[postgis-tickets] [SCM] PostGIS branch stable-2.5 updated. 2.5.7-12-ge98af774c
Fri Aug 12 06:56:11 PDT 2022
the project "PostGIS".
The branch, stable-2.5 has been updated
       via  e98af774c38385ed9a3da4c336a94cb060a77436 (commit)
       via  1e8beb08e21003a094685ef15bd76d476433880f (commit)
      from  4a78ce4e94e1f4982e42cec6f66645e20b59c87e (commit)
revisions in full, below.
commit e98af774c38385ed9a3da4c336a94cb060a77436
Author: Sandro Santilli <strk at kbt.io>
Date:   Fri Aug 12 15:55:58 2022 +0200
    Use more relative paths in tests
diff --git a/regress/regress.sql b/regress/regress.sql
index b5bedb453..011a4cfe4 100644
--- a/regress/regress.sql
+++ b/regress/regress.sql
@@ -146,7 +146,7 @@ select '112',ST_NumGeometries('GEOMETRYCOLLECTION(POINT(1 1), LINESTRING( 1 1 ,
 -- create a table with data that will be TOASTed (even after compression)
 create table TEST(a GEOMETRY, b GEOMETRY);
-\i regress_biginsert.sql
+\i :regdir/regress_biginsert.sql
 ---test basic ops on this
diff --git a/regress/sfcgal/regress.sql b/regress/sfcgal/regress.sql
index ff77c046f..685a570a4 100644
--- a/regress/sfcgal/regress.sql
+++ b/regress/sfcgal/regress.sql
@@ -191,7 +191,7 @@ select '112',ST_NumGeometries('GEOMETRYCOLLECTION(POINT(1 1), LINESTRING( 1 1 ,
commit 1e8beb08e21003a094685ef15bd76d476433880f
Date:   Fri Aug 12 15:50:18 2022 +0200
    Drop other custom SRIDs usages in tests
diff --git a/regress/geography.sql b/regress/geography.sql
index 409437ac5..f17bcdfec 100644
--- a/regress/geography.sql
+++ b/regress/geography.sql
@@ -1,21 +1,3 @@
-INSERT INTO spatial_ref_sys (srid, auth_name, auth_srid, srtext, proj4text)
-VALUES (
- '4326',
- 'EPSG',
- '4326',
- 'GEOGCS["WGS 84",DATUM["WGS_1984",SPHEROID["WGS 84",6378137,298.257223563,AUTHORITY["EPSG","7030"]],AUTHORITY["EPSG","6326"]],PRIMEM["Greenwich",0,AUTHORITY["EPSG","8901"]],UNIT["degree",0.0174532925199433,AUTHORITY["EPSG","9122"]],AUTHORITY["EPSG","4326"]]',
- '+proj=longlat +datum=WGS84 +no_defs'
-VALUES (
- '4269',
- 'EPSG',
- '4269',
- 'GEOGCS["NAD83",DATUM["North_American_Datum_1983",SPHEROID["GRS 1980",6378137,298.257222101,AUTHORITY["EPSG","7019"]],TOWGS84[0,0,0,0,0,0,0],AUTHORITY["EPSG","6269"]],PRIMEM["Greenwich",0,AUTHORITY["EPSG","8901"]],UNIT["degree",0.0174532925199433,AUTHORITY["EPSG","9122"]],AUTHORITY["EPSG","4269"]]',
- '+proj=longlat +ellps=GRS80 +towgs84=0,0,0,0,0,0,0 +no_defs'
 -- Do cached and uncached distance agree?
