[postgis-tickets] [SCM] PostGIS branch stable-2.5 updated. 2.5.7-10-g4a78ce4e9
Fri Aug 12 03:44:36 PDT 2022
the project "PostGIS".
The branch, stable-2.5 has been updated
       via  4a78ce4e94e1f4982e42cec6f66645e20b59c87e (commit)
       via  85d0c00ecc13c61e05b3c3fc1c5a482ff77ae8ec (commit)
       via  4bdfea50cd2cc5450a57ed5ae91d136adaaef55c (commit)
      from  ca3fccb94f03b1fac17e7398ecba39d602404e7c (commit)
revisions in full, below.
commit 4a78ce4e94e1f4982e42cec6f66645e20b59c87e
Author: Sandro Santilli <strk at kbt.io>
Date:   Wed Oct 28 22:12:55 2020 +0100
    Use relative paths in topology tests
    References #4777 in 2.5 branch (2.5.8dev)
    Should fix regression test broken by upgrading of
    run_test.pl in commit 35b17931f
diff --git a/topology/test/regress/cleartopogeom.sql b/topology/test/regress/cleartopogeom.sql
index e3697dbe5..6f27f7649 100644
--- a/topology/test/regress/cleartopogeom.sql
+++ b/topology/test/regress/cleartopogeom.sql
@@ -1,8 +1,8 @@
 \set VERBOSITY terse
 set client_min_messages to ERROR;
-\i load_topology.sql
-\i load_features.sql
+\i ../load_topology.sql
+\i ../load_features.sql
 SELECT 'relation before', count(distinct topogeo_id)
  FROM city_data.relation
diff --git a/topology/test/regress/copytopology.sql b/topology/test/regress/copytopology.sql
index 1703a1d4f..61c2fae21 100644
--- a/topology/test/regress/copytopology.sql
+++ b/topology/test/regress/copytopology.sql
@@ -1,8 +1,8 @@
 set client_min_messages to WARNING;
-\i load_topology-4326.sql
-\i more_features.sql
+\i ../load_topology-4326.sql
+\i ../more_features.sql
 SELECT topology.CopyTopology('city_data', 'CITY_data_UP_down') > 0;
diff --git a/topology/test/regress/getnodeedges.sql b/topology/test/regress/getnodeedges.sql
index f5f8e3e74..e4198b1a1 100644
--- a/topology/test/regress/getnodeedges.sql
+++ b/topology/test/regress/getnodeedges.sql
@@ -1,6 +1,6 @@
 SELECT 'N'||node_id, (topology.GetNodeEdges('city_data', node_id)).*
 	FROM city_data.node ORDER BY node_id, sequence;
diff --git a/topology/test/regress/getringedges.sql b/topology/test/regress/getringedges.sql
index 20874e5dd..88b4bd4c9 100644
--- a/topology/test/regress/getringedges.sql
+++ b/topology/test/regress/getringedges.sql
@@ -1,6 +1,6 @@
 SELECT 'R'||edge_id, (topology.GetRingEdges('city_data', edge_id)).*
 	FROM city_data.edge;
diff --git a/topology/test/regress/gettopogeomelements.sql b/topology/test/regress/gettopogeomelements.sql
index 5d765ba0c..e3a70afc5 100644
--- a/topology/test/regress/gettopogeomelements.sql
+++ b/topology/test/regress/gettopogeomelements.sql
@@ -1,7 +1,7 @@
 SELECT lid, tid, GetTopoGeomElements('city_data', lid, tid)
 FROM (
diff --git a/topology/test/regress/gml.sql b/topology/test/regress/gml.sql
index 58fcb519e..0582ca7cb 100644
--- a/topology/test/regress/gml.sql
+++ b/topology/test/regress/gml.sql
@@ -1,8 +1,8 @@
 --- Puntual single element {
diff --git a/topology/test/regress/legacy_invalid.sql b/topology/test/regress/legacy_invalid.sql
index 25187f411..bb2f91619 100644
--- a/topology/test/regress/legacy_invalid.sql
+++ b/topology/test/regress/legacy_invalid.sql
@@ -1,6 +1,6 @@
-\i invalid_topology.sql
+\i ../invalid_topology.sql
 -- clean up
 SELECT topology.DropTopology('invalid_topology');
