[postgis-tickets] [PostGIS] #5217: RHEL 8 nothing provides libarmadillo.so.10 (64bit) needed by gdal-libs*
PostGIS trac at osgeo.org
Tue Aug 16 03:04:04 PDT 2022
  Reporter:  marc3932  |      Owner:  pramsey
      Type:  patch     |     Status:  new
  Priority:  high      |  Milestone:  PostGIS GDAL
 Component:  postgis   |    Version:  3.2.x
Resolution:            |   Keywords:  gdal-libs
Comment (by devrimgunduz):
 Please enable EPEL repository.
 Regards, Devrim
 Replying to [ticket:5217 marc3932]:
 > # cat /etc/redhat-release
 > Red Hat Enterprise Linux release 8.6 (Ootpa)
 > # rpm -qa | grep postgres | sort
 > postgresql12-12.12-1PGDG.rhel8.x86_64
 > postgresql12-contrib-12.12-1PGDG.rhel8.x86_64
 > postgresql12-libs-12.12-1PGDG.rhel8.x86_64
 > postgresql12-server-12.12-1PGDG.rhel8.x86_64
 > postgresql13-13.7-1PGDG.rhel8.x86_64
 > postgresql13-contrib-13.7-1PGDG.rhel8.x86_64
 > postgresql13-libs-13.7-1PGDG.rhel8.x86_64
 > postgresql13-server-13.7-1PGDG.rhel8.x86_64
 > # rpm -qa | grep postgis | sort
 > postgis31_12-3.1.6-1.rhel8.x86_64
 > postgis32_13-3.2.2-1.rhel8.x86_64
 > # subscription-manager repos --list-enabled
 >     Available Repositories in /etc/yum.repos.d/redhat.repo
 > Repo ID:   rhel-8-for-x86_64-appstream-rpms
 > Repo Name: Red Hat Enterprise Linux 8 for x86_64 - AppStream (RPMs)
 > Repo URL:  https://red-inf-
 cap-p01.esri.com/pulp/repos/ESRI/LEP_Patch/cv_patch/content/dist/rhel8/$releasever/x86_64/appstream/os
 > Enabled:   1
 > Repo ID:   rhel-8-for-x86_64-baseos-rpms
 > Repo Name: Red Hat Enterprise Linux 8 for x86_64 - BaseOS (RPMs)
 cap-p01.esri.com/pulp/repos/ESRI/LEP_Patch/cv_patch/content/dist/rhel8/$releasever/x86_64/baseos/os
 > Enabled:   1
 > Repo ID:   ESRI_EPEL_8_EPEL8_x86_64
 > Repo Name: EPEL8 x86_64
 cap-p01.esri.com/pulp/repos/ESRI/LEP_Patch/cv_patch/custom/EPEL_8/EPEL8_x86_64
 > Enabled:   1
 > --PROBLEM:
 > # yum update
 > #Error:
 >  Problem 1: cannot install the best update candidate for package
 gdal32-libs-3.2.3-1.rhel8.x86_64
 >   - nothing provides libarmadillo.so.10()(64bit) needed by
 gdal32-libs-3.2.3-6.rhel8.x86_64
 >  Problem 2: cannot install the best update candidate for package
 gdal33-libs-3.3.3-1.rhel8.x86_64
 gdal33-libs-3.3.3-5.rhel8.x86_64
 >  Problem 3: cannot install the best update candidate for package
 gdal34-libs-3.4.3-1.rhel8.x86_64
 gdal34-libs-3.4.3-2.rhel8.x86_64
 > (try to add '--skip-broken' to skip uninstallable packages or '--nobest'
 to use not only best candidate packages)
Ticket URL: <https://trac.osgeo.org/postgis/ticket/5217#comment:1>