 SELECT c, abs(ST_Distance(ply::geography, pt::geography) - _ST_DistanceUnCached(ply::geography, pt::geography)) < 0.01 FROM
 ( VALUES
@@ -142,6 +124,3 @@ select 'dwithin_poly_line_1', ST_DWithin('POLYGON((1 1, 2 2, 3 0, 1 1))'::geogra
 select 'dwithin_poly_poly_1', ST_DWithin('POLYGON((0 0, -2 -2, -3 0, 0 0))'::geography, 'POLYGON((1 1, 2 2, 3 0, 1 1))'::geography, 10);
 select 'dwithin_poly_poly_2', ST_DWithin('POLYGON((0 0, -2 -2, -3 0, 0 0))'::geography, 'POLYGON((1 1, 2 2, 3 0, 1 1))'::geography, 300000);
 select 'dwithin_poly_poly_3', ST_DWithin('POLYGON((1 1, -2 -2, -3 0, 1 1))'::geography, 'POLYGON((1 1, 2 2, 3 0, 1 1))'::geography, 300000);
--- Clean up spatial_ref_sys
-DELETE FROM spatial_ref_sys WHERE srid IN (4269, 4326);
diff --git a/regress/in_gml.sql b/regress/in_gml.sql
index 4f2bf16bb..e21c8b067 100644
--- a/regress/in_gml.sql
+++ b/regress/in_gml.sql
@@ -3,21 +3,6 @@
 -- Written by Olivier Courtin - Oslandia
--- spatial_ref_sys datas
--- EPSG 4326 : WGS 84
-INSERT INTO "spatial_ref_sys" ("srid","auth_name","auth_srid","srtext","proj4text") VALUES (4326,'EPSG',4326,'GEOGCS["WGS 84",DATUM["WGS_1984",SPHEROID["WGS 84",6378137,298.257223563,AUTHORITY["EPSG","7030"]],TOWGS84[0,0,0,0,0,0,0],AUTHORITY["EPSG","6326"]],PRIMEM["Greenwich",0,AUTHORITY["EPSG","8901"]],UNIT["degree",0.01745329251994328,AUTHORITY["EPSG","9122"]],AUTHORITY["EPSG","4326"]]','+proj=longlat +ellps=WGS84 +datum=WGS84 +no_defs ');
---- EPSG 27562 : NTF (Paris) / Lambert Centre France
-INSERT INTO "spatial_ref_sys" ("srid","auth_name","auth_srid","srtext","proj4text") VALUES (27562,'EPSG',27562,'PROJCS["NTF (Paris) / Lambert Centre France",GEOGCS["NTF (Paris)",DATUM["Nouvelle_Triangulation_Francaise_Paris",SPHEROID["Clarke 1880 (IGN)",6378249.2,293.4660212936265,AUTHORITY["EPSG","7011"]],TOWGS84[-168,-60,320,0,0,0,0],AUTHORITY["EPSG","6807"]],PRIMEM["Paris",2.33722917,AUTHORITY["EPSG","8903"]],UNIT["grad",0.01570796326794897,AUTHORITY["EPSG","9105"]],AUTHORITY["EPSG","4807"]],UNIT["metre",1,AUTHORITY["EPSG","9001"]],PROJECTION["Lambert_Conformal_Conic_1SP"],PARAMETER["latitude_of_origin",52],PARAMETER["central_meridian",0],PARAMETER["scale_factor",0.99987742],PARAMETER["false_easting",600000],PARAMETER["false_northing",200000],AUTHORITY["EPSG","27562"],AXIS["X",EAST],AXIS["Y",NORTH]]','+proj=lcc +lat_1=46.8 +lat_0=46.8 +lon_0=0 +k_0=0.99987742 +x_0=600000 +y_0=200000 +a=6378249.2 +b=6356515 +towgs84=-168,-60,320,0,0,0,0 +pm=paris +units=m +no_defs ');
---- EPSG 27582 : NTF (Paris) / France II (deprecated)
-INSERT INTO "spatial_ref_sys" ("srid","auth_name","auth_srid","srtext","proj4text") VALUES (27582,'EPSG',27582,'PROJCS["NTF (Paris) / France II (deprecated)",GEOGCS["NTF (Paris)",DATUM["Nouvelle_Triangulation_Francaise_Paris",SPHEROID["Clarke 1880 (IGN)",6378249.2,293.4660212936265,AUTHORITY["EPSG","7011"]],TOWGS84[-168,-60,320,0,0,0,0],AUTHORITY["EPSG","6807"]],PRIMEM["Paris",2.33722917,AUTHORITY["EPSG","8903"]],UNIT["grad",0.01570796326794897,AUTHORITY["EPSG","9105"]],AUTHORITY["EPSG","4807"]],UNIT["metre",1,AUTHORITY["EPSG","9001"]],PROJECTION["Lambert_Conformal_Conic_1SP"],PARAMETER["latitude_of_origin",52],PARAMETER["central_meridian",0],PARAMETER["scale_factor",0.99987742],PARAMETER["false_easting",600000],PARAMETER["false_northing",2200000],AUTHORITY["EPSG","27582"],AXIS["X",EAST],AXIS["Y",NORTH]]','+proj=lcc +lat_1=46.8 +lat_0=46.8 +lon_0=0 +k_0=0.99987742 +x_0=600000 +y_0=2200000 +a=6378249.2 +b=6356515 +towgs84=-168,-60,320,0,0,0,0 +pm=paris +units=m +no_defs ');
