[postgis-tickets] [PostGIS] #5215: gitlab-ci is not checking installs in 2.5 branch (was: gitlab-ci is not checking installs for branches 3.0 and 2.5)
PostGIS trac at osgeo.org
Fri Aug 12 23:35:31 PDT 2022
  Reporter:  strk       |      Owner:  robe
      Type:  defect     |     Status:  new
  Priority:  blocker    |  Milestone:  PostGIS 2.5.8
 Component:  buildbots  |    Version:  2.5.x
Resolution:             |   Keywords:
Changes (by strk):
 * summary:  gitlab-ci is not checking installs for branches 3.0 and 2.5 =>
Old description:
> When using:
> make installcheck RUNTESTFLAGS=-v
> The RUNTESTFLAGS is fully set by user instead of being *appended_to*.
> This means the internal `--extension` switch won't be used, defeating the
> purpose of the `installcheck`.
> Note that this would work:
> RUNTESTFLAGS=-v make installcheck
> The gitlab-ci configuration in branches 2.5 and 3.0 is using the non-
> functional call, resulting in lack of install check and duplicated normal
> check.
> This was fixed from 3.1 onward, see commit
> [ae5e5a8f816b70d82d43964bb81395c1b685ec29/git]
New description:
 When using:
 The gitlab-ci configuration in branch 2.5 is using the non-functional
 call, resulting in lack of install check and duplicated normal check.
 This was fixed from 3.0 onward, see commit
Ticket URL: <https://trac.osgeo.org/postgis/ticket/5215#comment:1>