diff --git a/topology/test/regress/legacy_predicate.sql b/topology/test/regress/legacy_predicate.sql
index 567d2f6d7..88ee4da42 100644
--- a/topology/test/regress/legacy_predicate.sql
+++ b/topology/test/regress/legacy_predicate.sql
@@ -1,10 +1,10 @@
-\i hierarchy.sql
-\i topo_predicates.sql
+\i ../hierarchy.sql
+\i ../topo_predicates.sql
 -- clean up
 SELECT topology.DropTopology('city_data');
diff --git a/topology/test/regress/legacy_query.sql b/topology/test/regress/legacy_query.sql
index d0b903d20..21d0fd39e 100644
--- a/topology/test/regress/legacy_query.sql
+++ b/topology/test/regress/legacy_query.sql
@@ -2,11 +2,11 @@ set client_min_messages to WARNING;
 -- Tests TopoGeometry->Geometry cast and id(TopoGeometry)
-\i hierarchy.sql
-\i query_features.sql
+\i ../query_features.sql
 -- clean up
diff --git a/topology/test/regress/legacy_validate.sql b/topology/test/regress/legacy_validate.sql
index d325e706f..1dd8f0428 100644
--- a/topology/test/regress/legacy_validate.sql
+++ b/topology/test/regress/legacy_validate.sql
@@ -1,7 +1,7 @@
-\i validate_topology.sql
+\i ../validate_topology.sql
 -- clean up
diff --git a/topology/test/regress/st_addedgemodface.sql b/topology/test/regress/st_addedgemodface.sql
index 2939c2214..047bd6c45 100644
--- a/topology/test/regress/st_addedgemodface.sql
+++ b/topology/test/regress/st_addedgemodface.sql
@@ -1,6 +1,6 @@
 -- Endpoint / node mismatch
 SELECT topology.ST_AddEdgeModFace('city_data', 7, 6,
diff --git a/topology/test/regress/st_addedgenewfaces.sql b/topology/test/regress/st_addedgenewfaces.sql
index 71cfd994c..db90018b9 100644
--- a/topology/test/regress/st_addedgenewfaces.sql
+++ b/topology/test/regress/st_addedgenewfaces.sql
@@ -1,6 +1,6 @@
 SELECT topology.ST_AddEdgeNewFaces('city_data', 7, 6,
diff --git a/topology/test/regress/st_addisonode.sql b/topology/test/regress/st_addisonode.sql
index 5f97654e0..441387644 100644
--- a/topology/test/regress/st_addisonode.sql
+++ b/topology/test/regress/st_addisonode.sql
@@ -3,7 +3,7 @@ set client_min_messages to WARNING;
 -- Usual city_data input
 -- NULL exceptions
 select ST_AddIsoNode(NULL, 0, 'POINT(1 4)');
diff --git a/topology/test/regress/st_changeedgegeom.sql b/topology/test/regress/st_changeedgegeom.sql
index 757944977..3eff183f7 100644
--- a/topology/test/regress/st_changeedgegeom.sql
+++ b/topology/test/regress/st_changeedgegeom.sql
@@ -1,6 +1,6 @@
 -- good one
 SELECT 'T1', topology.ST_ChangeEdgeGeom('city_data', 25,
diff --git a/topology/test/regress/st_modedgeheal.sql b/topology/test/regress/st_modedgeheal.sql
index 2e86ece49..83229926d 100644
--- a/topology/test/regress/st_modedgeheal.sql
+++ b/topology/test/regress/st_modedgeheal.sql
@@ -2,7 +2,7 @@
 -- Import city_data
 SELECT topology.ST_ModEdgeHeal('city_data', 1, null);
 SELECT topology.ST_ModEdgeHeal('city_data', null, 1);
diff --git a/topology/test/regress/st_modedgesplit.sql b/topology/test/regress/st_modedgesplit.sql
index 2425f18e4..aed4c0b32 100644
--- a/topology/test/regress/st_modedgesplit.sql
+++ b/topology/test/regress/st_modedgesplit.sql
@@ -5,7 +5,7 @@ set client_min_messages to WARNING;
 INSERT INTO spatial_ref_sys ( auth_name, auth_srid, srid, proj4text ) VALUES ( 'EPSG', 4326, 4326, '+proj=longlat +ellps=WGS84 +datum=WGS84 +no_defs' );