---- EPSG 28992
-INSERT INTO "spatial_ref_sys" ("srid","auth_name","auth_srid","srtext","proj4text") VALUES (28992,'EPSG',28992,'PROJCS["Amersfoort / RD New",GEOGCS["Amersfoort",DATUM["Amersfoort",SPHEROID["Bessel 1841",6377397.155,299.1528128,AUTHORITY["EPSG","7004"]],TOWGS84[565.2369,50.0087,465.658,-0.406857,0.350733,-1.87035,4.0812],AUTHORITY["EPSG","6289"]],PRIMEM["Greenwich",0,AUTHORITY["EPSG","8901"]],UNIT["degree",0.0174532925199433,AUTHORITY["EPSG","9122"]],AUTHORITY["EPSG","4289"]],PROJECTION["Oblique_Stereographic"],PARAMETER["latitude_of_origin",52.15616055555555],PARAMETER["central_meridian",5.38763888888889],PARAMETER["scale_factor",0.9999079],PARAMETER["false_easting",155000],PARAMETER["false_northing",463000],UNIT["metre",1,AUTHORITY["EPSG","9001"]],AXIS["X",EAST],AXIS["Y",NORTH],AUTHORITY["EPSG","28992"]]','+proj=sterea +lat_0=52.15616055555555 +lon_0=5.38763888888889 +k=0.9999079 +x_0=155000 +y_0=463000 +ellps=bessel +towgs84=565.2369,50.0087,465.658,-0.406857,0.350733,-1.87035,4.0
 812 +units=m +no_defs');
 -- Empty Geometry
 SELECT 'empty_geom', ST_AsEWKT(ST_GeomFromGML(NULL));
@@ -1267,11 +1252,3 @@ SELECT 'double_31', ST_AsEWKT(ST_GeomFromGML('<gml:Point><gml:pos>1 $0%@#$^%#</g
 -- #4652
 SELECT '#4652', ST_AsEWKT(ST_GeomFromGML('<gml:Curve id="id-69b216c9-2c07-434d-8664-e321b3697725-0" srsDimension="2" srsName="urn:x-ogc:def:crs:EPSG:28992"> <gml:segments> <gml:LineStringSegment> <gml:posList>119675.91899999976 526436.1209999993 119676.54699999839 526439.4930000007 119676.44299999997 526439.5130000003 119676.03299999982 526439.6220000014 119675.38500000164 526439.868999999</gml:posList> </gml:LineStringSegment> <gml:LineStringSegment> <gml:posList>119675.38500000164 526439.868999999 119675.15500452081 526439.9735735222 119674.92922525379 526440.0869634049 119674.70800000057 526440.2089999989</gml:posList> </gml:LineStringSegment> <gml:LineStringSegment> <gml:posList>119674.70800000057 526440.2089999989 119674.01347910661 526440.6575801083 119673.38748824484 526441.1976901226</gml:posList> </gml:LineStringSegment> </gml:segments> </gml:Curve>',28992));
--- Delete inserted spatial data
-DELETE FROM spatial_ref_sys WHERE srid = 4326;
-DELETE FROM spatial_ref_sys WHERE srid = 27562;
-DELETE FROM spatial_ref_sys WHERE srid = 27582;
-DELETE FROM spatial_ref_sys WHERE srid = 28992;
diff --git a/regress/in_kml.sql b/regress/in_kml.sql
index 1b40f9034..fb38c8fba 100644
--- a/regress/in_kml.sql
+++ b/regress/in_kml.sql
@@ -3,13 +3,6 @@
 -- Empty Geometry
 SELECT 'empty_geom', ST_AsEWKT(ST_GeomFromKML(NULL));
@@ -328,8 +321,3 @@ SELECT 'double_31', ST_AsEWKT(ST_GeomFromKML('<kml:Point><kml:coordinates>1,$0%@
 -- ERROR: mixed coordinate dimension
 SELECT 'mixed_dims_1', ST_AsEWKT(ST_GeomFromKML('<kml:Point><kml:coordinates>1,2 1,2,3</kml:coordinates></kml:Point>'));
 SELECT 'mixed_dims_2', ST_AsEWKT(ST_GeomFromKML('<kml:Point><kml:coordinates>1,2,3 1,2</kml:coordinates></kml:Point>'));
diff --git a/regress/knn_recheck.sql b/regress/knn_recheck.sql
index 9568f78ed..61b151969 100644
--- a/regress/knn_recheck.sql
+++ b/regress/knn_recheck.sql
@@ -1,4 +1,4 @@
--- create table
