd = "psql $psql_opts -c 'CREATE SCHEMA IF NOT EXISTS $OPT_SCHEMA' ";
+ $cmd .= "-c 'SET search_path TO $OPT_SCHEMA,topology'";
+ $cmd .= " -Xf $file $DB >> $REGRESS_LOG 2>&1";
+ #print " $file\n" if $VERBOSE;
if ( $rv )
fail "Error encountered loading $file", $REGRESS_LOG;
- exit 1;
+ #exit 1;
+ return 0;
return 1;
@@ -1359,6 +1404,15 @@ sub prepare_spatial_extensions
+ my $sql = "CREATE SCHEMA IF NOT EXISTS ${OPT_SCHEMA}";
+ my $cmd = "psql $psql_opts -c \"". $sql . "\" $DB >> $REGRESS_LOG 2>&1";
+ if ( $rv ) {
+ fail "Error encountered creating target schema ${OPT_SCHEMA}", $REGRESS_LOG;
+ die;
my $sql = "CREATE EXTENSION postgis";
if ( $OPT_UPGRADE_FROM ) {
@@ -1369,6 +1423,8 @@ sub prepare_spatial_extensions
$sql .= " VERSION '" . $OPT_UPGRADE_FROM . "'";
+ $sql .= " SCHEMA " . $OPT_SCHEMA;
print "Preparing db '${DB}' using: ${sql}\n";
@@ -1396,6 +1452,23 @@ sub prepare_spatial_extensions
+ if ( $OPT_WITH_TIGER )
+ my $sql = "CREATE EXTENSION postgis_tiger_geocoder CASCADE";
+ if ( $OPT_UPGRADE_FROM ) {
+ $sql .= " VERSION '" . $OPT_UPGRADE_FROM . "'";
+ print "Preparing db '${DB}' using: ${sql}\n";
+ $cmd = "psql $psql_opts -c \"" . $sql . "\" $DB >> $REGRESS_LOG 2>&1";
+ $rv = system($cmd);
+ if ( $rv ) {
+ fail "Error encountered creating EXTENSION POSTGIS_TIGER_GEOCODER", $REGRESS_LOG;
+ die;
if ( $OPT_WITH_RASTER && (
# NOTE: this code is assuming that the default version
# (!$OPT_UPGRADE_FROM) has split raster extension
@@ -1408,6 +1481,8 @@ sub prepare_spatial_extensions
@@ -1432,6 +1507,8 @@ sub prepare_spatial_extensions
@@ -1458,7 +1535,6 @@ sub prepare_spatial
# Load postgis.sql into the database
load_sql_file("${scriptdir}/postgis.sql", 1);
load_sql_file("${scriptdir}/postgis_comments.sql", 0);
- load_sql_file("${scriptdir}/postgis_proc_set_search_path.sql", 0);
load_sql_file("${scriptdir}/spatial_ref_sys.sql", 0);
@@ -1473,7 +1549,6 @@ sub prepare_spatial
print "Loading Raster into '${DB}'\n";
load_sql_file("${scriptdir}/rtpostgis.sql", 1);
load_sql_file("${scriptdir}/raster_comments.sql", 0);
- load_sql_file("${scriptdir}/rtpostgis_proc_set_search_path.sql", 0);
if ( $OPT_WITH_SFCGAL )
@@ -1486,67 +1561,48 @@ sub prepare_spatial
return 1;
+sub package_extension_sql
+ my ($extname, $extver) = @_;
+ my $sql;
+ if ( $pgvernum lt 130000 ) {
+ $sql = "CREATE EXTENSION ${extname} VERSION '${extver}' FROM unpackaged;";
+ } else {
+ $sql = "CREATE EXTENSION ${extname} VERSION unpackaged;";
+ $sql .= "ALTER EXTENSION ${extname} UPDATE TO '${extver}'";
+ return $sql;
# Upgrade an existing database (soft upgrade)
sub upgrade_spatial
print "Upgrading PostGIS in '${DB}' \n" ;
- my $script = `ls ${STAGED_SCRIPTS_DIR}/postgis_upgrade.sql`;
- chomp($script);
- if ( -e $script )
- print "Upgrading core\n";
- load_sql_file($script);
- else
- die "$script not found\n";
+ my $script = "${STAGED_SCRIPTS_DIR}/postgis_upgrade.sql";
+ print "Upgrading core\n";
+ die unless load_sql_file($script, 1);
- my $script = `ls ${STAGED_SCRIPTS_DIR}/topology_upgrade.sql`;
- chomp($script);
- if ( -e $script )
- print "Upgrading topology\n";
- else
+ $script = "${STAGED_SCRIPTS_DIR}/topology_upgrade.sql";
+ print "Upgrading topology\n";
- my $script = `ls ${STAGED_SCRIPTS_DIR}/rtpostgis_upgrade.sql`;
- chomp($script);
- if ( -e $script )
- print "Upgrading raster\n";
- else
+ $script = "${STAGED_SCRIPTS_DIR}/rtpostgis_upgrade.sql";
+ print "Upgrading raster\n";
- my $script = `ls ${STAGED_SCRIPTS_DIR}/sfcgal_upgrade.sql`;
- chomp($script);
- if ( -e $script )
- print "Upgrading sfcgal\n";
- else
+ $script = "${STAGED_SCRIPTS_DIR}/sfcgal_upgrade.sql";
+ print "Upgrading sfcgal\n";
return 1;
@@ -1590,7 +1646,7 @@ sub upgrade_spatial_extensions
elsif ( $OPT_UPGRADE_FROM =~ /^unpackaged/ )
