[postgis-tickets] [PostGIS] #5215: gitlab-ci is not checking installs for branches 3.0 and 2.5
PostGIS trac at osgeo.org
Fri Aug 12 23:33:19 PDT 2022
 Reporter:  strk       |      Owner:  robe
     Type:  defect     |     Status:  new
 Priority:  blocker    |  Milestone:  PostGIS 2.5.8
Component:  buildbots  |    Version:  2.5.x
 Keywords:             |
 When using:
 make installcheck RUNTESTFLAGS=-v
 The RUNTESTFLAGS is fully set by user instead of being *appended_to*.
 This means the internal `--extension` switch won't be used, defeating the
 purpose of the `installcheck`.
 Note that this would work:
 RUNTESTFLAGS=-v make installcheck
 The gitlab-ci configuration in branches 2.5 and 3.0 is using the non-
 functional call, resulting in lack of install check and duplicated normal
 check.
 This was fixed from 3.1 onward, see commit
 [ae5e5a8f816b70d82d43964bb81395c1b685ec29/git]
Ticket URL: <https://trac.osgeo.org/postgis/ticket/5215>