+-- create table
 CREATE TABLE knn_recheck_geom(gid serial primary key, geom geometry);
 INSERT INTO knn_recheck_geom(gid,geom)
 SELECT ROW_NUMBER() OVER(ORDER BY x,y) AS gid, ST_Point(x*0.777,y*0.887) As geom
@@ -66,9 +66,6 @@ ORDER BY a.gid, true_rn, b.gid;
 DROP TABLE knn_recheck_geom;
 -- geography tests
-DELETE FROM spatial_ref_sys where srid = 4326;
-INSERT INTO "spatial_ref_sys" ("srid","auth_name","auth_srid","proj4text")
-    VALUES (4326,'EPSG',4326,'+proj=longlat +ellps=WGS84 +datum=WGS84 +no_defs ');
 -- create table
 CREATE TABLE knn_recheck_geog(gid serial primary key, geog geography);
 INSERT INTO knn_recheck_geog(gid,geog)
@@ -130,11 +127,6 @@ ORDER BY a.gid;
 DROP TABLE knn_recheck_geog;
 --now the nd operator tests
 -- create table and load
 CREATE TABLE knn_recheck_geom_nd(gid serial primary key, geom geometry);
diff --git a/regress/legacy.sql b/regress/legacy.sql
index 57bd4ab27..2aba229e8 100644
--- a/regress/legacy.sql
+++ b/regress/legacy.sql
@@ -11,8 +11,6 @@ SET client_min_messages TO WARNING;
 \cd :scriptdir
 \i legacy.sql
-TRUNCATE spatial_ref_sys;
 SELECT 'Starting up MapServer/Geoserver tests...';
 -- Set up the data table
@@ -54,6 +52,4 @@ SELECT 'Done.';
 -- test #1869 ST_AsBinary is not unique --
 SELECT 1869 As ticket_id, ST_AsText(ST_AsBinary('POINT(1 2)'));
-DELETE FROM spatial_ref_sys WHERE SRID = '4326';
 \i uninstall_legacy.sql
diff --git a/regress/out_geography.sql b/regress/out_geography.sql
index 4e5a87dfe..765c0da71 100644
--- a/regress/out_geography.sql
+++ b/regress/out_geography.sql
@@ -1,11 +1,4 @@
-INSERT INTO "spatial_ref_sys" ("srid","auth_name","auth_srid","proj4text") VALUES (4326,'EPSG',4326,'+proj=longlat +ellps=WGS84 +datum=WGS84 +no_defs ');
-INSERT INTO "spatial_ref_sys" ("srid", "proj4text") VALUES (102189, '+proj=tmerc +lat_0=4.599047222222222 +lon_0=-74.08091666666667 +k=1.000000 +x_0=1000000 +y_0=1000000 +ellps=intl +towgs84=307,304,-318,0,0,0,0 +units=m +no_defs ');
 -- GML
@@ -70,9 +63,7 @@ SELECT 'kml_version_03', ST_AsKML(-4, geography(ST_GeomFromEWKT('SRID=4326;POINT
 SELECT 'kml_prefix_01', ST_AsKML(2, geography(ST_GeomFromEWKT('SRID=4326;POINT(1 2)')), 0, '');
 SELECT 'kml_prefix_02', ST_AsKML(2, geography(ST_GeomFromEWKT('SRID=4326;POINT(1 2)')), 0, 'kml');
--- Projected
--- National Astronomical Observatory of Colombia - Bogota, Colombia (Placemark)
-SELECT 'kml_projection_01', ST_AsKML(geography(ST_GeomFromEWKT('SRID=102189;POINT(1000000 1000000)')), 3);
+-- Projected -- there's no projected geography
 -- SVG
@@ -146,9 +137,3 @@ SELECT 'geojson_options_16', ST_AsGeoJSON(geography(ST_GeomFromEWKT('SRID=4326;L
 -- Precision
 SELECT 'text_precision_01', ST_AsText(geography(GeomFromEWKT('SRID=4326;POINT(111.1111111 1.1111111)')));
 SELECT 'text_precision_02', ST_AsText(geography(GeomFromEWKT('SRID=4326;POINT(111.1111111 1.1111111)')),2);
-DELETE FROM spatial_ref_sys;
diff --git a/regress/out_geography_expected b/regress/out_geography_expected
index 68cfc1605..554d86bab 100644
--- a/regress/out_geography_expected
+++ b/regress/out_geography_expected
@@ -30,7 +30,6 @@ ERROR:  Only KML 2 is supported
 kml_prefix_01|<Point><coordinates>1,2</coordinates></Point>
 kml_prefix_02|<kml:Point><kml:coordinates>1,2</kml:coordinates></kml:Point>
-ERROR:  Only lon/lat coordinate systems are supported in geography.