- $sql = "CREATE EXTENSION postgis VERSION '${nextver}' FROM unpackaged";
+ $sql = package_extension_sql('postgis', ${nextver});
else
@@ -1603,7 +1659,7 @@ sub upgrade_spatial_extensions
#print "CMD: " . $cmd . "\n";
if ( $rv ) {
- fail "Error encountered altering EXTENSION POSTGIS", $REGRESS_LOG;
+ fail "Error encountered updating EXTENSION POSTGIS", $REGRESS_LOG;
die;
@@ -1616,7 +1672,7 @@ sub upgrade_spatial_extensions
# upgrade of postgis must have unpackaged raster, so
# we create it again here
- my $sql = "CREATE EXTENSION postgis_raster VERSION '${nextver}' FROM unpackaged";
+ my $sql = package_extension_sql('postgis_raster', ${nextver});
print "Upgrading PostGIS Raster in '${DB}' using: ${sql}\n" ;
@@ -1633,7 +1689,8 @@ sub upgrade_spatial_extensions
# left unpackaged
print "Packaging PostGIS Raster in '${DB}' for later drop using: ${sql}\n" ;
- $sql = "CREATE EXTENSION postgis_raster VERSION '${nextver}' FROM unpackaged";
+ $sql = package_extension_sql('postgis_raster', ${nextver});
$rv = system($cmd);
if ( $rv ) {
@@ -1664,7 +1721,7 @@ sub upgrade_spatial_extensions
my $sql = "ALTER EXTENSION postgis_raster UPDATE TO '${nextver}'";
if ( $OPT_UPGRADE_FROM =~ /^unpackaged/ ) {
@@ -1672,7 +1729,7 @@ sub upgrade_spatial_extensions
my $cmd = "psql $psql_opts -c \"" . $sql . "\" $DB >> $REGRESS_LOG 2>&1";
if ( $rv ) {
- fail "Error encountered altering EXTENSION POSTGIS_RASTER", $REGRESS_LOG;
+ fail "Error encountered updating EXTENSION POSTGIS_RASTER", $REGRESS_LOG;
die;
@@ -1682,7 +1739,7 @@ sub upgrade_spatial_extensions
my $sql = "ALTER EXTENSION postgis_topology UPDATE TO '${nextver}'";
- $sql = "CREATE EXTENSION postgis_topology VERSION '${nextver}' FROM unpackaged";
+ $sql = package_extension_sql('postgis_topology', ${nextver});
print "Upgrading PostGIS Topology in '${DB}' using: ${sql}\n";
@@ -1690,7 +1747,7 @@ sub upgrade_spatial_extensions
if ( $rv ) {
- fail "Error encountered altering EXTENSION POSTGIS_TOPOLOGY", $REGRESS_LOG;
+ fail "Error encountered updating EXTENSION POSTGIS_TOPOLOGY", $REGRESS_LOG;
die;
@@ -1700,7 +1757,7 @@ sub upgrade_spatial_extensions
my $sql;
- $sql = "CREATE EXTENSION postgis_sfcgal VERSION '${nextver}' FROM unpackaged";
+ $sql = package_extension_sql('postgis_sfcgal', ${nextver});
elsif ( $OPT_UPGRADE_FROM && semver_lessthan($OPT_UPGRADE_FROM, "2.2.0") )
@@ -1777,6 +1834,16 @@ sub drop_spatial_extensions
$rv = system($cmd);
$ok = 0 if $rv;
+ $cmd = "psql $psql_opts -c \"DROP EXTENSION IF EXISTS postgis_tiger_geocoder;
+ DROP EXTENSION IF EXISTS fuzzystrmatch;
+ DROP SCHEMA IF EXISTS tiger;
+ DROP SCHEMA IF EXISTS tiger_data;
+ \" $DB >> $REGRESS_LOG 2>&1";
+ $ok = 0 if $rv;
$cmd = "psql $psql_opts -c \"DROP EXTENSION postgis\" $DB >> $REGRESS_LOG 2>&1";
$rv = system($cmd);
@@ -1792,6 +1859,7 @@ sub drop_spatial_extensions
sub uninstall_spatial
my $ok;
start_test("uninstall");
@@ -1803,24 +1871,19 @@ sub uninstall_spatial
$ok = drop_spatial();
- if ( $ok )
- show_progress(); # on to objects count
- $OBJ_COUNT_POST = count_db_objects();
+ return $ok if ! $ok;
- if ( $OBJ_COUNT_POST != $OBJ_COUNT_PRE )
- fail("Object count pre-install ($OBJ_COUNT_PRE) != post-uninstall ($OBJ_COUNT_POST)");
- return 0;
- else
- pass("($OBJ_COUNT_PRE)");
- return 1;
+ show_progress(); # on to objects count
+ $OBJ_COUNT_POST = count_db_objects();
+ if ( $OBJ_COUNT_POST != $OBJ_COUNT_PRE )
+ fail("Object count pre-install ($OBJ_COUNT_PRE) != post-uninstall ($OBJ_COUNT_POST)");
+ return 0;
- return 0;
+ pass("($OBJ_COUNT_PRE)");
+ return 1;
# Dump and restore the database
Summary of changes:
regress/run_test.pl | 563 +++++++++++++++++++++++++++++-----------------------
1 file changed, 313 insertions(+), 250 deletions(-)
hooks/post-receive