 -- Import city_data
 -- Save max node id
 select 'node'::text as what, max(node_id) INTO city_data.limits FROM city_data.node;
diff --git a/topology/test/regress/st_newedgeheal.sql b/topology/test/regress/st_newedgeheal.sql
index c2b74dd76..e49979fe9 100644
--- a/topology/test/regress/st_newedgeheal.sql
+++ b/topology/test/regress/st_newedgeheal.sql
@@ -2,7 +2,7 @@
 -- Import city_data
 SELECT topology.ST_NewEdgeHeal('city_data', 1, null);
 SELECT topology.ST_NewEdgeHeal('city_data', null, 1);
diff --git a/topology/test/regress/st_newedgessplit.sql b/topology/test/regress/st_newedgessplit.sql
index 68b9d8a4f..2e47a5d9a 100644
--- a/topology/test/regress/st_newedgessplit.sql
+++ b/topology/test/regress/st_newedgessplit.sql
@@ -5,7 +5,7 @@ set client_min_messages to ERROR;
 -- Import city_data
 -- Save max node id
diff --git a/topology/test/regress/st_remedgemodface.sql b/topology/test/regress/st_remedgemodface.sql
index 9fb596198..dcdc0eef7 100644
--- a/topology/test/regress/st_remedgemodface.sql
+++ b/topology/test/regress/st_remedgemodface.sql
@@ -4,7 +4,7 @@ set client_min_messages to ERROR;
 -- Import city_data
 -- Utility functions for the test {
@@ -377,9 +377,9 @@ SELECT topology.DropTopology('city_data');
 -- Import city_data
-\i cache_geometries.sql
+\i ../cache_geometries.sql
 -- A city_street is defined by edge 3, can't drop
 SELECT '*RM(3)', topology.ST_RemEdgeModFace('city_data', 3);
diff --git a/topology/test/regress/st_remedgenewface.sql b/topology/test/regress/st_remedgenewface.sql
index ba7c10168..238c12511 100644
--- a/topology/test/regress/st_remedgenewface.sql
+++ b/topology/test/regress/st_remedgenewface.sql
 -- Import city_data
 -- Import city_data
 SELECT '*RN(3)', topology.ST_RemEdgeNewFace('city_data', 3);
diff --git a/topology/test/regress/topogeo_addlinestring.sql b/topology/test/regress/topogeo_addlinestring.sql
index 460229a2c..0bac7183b 100644
--- a/topology/test/regress/topogeo_addlinestring.sql
+++ b/topology/test/regress/topogeo_addlinestring.sql
@@ -1,7 +1,7 @@
 -- Save max node id
diff --git a/topology/test/regress/topogeo_addpoint.sql b/topology/test/regress/topogeo_addpoint.sql
index b7c4f9292..3f7cd3e80 100644
--- a/topology/test/regress/topogeo_addpoint.sql
+++ b/topology/test/regress/topogeo_addpoint.sql
@@ -1,7 +1,7 @@
 -- Invalid calls
 SELECT 'invalid', TopoGeo_addPoint('city_data', 'LINESTRING(36 26, 38 30)');
diff --git a/topology/test/regress/topogeo_addpolygon.sql b/topology/test/regress/topogeo_addpolygon.sql
index f21379fce..68863b0b5 100644
--- a/topology/test/regress/topogeo_addpolygon.sql
+++ b/topology/test/regress/topogeo_addpolygon.sql
@@ -1,7 +1,7 @@
 -- Save max node,edge and face ids
diff --git a/topology/test/regress/topogeometry_type.sql b/topology/test/regress/topogeometry_type.sql
index 05c21fe3e..4da8a3167 100644
--- a/topology/test/regress/topogeometry_type.sql
+++ b/topology/test/regress/topogeometry_type.sql
@@ -1,9 +1,9 @@
-\i hierarchy.sql
 SELECT DISTINCT 'GeometryType(traffic_signs)',
 	geometrytype(feature) FROM features.traffic_signs;
diff --git a/topology/test/regress/topojson.sql b/topology/test/regress/topojson.sql
index 6a0aad4fc..e5ccf1444 100644
--- a/topology/test/regress/topojson.sql
