[postgis-tickets] [PostGIS] #5187: Upgrade failures on 2.5 to 3.3.0
PostGIS trac at osgeo.org
Fri Aug 12 10:05:29 PDT 2022
  Reporter:  robe                   |      Owner:  strk
      Type:  defect                 |     Status:  closed
  Priority:  critical               |  Milestone:  PostGIS 2.5.8
 Component:  build/upgrade/install  |    Version:  master
Resolution:  fixed                  |   Keywords:
Changes (by Sandro Santilli <strk@…>):
 * status:  reopened => closed
 * resolution:   => fixed
Comment:
 In [changeset:"a903b04e3eee109e7a6d6ea44e12583429f4dd28/git"
 a903b04e/git]:
 {{{#!CommitTicketReference repository="git"
 revision="a903b04e3eee109e7a6d6ea44e12583429f4dd28"
 Survive upgrades adding views and tables
 Closes #5187 in master branch (3.3.0dev)
Ticket URL: <https://trac.osgeo.org/postgis/ticket/5187#comment:15>
