[postgis-tickets] [SCM] postgis.net branch website updated. e3ee0c5db79402e46db67030287177a6602dfec9
Tue Aug 16 19:51:20 PDT 2022
the project "postgis.net".
The branch, website has been updated
       via  e3ee0c5db79402e46db67030287177a6602dfec9 (commit)
      from  52aae6201b1c07a7b11bc3a8b41d2d0b0f4e4304 (commit)
revisions in full, below.
commit e3ee0c5db79402e46db67030287177a6602dfec9
Author: Regina Obe <lr at pcorp.us>
Date:   Tue Aug 16 22:51:13 2022 -0400
    Update instructions and latst stable version
diff --git a/config/_default/params.toml b/config/_default/params.toml
index 4175726..315e27d 100644
--- a/config/_default/params.toml
+++ b/config/_default/params.toml
@@ -125,7 +125,7 @@ matomoDomain = "matomo.example.com" # Set to Matomo domain
 matomoSiteID = "1" # Default is set to 1, change this to the siteid being tracked
 [postgis]
-version = "3.2.1"
+version = "3.2.2"
 release_docs =  "https://download.osgeo.org/postgis/docs"
 release_source = "https://download.osgeo.org/postgis/source"
 release_notes = "https://git.osgeo.org/gitea/postgis/postgis/raw/tag"
diff --git a/content/pages/install.md b/content/pages/install.md
index fd06a4e..f1b443b 100644
--- a/content/pages/install.md
+++ b/content/pages/install.md
@@ -102,32 +102,33 @@ CREATE EXTENSION postgis_tiger_geocoder;
 ## Upgrading PostGIS
-To upgrade PostGIS, you first have to install the latest binaries and then upgrade each database you have PostGIS installed in
+To upgrade PostGIS, you first have to install the latest binaries and then upgrade each database you have PostGIS installed in.
-For example connect to database you want to upgrade and if you just installed binaries for 2.1.3
-You can upgrade from 2.0 to 2.1, 2.2 et.c using this approach. To go from 1.* to 2.* you need to do a hard upgrade.
+For example connect to database you want to upgrade and if you just installed binaries for 2.5.
+You can upgrade from 2.5 to 3.1, 3.3 etc using this approach. To go from 1.* to 2.* or 1.* to 3.* you need to do a hard upgrade.
 Refer to  [PostGIS install](/docs/postgis_installation.html#install_short_version)  for more extensive instructions.
-Note: that as of PostGIS 2.1.3 and PostGIS 2.0.6, you need to set [environment variables](/posts/2014/05/19/postgis-2.0.6_and_2.1.3) to get full features.
+Note: that as of PostGIS 2.1.3 and PostGIS 2.0.6, you need to set [environment variables or GUCS](/2014/05/19/postgis-2.0.6_and_2.1.3) to get full features.
+For PostGIS 3+
 ```postgres
--- Upgrade PostGIS (includes raster) to latest version
+-- Upgrades postgis and other installed postgis packaged extensions
+SELECT postgis_extensions_upgrade();
+For PostGIS 2.5 and below
+```postgres
+-- Upgrade PostGIS and postgis packaged extensions
 ALTER EXTENSION postgis UPDATE;
-ALTER EXTENSION postgis_topology UPDATE;
 or to a specific version
 ```postgres
+-- Upgrade PostGIS (repeat for each PostGIS packaged extension you have installed)
  UPDATE TO "{{< loc postgis.version>}}";
--- Upgrade Topology
- UPDATE TO "{{< loc "postgis.version">}}";
--- Upgrade US Tiger Geocoder
-ALTER EXTENSION postgis_tiger_geocoder
diff --git a/content/post/2014/05-19_postgis-2.0.6_and_2.1.3.md b/content/post/2014/05-19_postgis-2.0.6_and_2.1.3.md
index 5059320..41ae820 100644
--- a/content/post/2014/05-19_postgis-2.0.6_and_2.1.3.md
+++ b/content/post/2014/05-19_postgis-2.0.6_and_2.1.3.md
@@ -1,5 +1,6 @@
 title: Security releases 2.0.6 and 2.1.3
+slug: "postgis-2.0.6_and_2.1.3"
 layout: post
 category: news
 tags: [release, 2.1, 2.0]
Summary of changes:
 config/_default/params.toml                        |  2 +-
 content/pages/install.md                           | 29 +++++++++++-----------
 content/post/2014/05-19_postgis-2.0.6_and_2.1.3.md |  1 +
 3 files changed, 17 insertions(+), 15 deletions(-)
hooks/post-receive
postgis.net
