[postgis-tickets] [SCM] PostGIS branch stable-2.5 updated. 2.5.7-18-ga15932c36
Fri Aug 12 08:01:32 PDT 2022
the project "PostGIS".
The branch, stable-2.5 has been updated
       via  a15932c364cd21d5ae47788b62df6e300a80ab8d (commit)
       via  09d2416240ab9d773b915493277f93ebd1681a73 (commit)
       via  73742528e7f4f42a9234064a74bbb1702ad166a7 (commit)
      from  316794da4b8e2e07369685f1903c12d4fdb88877 (commit)
revisions in full, below.
commit a15932c364cd21d5ae47788b62df6e300a80ab8d
Author: Sandro Santilli <strk at kbt.io>
Date:   Fri Aug 12 17:01:06 2022 +0200
    Stop expecting SAVEPOINT/RELEASE output from tests
    Should fix regression test broken by upgrade
    of run_test.pl in commit 35b17931f
diff --git a/raster/test/regress/rt_count_expected b/raster/test/regress/rt_count_expected
index b3ef7a876..517c87ba5 100644
--- a/raster/test/regress/rt_count_expected
+++ b/raster/test/regress/rt_count_expected
@@ -15,7 +15,6 @@
 1000
 20
 1000
-SAVEPOINT
 NOTICE:  Invalid band index (must use 1-based). Returning NULL
@@ -26,7 +25,4 @@ NOTICE:  Invalid band index (must use 1-based). Returning NULL
-RELEASE
-SAVEPOINT
 ERROR:  Sample percent must be between zero and one
-RELEASE
diff --git a/raster/test/regress/rt_histogram_expected b/raster/test/regress/rt_histogram_expected
index 750835fcd..e2d2882f8 100644
--- a/raster/test/regress/rt_histogram_expected
+++ b/raster/test/regress/rt_histogram_expected
@@ -74,7 +74,6 @@ NOTICE:  Invalid band index (must use 1-based). Returning NULL
 -10.000|-5.619|10|0.500
 -5.619|-1.239|0|0.000
 -1.239|3.142|10|0.500
-SAVEPOINT
 NOTICE:  Raster does not have band at index 2. Skipping raster
@@ -86,12 +85,7 @@ NOTICE:  Raster does not have band at index 2. Skipping raster
 ERROR:  RASTER_histogramCoverage: Cannot get summary stats of coverage
-RELEASE
-SAVEPOINT
 -10.000|-3.429|10|0.500
 -3.429|3.142|10|0.500
-RELEASE
-SAVEPOINT
-RELEASE
diff --git a/raster/test/regress/rt_quantile_expected b/raster/test/regress/rt_quantile_expected
index 013cf6e53..ff1716872 100644
--- a/raster/test/regress/rt_quantile_expected
+++ b/raster/test/regress/rt_quantile_expected
@@ -93,17 +93,9 @@ NOTICE:  Invalid band index (must use 1-based). Returning NULL
 3.142
 3.142
 3.142
-SAVEPOINT
-RELEASE
-SAVEPOINT
 3.142
-RELEASE
-SAVEPOINT
 3.142
-RELEASE
-SAVEPOINT
 NOTICE:  Invalid value for quantile (must be between 0 and 1). Returning NULL
-RELEASE
diff --git a/raster/test/regress/rt_summarystats_expected b/raster/test/regress/rt_summarystats_expected
index fe34a2801..8bed7afff 100644
--- a/raster/test/regress/rt_summarystats_expected
+++ b/raster/test/regress/rt_summarystats_expected
@@ -14,7 +14,6 @@ NOTICE:  Band is empty as width and/or height is 0
 1000|-68.584|-0.069|1.046|-10.000|3.142
 20|-68.584|-3.429|6.571|-10.000|3.142
-SAVEPOINT
@@ -26,35 +25,15 @@ NOTICE:  Raster does not have band at index 2. Skipping raster
 0|||||
-RELEASE
-SAVEPOINT
-RELEASE
-SAVEPOINT
-RELEASE
-SAVEPOINT
-RELEASE
-SAVEPOINT
-RELEASE
-SAVEPOINT
-RELEASE
-SAVEPOINT
-RELEASE
-SAVEPOINT
-RELEASE
-SAVEPOINT
-RELEASE
-SAVEPOINT
 ERROR:  Invalid sample percentage (must be between 0 and 1). Returning NULL
-RELEASE
-SAVEPOINT
@@ -66,4 +45,3 @@ NOTICE:  Raster does not have band at index 2. Skipping raster
 0|||||
-RELEASE
diff --git a/raster/test/regress/rt_valuecount_expected b/raster/test/regress/rt_valuecount_expected
index e22b0ddab..c5132868e 100644
--- a/raster/test/regress/rt_valuecount_expected
+++ b/raster/test/regress/rt_valuecount_expected
@@ -35,12 +35,6 @@ NOTICE:  Invalid band index (must use 1-based). Returning NULL
 0
 10
 0
-SAVEPOINT
-RELEASE
-SAVEPOINT
 ERROR:  relation "test1" does not exist at character 20
-RELEASE
-SAVEPOINT
 ERROR:  column "rast1" does not exist at character 8
-RELEASE
commit 09d2416240ab9d773b915493277f93ebd1681a73
Date:   Fri Aug 12 16:58:46 2022 +0200
    Drop more custom SRIDs usages in tests
diff --git a/raster/test/regress/loader/Projected-post.sql b/raster/test/regress/loader/Projected-post.sql
index 2fc7692e6..496c8bf5f 100644
--- a/raster/test/regress/loader/Projected-post.sql
+++ b/raster/test/regress/loader/Projected-post.sql
@@ -1,4 +1,3 @@
-TRUNCATE spatial_ref_sys;
 -- should this be done automatically ?
