[postgis-tickets] [PostGIS] #4777: core tests are using \copy with hard-coded relative paths
PostGIS trac at osgeo.org
Fri Aug 12 02:58:12 PDT 2022
  Reporter:  strk                   |      Owner:  strk
      Type:  defect                 |     Status:  closed
  Priority:  medium                 |  Milestone:  PostGIS 3.1.0
 Component:  build/upgrade/install  |    Version:  2.5.x
Resolution:  fixed                  |   Keywords:
Comment (by Sandro Santilli <strk@…>):
 In [changeset:"3c7e31fd5f3ba3d98dc88afcc69c982a4486a081/git" 3c7e31f/git]:
 {{{#!CommitTicketReference repository="git"
 revision="3c7e31fd5f3ba3d98dc88afcc69c982a4486a081"
 Use relative paths in topology tests
 References #4777 in 3.0 branch (3.0.7dev)
 Should fix regression test broken by upgrading of
 run_test.pl in commit a0c29068d
Ticket URL: <https://trac.osgeo.org/postgis/ticket/4777#comment:5>
