[postgis-tickets] [PostGIS] #5217: RHEL 8 nothing provides libarmadillo.so.10 (64bit) needed by gdal-libs*
PostGIS trac at osgeo.org
Thu Aug 18 16:45:13 PDT 2022
  Reporter:  marc3932  |      Owner:  pramsey
      Type:  patch     |     Status:  new
  Priority:  high      |  Milestone:  PostGIS GDAL
 Component:  postgis   |    Version:  3.2.x
Resolution:            |   Keywords:  gdal-libs
Comment (by marc3932):
 Problem Description:
 - gdal3*libs are part of PostgreSQL PostGIS
 - I cannot install the latest gdal3*libs because it requires
 libarmadillo.so.10
 - libarmadillo.so.10 is part of the EPEL repository
 - the ESRI_EPEL_8_EPEL8_x86_64 cannot provide libarmadillo.so.10
 - but epel repo has armadillo v10 , it is there
 https://dl.fedoraproject.org/pub/epel/8/Everything/x86_64/Packages/a/
 - this means the internal repo ESRI_EPEL_8_EPEL8_x86_64 is not updated
 - I have contacted my IT department to update the internal EPEL repo
Ticket URL: <https://trac.osgeo.org/postgis/ticket/5217#comment:2>