 -- "loadedrast" is removed automatically !
 DROP TABLE o_2_loadedrast;
diff --git a/raster/test/regress/loader/Projected-pre.sql b/raster/test/regress/loader/Projected-pre.sql
index 61918bd1d..e69de29bb 100644
--- a/raster/test/regress/loader/Projected-pre.sql
+++ b/raster/test/regress/loader/Projected-pre.sql
@@ -1,8 +0,0 @@
--- NOTE: the need for truncation here reveals a leak bug in previous tests
-INSERT INTO "spatial_ref_sys" ("srid","auth_name","auth_srid","srtext","proj4text")
-VALUES
-(4326,'EPSG',4326,'GEOGCS["WGS 84",DATUM["WGS_1984",SPHEROID["WGS 84",6378137,298.257223563,AUTHORITY["EPSG","7030"]],AUTHORITY["EPSG","6326"]],PRIMEM["Greenwich",0,AUTHORITY["EPSG","8901"]],UNIT["degree",0.01745329251994328,AUTHORITY["EPSG","9122"]],AUTHORITY["EPSG","4326"]]','+proj=longlat +ellps=WGS84 +datum=WGS84 +no_defs ')
-('3857','EPSG','3857','PROJCS["WGS 84 / Pseudo-Mercator",GEOGCS["WGS 84",DATUM["WGS_1984",SPHEROID["WGS 84",6378137,298.257223563,AUTHORITY["EPSG","7030"]],AUTHORITY["EPSG","6326"]],PRIMEM["Greenwich",0,AUTHORITY["EPSG","8901"]],UNIT["degree",0.0174532925199433,AUTHORITY["EPSG","9122"]],AUTHORITY["EPSG","4326"]],UNIT["metre",1,AUTHORITY["EPSG","9001"]],PROJECTION["Mercator_1SP"],PARAMETER["central_meridian",0],PARAMETER["scale_factor",1],PARAMETER["false_easting",0],PARAMETER["false_northing",0],EXTENSION["PROJ4","+proj=merc +a=6378137 +b=6378137 +lat_ts=0.0 +lon_0=0.0 +x_0=0.0 +y_0=0 +k=1.0 +units=m +nadgrids=@null +wktext  +no_defs"],AUTHORITY["EPSG","3857"],AXIS["X",EAST],AXIS["Y",NORTH]]','+proj=merc +a=6378137 +b=6378137 +lat_ts=0.0 +lon_0=0.0 +x_0=0.0 +y_0=0 +k=1.0 +units=m +nadgrids=@null +wktext  +no_defs')
commit 73742528e7f4f42a9234064a74bbb1702ad166a7
Date:   Fri Aug 12 16:51:09 2022 +0200
    run_test.pl: run psql in quiet mode when loading scripts
diff --git a/regress/run_test.pl b/regress/run_test.pl
index efafb29ae..c66331f5b 100755
--- a/regress/run_test.pl
+++ b/regress/run_test.pl
@@ -1383,7 +1383,7 @@ sub load_sql_file
 	if ( -e $file )
 		# ON_ERROR_STOP is used by psql to return non-0 on an error
-		my $psql_opts = "--no-psqlrc --variable ON_ERROR_STOP=true";
+		my $psql_opts = "--quiet --no-psqlrc --variable ON_ERROR_STOP=true";
 		my $cmd = "psql $psql_opts -c 'CREATE SCHEMA IF NOT EXISTS $OPT_SCHEMA' ";
 		$cmd .= "-c 'SET search_path TO $OPT_SCHEMA,topology'";
 		$cmd .= " -Xf $file $DB >> $REGRESS_LOG 2>&1";
Summary of changes:
 raster/test/regress/loader/Projected-post.sql |  1 -
 raster/test/regress/loader/Projected-pre.sql  |  8 --------
 raster/test/regress/rt_count_expected         |  4 ----
 raster/test/regress/rt_histogram_expected     |  6 ------
 raster/test/regress/rt_quantile_expected      |  8 --------
 raster/test/regress/rt_summarystats_expected  | 22 ----------------------
 raster/test/regress/rt_valuecount_expected    |  6 ------
 regress/run_test.pl                           |  2 +-
 8 files changed, 1 insertion(+), 56 deletions(-)
hooks/post-receive
