[postgis-tickets] [PostGIS] #5216: Error: Package: gdal-libs-1.11.4-12.rhel7.x86_64 (@pgdg11)
PostGIS trac at osgeo.org
Mon Aug 15 19:05:50 PDT 2022
  Reporter:  marc3932  |      Owner:  pramsey
      Type:  patch     |     Status:  closed
  Priority:  high      |  Milestone:  PostGIS GDAL
 Component:  postgis   |    Version:  3.1.x
Resolution:  wontfix   |   Keywords:  gdal-libs
Changes (by robe):
 * status:  new => closed
 * resolution:   => wontfix
Comment:
 This is not a postgis problem but a packaging issue.
 My guess is either you have an old postgis like a postgis-2.4 installed
 that you are not using anymore.  I recall I ran into this issue on a
 CentOS 7 I had upgraded from PostGIS-2.4 to PostGIS 3.2.
 You need to make sure you have the pg_depends repo in your  repos list:
 I recall running into this very problem on a CentOS 7.
 My entry looks like this:
 [pgdg-depends]
 name=PostgreSQL RHEL/CentOS 7 - x86_64 common
 baseurl=https://download.postgresql.org/pub/repos/yum/common/redhat/rhel-7-x86_64/
 enabled=1
 gpgcheck=0
 Anyrate, I'm going to close this out as a won't fix, cause it's a
 packaging issue we don't manage.  If you continue to have issues, you
 should write the pg yum mailing list -- https://www.postgresql.org/list
 /pgsql-pkg-yum/ (join here - https://lists.postgresql.org/manage/)
Ticket URL: <https://trac.osgeo.org/postgis/ticket/5216#comment:5>
