[postgis-tickets] [PostGIS] #5217: RHEL 8 nothing provides libarmadillo.so.10 (64bit) needed by gdal-libs*
PostGIS trac at osgeo.org
Sat Aug 13 14:41:17 PDT 2022
 Reporter:  marc3932   |      Owner:  pramsey
     Type:  patch      |     Status:  new
 Priority:  high       |  Milestone:  PostGIS GDAL
Component:  postgis    |    Version:  3.2.x
 Keywords:  gdal-libs  |
 # cat /etc/redhat-release
 Red Hat Enterprise Linux release 8.6 (Ootpa)
 # rpm -qa | grep postgres | sort
 postgresql12-12.12-1PGDG.rhel8.x86_64
 postgresql12-contrib-12.12-1PGDG.rhel8.x86_64
 postgresql12-libs-12.12-1PGDG.rhel8.x86_64
 postgresql12-server-12.12-1PGDG.rhel8.x86_64
 postgresql13-13.7-1PGDG.rhel8.x86_64
 postgresql13-contrib-13.7-1PGDG.rhel8.x86_64
 postgresql13-libs-13.7-1PGDG.rhel8.x86_64
 postgresql13-server-13.7-1PGDG.rhel8.x86_64
 # rpm -qa | grep postgis | sort
 postgis31_12-3.1.6-1.rhel8.x86_64
 postgis32_13-3.2.2-1.rhel8.x86_64
 # subscription-manager repos --list-enabled
     Available Repositories in /etc/yum.repos.d/redhat.repo
 Repo ID:   rhel-8-for-x86_64-appstream-rpms
 Repo Name: Red Hat Enterprise Linux 8 for x86_64 - AppStream (RPMs)
 Repo URL:  https://red-inf-
 cap-p01.esri.com/pulp/repos/ESRI/LEP_Patch/cv_patch/content/dist/rhel8/$releasever/x86_64/appstream/os
 Enabled:   1
 Repo ID:   rhel-8-for-x86_64-baseos-rpms
 Repo Name: Red Hat Enterprise Linux 8 for x86_64 - BaseOS (RPMs)
 cap-p01.esri.com/pulp/repos/ESRI/LEP_Patch/cv_patch/content/dist/rhel8/$releasever/x86_64/baseos/os
 Enabled:   1
 Repo ID:   ESRI_EPEL_8_EPEL8_x86_64
 Repo Name: EPEL8 x86_64
 cap-p01.esri.com/pulp/repos/ESRI/LEP_Patch/cv_patch/custom/EPEL_8/EPEL8_x86_64
 Enabled:   1
 --PROBLEM:
 # yum update
 #Error:
  Problem 1: cannot install the best update candidate for package
 gdal32-libs-3.2.3-1.rhel8.x86_64
   - nothing provides libarmadillo.so.10()(64bit) needed by
 gdal32-libs-3.2.3-6.rhel8.x86_64
  Problem 2: cannot install the best update candidate for package
 gdal33-libs-3.3.3-1.rhel8.x86_64
 gdal33-libs-3.3.3-5.rhel8.x86_64
  Problem 3: cannot install the best update candidate for package
 gdal34-libs-3.4.3-1.rhel8.x86_64
 gdal34-libs-3.4.3-2.rhel8.x86_64
 (try to add '--skip-broken' to skip uninstallable packages or '--nobest'
 to use not only best candidate packages)
Ticket URL: <https://trac.osgeo.org/postgis/ticket/5217>
