[postgis-tickets] [PostGIS] #4777: core tests are using \copy with hard-coded relative paths
PostGIS trac at osgeo.org
Fri Aug 12 03:44:45 PDT 2022
  Reporter:  strk                   |      Owner:  strk
      Type:  defect                 |     Status:  closed
  Priority:  medium                 |  Milestone:  PostGIS 3.1.0
 Component:  build/upgrade/install  |    Version:  2.5.x
Resolution:  fixed                  |   Keywords:
Comment (by Sandro Santilli <strk@…>):
 In [changeset:"4a78ce4e94e1f4982e42cec6f66645e20b59c87e/git" 4a78ce4/git]:
 {{{#!CommitTicketReference repository="git"
 revision="4a78ce4e94e1f4982e42cec6f66645e20b59c87e"
 Use relative paths in topology tests
 References #4777 in 2.5 branch (2.5.8dev)
 Should fix regression test broken by upgrading of
 run_test.pl in commit 35b17931f
Ticket URL: <https://trac.osgeo.org/postgis/ticket/4777#comment:6>