 svg_empty_geom|
 svg_option_01|M 1 -1 L 4 -4 5 -7
 svg_option_02|M 1 -1 l 3 -3 1 -3
diff --git a/regress/out_geometry.sql b/regress/out_geometry.sql
index 6dafe7e70..ef8060956 100644
--- a/regress/out_geometry.sql
+++ b/regress/out_geometry.sql
@@ -1,12 +1,3 @@
-DELETE FROM "spatial_ref_sys";
---- EPSG 1021892 : Bogota 1975 / Colombia Bogota zone (deprecated)
 -- GML
@@ -86,7 +77,7 @@ SELECT 'kml_prefix_02', ST_AsKML(2, ST_GeomFromEWKT('SRID=4326;POINT(1 2)'), 0,
 -- Projected
-SELECT 'kml_projection_01', ST_AsKML(ST_GeomFromEWKT('SRID=102189;POINT(1000000 1000000)'), 3);
+SELECT 'kml_projection_01', ST_AsKML(ST_GeomFromEWKT('SRID=3116;POINT(1000000 1000000)'), 3);
 -- Encoded Polyline
@@ -181,9 +172,3 @@ SELECT 'pgcast_06',ST_AsText('((0,0),(0,1),(1,1),(1,0))'::polygon::geometry);
 -- Precision
 SELECT 'text_precision_01', ST_AsText(GeomFromEWKT('SRID=4326;POINT(111.1111111 1.1111111)'));
 SELECT 'text_precision_02', ST_AsText(GeomFromEWKT('SRID=4326;POINT(111.1111111 1.1111111)'),2);
diff --git a/regress/regress_management.sql b/regress/regress_management.sql
index 567d81bdd..c92b7aad0 100644
--- a/regress/regress_management.sql
+++ b/regress/regress_management.sql
@@ -1,8 +1,6 @@
 -- Test the populate_geometry_columns,DropGeometryTable etc --
 \set VERBOSITY terse
 SET client_min_messages TO warning;
-INSERT INTO spatial_ref_sys ( srid, proj4text ) VALUES( 4326, '+proj=longlat +ellps=WGS84 +datum=WGS84 +no_defs');
 CREATE TABLE test_pt(gid SERIAL PRIMARY KEY, geom geometry);
 INSERT INTO test_pt(geom) VALUES(ST_GeomFromEWKT('SRID=4326;POINT M(1 2 3)'));
 SELECT populate_geometry_columns('test_pt'::regclass);
diff --git a/regress/sfcgal/geography.sql b/regress/sfcgal/geography.sql
index 3ec43cd30..99114fb49 100644
--- a/regress/sfcgal/geography.sql
+++ b/regress/sfcgal/geography.sql
@@ -1,14 +1,5 @@
 SET postgis.backend = 'sfcgal';
-VALUES (
- '4326',
- 'EPSG',
- '4326',
 ( VALUES
@@ -73,6 +64,3 @@ ply AS (
 SELECT 'geog_precision_pazafir', _ST_DistanceUnCached(pt.point, ply.polygon), ST_Distance(pt.point, ply.polygon) FROM pt, ply;
diff --git a/regress/sfcgal/tickets.sql b/regress/sfcgal/tickets.sql
index ef3d9daf7..98db4f4a0 100644
--- a/regress/sfcgal/tickets.sql
+++ b/regress/sfcgal/tickets.sql
@@ -5,18 +5,6 @@
--- NOTE: some tests _require_ spatial_ref_sys entries.
