[postgis-tickets] [PostGIS] #5223: GEOS 3.10 doesn't regress cleanly with PostGIS 3.0
PostGIS trac at osgeo.org
Fri Aug 19 21:02:58 PDT 2022
 Reporter:  robe      |      Owner:  strk
     Type:  defect    |     Status:  new
 Priority:  medium    |  Milestone:  PostGIS 3.0.8
Component:  topology  |    Version:  3.0.x
 Keywords:            |
 I was hoping I could just upgrade all my PostGIS versions to at least
 3.10, but get a topology regression.
 I'm not sure this is worth fixing though, unless it's not too much
 trouble.
 PostgreSQL 12.12, compiled by Visual C++ build 1914, 64-bit
   Postgis 3.0.8dev - (3.0.7-1-ge43ebd130) - 2022-08-19 23:29:30
   scripts 3.0.8dev 3.0.7-1-ge43ebd130
   GEOS: 3.10.3dev-CAPI-1.16.0
   PROJ: 7.2.1
  regress/addedge .. failed (diff expected obtained:
 /projects/postgis/tmp/3.0.8dev_pg12_geos3.10_gdal3.4.3w64/test_7_diff)
 --- regress/addedge_expected    2020-08-09 14:02:07.597151800 -0400
 +++ /projects/postgis/tmp/3.0.8dev_pg12_geos3.10_gdal3.4.3w64/test_7_out
 2022-08-19 20:04:48.713399500 -0400
 @@ -17,7 +17,7 @@
  e6|6
  #770-1|7
  #770-2|8
 -ERROR:  Edge intersects (not on endpoints) with existing edge 7 at or
 near point POINT(8 10)
 +ERROR:  Edge intersects (not on endpoints) with existing edge 7 at or
 near point POINT(10 12)
  #770-1*|7
Ticket URL: <https://trac.osgeo.org/postgis/ticket/5223>
