[postgis-tickets] [PostGIS] #5211: Upgrade from unpackaged2.5--3.2.3dev fails on trying to add spgist_geometry_ops_nd opclass
PostGIS trac at osgeo.org
Fri Aug 12 08:23:26 PDT 2022
 Reporter:  strk     |      Owner:  pramsey
     Type:  defect   |     Status:  new
 Priority:  blocker  |  Milestone:  PostGIS 3.0.7
Component:  postgis  |    Version:  3.0.x
 Keywords:           |
 See session:
 strk at c19:/usr/local/src/postgis/postgis-3.2(stable-3.2)]
 regress/run_test.pl -v --extension --upgrade --upgrade-path unpackaged2.5
 --3.2.3dev regress/core/regress
 Upgrade path: unpackaged2.5 --> 3.2.3dev
 PATH is
 /home/postgresql/PG12/bin/:/home/strk/.nvm/versions/node/v16.16.0/bin:/home/strk/.local/bin:/home/strk/bin:/usr/local/sbin:/usr/local/bin:/usr/sbin:/usr/bin:/sbin:/bin:/usr/games:/usr/local/games:/snap/bin:/home/strk/bin:/home/strk/go/bin:/opt/bitcoin/bin:/home/strk/bin:/home/strk/go/bin:/opt/bitcoin/bin
 Checking for shp2pgsql ... found
 Checking for pgsql2shp ... found
 TMPDIR is /tmp/pgis_reg
 Creating database 'postgis_reg'
 Loading unpackaged components from
 /home/postgresql/PG12/share/contrib/postgis-2.5
 Loading PostGIS into 'postgis_reg'
 Upgrading from postgis 2.5.8dev
 Upgrading PostGIS in 'postgis_reg' using: CREATE EXTENSION postgis VERSION
 '3.2.3dev' FROM unpackaged;
  failed (Error encountered updating EXTENSION POSTGIS:
 /tmp/pgis_reg/regress_log)
 NOTICE:  schema "public" already exists, skipping
 CREATE SCHEMA
 ERROR:  Trying to add OPERATOR CLASS spgist_geometry_ops_nd USING SPGIST
 to postgis, got operator class "spgist_geometry_ops_nd" does not exist for
 access method "spgist" (42704)
 CONTEXT:  PL/pgSQL function inline_code_block line 25 at RAISE
 Died at regress/run_test.pl line 1663.
 This was introduced by commit
 [b8b2614feb9a3529803f5d2b6d725dcf5e2c889e/git] aimed at fixing #5209
 Similar commits went in branches 3.1
 ([f2c16bd63f888e285feebb8050e7c46cb6ddd091/git])
 and 3.0 ([d4c55c6c5562ab286e5a78d7675c8d000913d82c/git])
Ticket URL: <https://trac.osgeo.org/postgis/ticket/5211>