--- In particular, the GML output ones want auth_name and auth_srid too,
--- so we provide one for EPSG:4326
-INSERT INTO spatial_ref_sys ( srid, proj4text ) VALUES ( 32611, '+proj=utm +zone=11 +ellps=WGS84 +datum=WGS84 +units=m +no_defs' );
-INSERT INTO spatial_ref_sys ( auth_name, auth_srid, srid, proj4text ) VALUES ( 'EPSG', 4326, 4326, '+proj=longlat +ellps=WGS84 +datum=WGS84 +no_defs' );
-INSERT INTO spatial_ref_sys ( srid, proj4text ) VALUES ( 32602, '+proj=utm +zone=2 +ellps=WGS84 +datum=WGS84 +units=m +no_defs ' );
-INSERT INTO spatial_ref_sys ( srid, proj4text ) VALUES ( 32702, '+proj=utm +zone=2 +south +ellps=WGS84 +datum=WGS84 +units=m +no_defs ' );
-INSERT INTO spatial_ref_sys ( srid, proj4text ) VALUES ( 3395, '+proj=merc +lon_0=0 +k=1 +x_0=0 +y_0=0 +ellps=WGS84 +datum=WGS84 +units=m +no_defs ' );
-INSERT INTO spatial_ref_sys (srid,proj4text) VALUES (32707,'+proj=utm +zone=7 +south +ellps=WGS84 +datum=WGS84 +units=m +no_defs ');
 -- #2 --
 SELECT '#2', ST_AsText(ST_Normalize(ST_Union(g)) ) FROM
 ( VALUES
@@ -607,6 +595,7 @@ FROM inp;
 insert into spatial_ref_sys (srid, proj4text) values (500001,NULL);
 insert into spatial_ref_sys (srid, proj4text) values (500002, '+proj=longlat +ellps=WGS84 +datum=WGS84 +no_defs');
 select '#1150', st_astext(st_transform('SRID=500002;POINT(0 0)'::geometry,500001));
+delete from spatial_ref_sys where srid in (500001,500002);
 -- #1038
 select '#1038', ST_AsSVG('POLYGON EMPTY'::geometry);
@@ -811,5 +800,3 @@ SELECT '#2110.3', 'POINT(0 0)'::geometry = 'POINT(0 0)'::geometry;
 SELECT '#2145',
 round(ST_Length(St_Segmentize(ST_GeographyFromText('LINESTRING(-89.3000030518 28.2000007629,-89.1999969482 89.1999969482,-89.1999969482 89.1999969482)'), 10000))::numeric,0);
--- Clean up
diff --git a/regress/tickets.sql b/regress/tickets.sql
index d01e1fe9a..a3dc92305 100644
--- a/regress/tickets.sql
+++ b/regress/tickets.sql
@@ -3,17 +3,6 @@
 -- referenced by bug number for historical interest.
 SET client_min_messages TO NOTICE;
 -- #2 --
@@ -569,6 +558,7 @@ FROM inp;
 -- #1038
@@ -1112,7 +1102,6 @@ ANALYZE bug_4144_table;
 DROP TABLE IF EXISTS bug_4144_table;
 -- Clean up
 SELECT '#4176', ST_Intersects('POLYGON((0 0, 10 10, 3 5, 0 0))', 'GEOMETRYCOLLECTION(POINT(10 10), LINESTRING(0 0, 3 3))');
Summary of changes:
 regress/geography.sql          | 21 ---------------------
 regress/in_gml.sql             | 23 -----------------------
 regress/in_kml.sql             | 12 ------------
 regress/knn_recheck.sql        | 10 +---------
 regress/legacy.sql             |  4 ----
 regress/out_geography.sql      | 17 +----------------
 regress/out_geography_expected |  1 -
 regress/out_geometry.sql       | 17 +----------------
 regress/regress.sql            |  2 +-
 regress/regress_management.sql |  2 --
 regress/sfcgal/geography.sql   | 12 ------------
 regress/sfcgal/regress.sql     |  2 +-
 regress/sfcgal/tickets.sql     | 15 +--------------
 regress/tickets.sql            | 13 +------------
 14 files changed, 7 insertions(+), 144 deletions(-)
hooks/post-receive