+++ b/topology/test/regress/topojson.sql
@@ -1,8 +1,8 @@
-\i hierarchy.sql
 -- This edges perturbate the topology so that walking around the boundaries
 -- of P1 and P2 may require walking on some of them
commit 85d0c00ecc13c61e05b3c3fc1c5a482ff77ae8ec
Date:   Fri Aug 12 12:31:28 2022 +0200
    Stop using custom SRIDs in tests
    Custom SRIDs are not needed anymore in these tests
    since upgrade of run_test.pl committed in 35b17931f
    (and breaking the testsuite)
    This is a backport of commit aafcb2e8
diff --git a/regress/loader/ReprojectPts-post.sql b/regress/loader/ReprojectPts-post.sql
deleted file mode 100644
index 03ec0db9f..000000000
--- a/regress/loader/ReprojectPts-post.sql
+++ /dev/null
@@ -1,2 +0,0 @@
--- Cleanup
-DELETE FROM spatial_ref_sys;
diff --git a/regress/loader/ReprojectPts-pre.sql b/regress/loader/ReprojectPts-pre.sql
index 20c08f687..000000000
--- a/regress/loader/ReprojectPts-pre.sql
+++ /dev/null
@@ -1,11 +0,0 @@
---- In case this test is running in an extension context
-TRUNCATE spatial_ref_sys;
---- EPSG 4326 : WGS 84
-INSERT INTO "spatial_ref_sys" ("srid","auth_name","auth_srid","srtext","proj4text") VALUES (4326,'EPSG',4326,'GEOGCS["WGS 84",DATUM["WGS_1984",SPHEROID["WGS 84",6378137,298.257223563,AUTHORITY["EPSG","7030"]],AUTHORITY["EPSG","6326"]],PRIMEM["Greenwich",0,AUTHORITY["EPSG","8901"]],UNIT["degree",0.01745329251994328,AUTHORITY["EPSG","9122"]],AUTHORITY["EPSG","4326"]]','+proj=longlat +ellps=WGS84 +datum=WGS84 +no_defs ');
---- EPSG 2260 : NAD83 / New York East (ftUS)
-INSERT INTO "spatial_ref_sys" ("srid","auth_name","auth_srid","srtext","proj4text") VALUES (2260,'EPSG',2260,'PROJCS["NAD83 / New York East (ftUS)",GEOGCS["NAD83",DATUM["North_American_Datum_1983",SPHEROID["GRS 1980",6378137,298.257222101,AUTHORITY["EPSG","7019"]],AUTHORITY["EPSG","6269"]],PRIMEM["Greenwich",0,AUTHORITY["EPSG","8901"]],UNIT["degree",0.01745329251994328,AUTHORITY["EPSG","9122"]],AUTHORITY["EPSG","4269"]],UNIT["US survey foot",0.3048006096012192,AUTHORITY["EPSG","9003"]],PROJECTION["Transverse_Mercator"],PARAMETER["latitude_of_origin",38.83333333333334],PARAMETER["central_meridian",-74.5],PARAMETER["scale_factor",0.9999],PARAMETER["false_easting",492125],PARAMETER["false_northing",0],AUTHORITY["EPSG","2260"],AXIS["X",EAST],AXIS["Y",NORTH]]','+proj=tmerc +lat_0=38.83333333333334 +lon_0=-74.5 +k=0.9999 +x_0=150000 +y_0=0 +ellps=GRS80 +datum=NAD83 +units=us-ft +no_defs ');
diff --git a/regress/loader/ReprojectPtsGeog-post.sql b/regress/loader/ReprojectPtsGeog-post.sql
index 1f3bcbdab..000000000
--- a/regress/loader/ReprojectPtsGeog-post.sql
+++ /dev/null
@@ -1,2 +0,0 @@
--- cleanup
diff --git a/regress/loader/ReprojectPtsGeog-pre.sql b/regress/loader/ReprojectPtsGeog-pre.sql
index dfe50eab6..000000000
--- a/regress/loader/ReprojectPtsGeog-pre.sql
+++ /dev/null
@@ -1,9 +0,0 @@
index 182ff493c..1703a1d4f 100644
@@ -1,6 +1,5 @@
-INSERT INTO spatial_ref_sys ( auth_name, auth_srid, srid, proj4text ) VALUES ( 'EPSG', 4326, 4326, '+proj=longlat +ellps=WGS84 +datum=WGS84 +no_defs' );
@@ -57,4 +56,3 @@ select '#2184.2', st_addisonode('t3d', NULL, 'POINT(1 2 3)');
 select '#2184.3', topology.copyTopology('t3d', 't3d-bis') > 0;
