[postgis-tickets] [PostGIS] #5187: Upgrade failures on 2.5 to 3.3.0
PostGIS trac at osgeo.org
Fri Aug 12 10:18:06 PDT 2022
  Reporter:  robe                   |      Owner:  strk
      Type:  defect                 |     Status:  closed
  Priority:  critical               |  Milestone:  PostGIS 2.5.8
 Component:  build/upgrade/install  |    Version:  master
Resolution:  fixed                  |   Keywords:
Comment (by strk):
 Replying to [comment:11 Sandro Santilli <strk@…>]:
 > In [changeset:"40c8f25a0fe041427b111ed133d573b553e1ce53/git"
 40c8f25a/git]:
 > {{{#!CommitTicketReference repository="git"
 revision="40c8f25a0fe041427b111ed133d573b553e1ce53"
 > Survive upgrades adding operator class (and other object kinds)
 > References #5187 in 3.1 branch (3.1.7dev)
 For the record: the above commit [40c8f25a/git] was in 3.0 branch
 (3.0.7dev) not 3.1 as written in the commit log. I've pushed a note to
 mention it in git history but Trac doesn't show it. Gitea instead does:
 https://git.osgeo.org/gitea/postgis/postgis/commit/40c8f25a0fe041427b111ed133d573b553e1ce53
Ticket URL: <https://trac.osgeo.org/postgis/ticket/5187#comment:16>
