[postgis-tickets] [PostGIS] #5217: RHEL 8 nothing provides libarmadillo.so.10 (64bit) needed by gdal-libs*
PostGIS trac at osgeo.org
Thu Aug 18 16:48:27 PDT 2022
  Reporter:  marc3932  |      Owner:  pramsey
      Type:  patch     |     Status:  new
  Priority:  high      |  Milestone:  PostGIS GDAL
 Component:  postgis   |    Version:  3.2.x
Resolution:            |   Keywords:  gdal-libs
Comment (by marc3932):
 I want to point out that the alternative to download the rpm of armadillo
 10 from the public EPEL repo and try to install on RHEL 8.6, but this
 causes other dependencies to show up, see below, therefore the best
 solution is really to have the internal ESRI_EPEL_8_EPEL8_x86_64 repo
 update by my IT department.
 https://rpmfind.net/linux/rpm2html/search.php?query=libarmadillo.so.10()(64bit)
 armadillo-10.8.2-4.el9.x86_64.rpm
 [root at lnx8pg12 ~]# **rpm -Uvh /tmp/armadillo-10.8.2-4.el9.x86_64.rpm**
 warning: /tmp/armadillo-10.8.2-4.el9.x86_64.rpm: Header V4 RSA/SHA256
 Signature, key ID 3228467c: NOKEY
 **error: Failed dependencies:**
 **libhdf5.so.200()(64bit) is needed by armadillo-10.8.2-4.el9.x86_64**
 **libsuperlu.so.5()(64bit) is needed by armadillo-10.8.2-4.el9.x86_64**
 libarmadillo.so.9()(64bit) is needed by (installed)
 gdal32-libs-3.2.3-1.rhel8.x86_64
 gdal33-libs-3.3.3-1.rhel8.x86_64
 gdal34-libs-3.4.3-1.rhel8.x86_64
Ticket URL: <https://trac.osgeo.org/postgis/ticket/5217#comment:3>