 select '#2184.4', length(topology.dropTopology('t3d')) > 0, length(topology.dropTopology('t3d-bis')) > 0;
-DELETE FROM spatial_ref_sys where srid = 4326;
index aadbe017d..58fcb519e 100644
@@ -1,7 +1,5 @@
@@ -218,5 +216,4 @@ ORDER BY name;
 DROP SCHEMA features CASCADE;
 DROP TABLE visited;
index 2bc106141..460229a2c 100644
@@ -1,8 +1,6 @@
 -- Save max node id
@@ -270,7 +268,6 @@ SELECT * FROM ValidateTopology('city_data');
 -- Cleanups
 DROP FUNCTION check_changes(text,boolean);
 SELECT DropTopology('city_data');
 -- See http://trac.osgeo.org/postgis/ticket/3280
 SELECT 't3280.start', topology.CreateTopology('bug3280') > 0;
commit 4bdfea50cd2cc5450a57ed5ae91d136adaaef55c
Date:   Fri Aug 12 11:22:55 2022 +0200
    Allow running `make staged-install` from top-level dir
diff --git a/GNUmakefile.in b/GNUmakefile.in
index c08aaafcf..c806319e4 100644
--- a/GNUmakefile.in
+++ b/GNUmakefile.in
@@ -37,6 +37,9 @@ test: check
 check: all docs-check check-no-trailing-blanks
+staged-install: all
+	$(MAKE) -C regress staged-install
 check-no-trailing-blanks:
 	! find . -name '*.c' -o -name '*.h' -o -name '*.proto' | \
 		grep -v lwin_wkt_lex.c | \
Summary of changes:
 GNUmakefile.in                                  |  3 +++
 regress/loader/ReprojectPts-post.sql            |  2 --
 regress/loader/ReprojectPts-pre.sql             | 11 -----------
 regress/loader/ReprojectPtsGeog-post.sql        |  2 --
 regress/loader/ReprojectPtsGeog-pre.sql         |  9 ---------
 topology/test/regress/cleartopogeom.sql         |  4 ++--
 topology/test/regress/copytopology.sql          |  8 +++-----
 topology/test/regress/getnodeedges.sql          |  2 +-
 topology/test/regress/getringedges.sql          |  2 +-
 topology/test/regress/gettopogeomelements.sql   |  4 ++--
 topology/test/regress/gml.sql                   |  9 +++------
 topology/test/regress/legacy_invalid.sql        |  2 +-
 topology/test/regress/legacy_predicate.sql      | 10 +++++-----
 topology/test/regress/legacy_query.sql          | 10 +++++-----
 topology/test/regress/legacy_validate.sql       |  4 ++--
 topology/test/regress/st_addedgemodface.sql     |  2 +-
 topology/test/regress/st_addedgenewfaces.sql    |  2 +-
 topology/test/regress/st_addisonode.sql         |  2 +-
 topology/test/regress/st_changeedgegeom.sql     |  2 +-
 topology/test/regress/st_modedgeheal.sql        |  2 +-
 topology/test/regress/st_modedgesplit.sql       |  2 +-
 topology/test/regress/st_newedgeheal.sql        |  2 +-
 topology/test/regress/st_newedgessplit.sql      |  2 +-
 topology/test/regress/st_remedgemodface.sql     |  8 ++++----
 topology/test/regress/st_remedgenewface.sql     |  8 ++++----
 topology/test/regress/topogeo_addlinestring.sql |  5 +----
 topology/test/regress/topogeo_addpoint.sql      |  2 +-
 topology/test/regress/topogeo_addpolygon.sql    |  2 +-
 topology/test/regress/topogeometry_type.sql     |  8 ++++----
 topology/test/regress/topojson.sql              |  6 +++---
 30 files changed, 54 insertions(+), 83 deletions(-)
 delete mode 100644 regress/loader/ReprojectPts-post.sql
 delete mode 100644 regress/loader/ReprojectPts-pre.sql
 delete mode 100644 regress/loader/ReprojectPtsGeog-post.sql
 delete mode 100644 regress/loader/ReprojectPtsGeog-pre.sql
hooks/post-receive
