[postgis-tickets] [PostGIS] #5222: extension "postgis_raster" has no installation script nor update path for version "unpackaged"
PostGIS trac at osgeo.org
Wed Aug 31 11:11:38 PDT 2022
  Reporter:  marc3932  |      Owner:  robe
      Type:  patch     |     Status:  new
  Priority:  blocker   |  Milestone:  PostGIS Packaging
 Component:  raster    |    Version:  3.2.x
Resolution:            |   Keywords:  postgis_raster windows
Comment (by marc3932):
 -- I have Postgis 3.2.2 for PostgreSQL 11 installed and it already contain
 a file named "postgis--unpackaged--3.2.2.sql" under "C:\Program
 Files\PostgreSQL\11\share\extension"
 C:\Program Files\PostgreSQL\11\share\extension>dir postgis--unpackaged*.*
  Directory of C:\Program Files\PostgreSQL\11\share\extension
 03/11/2019  12:12 PM         1,475,393 postgis--unpackaged--2.5.2.sql
 07/30/2022  12:49 AM         1,068,869 postgis--unpackaged--3.2.2.sql
 08/30/2022  04:14 PM                21 postgis--unpackaged.sql
 -- I compared the file C:\Program
 Files\PostgreSQL\11\share\extension\postgis--unpackaged--3.2.2.sql on my
 server with the one from
 https://winnie.postgis.net/download/windows/pg11/buildbot/extras/postgis--
 --and they are identical, and still fails to upgrade.
 -- SELECT postgis_extensions_upgrade();
 NOTICE:  Extension postgis_sfcgal is not available or not packagable for
 some reason
 NOTICE:  Packaging extension postgis_raster
 ERROR:  extension "postgis_raster" has no installation script nor update
 CONTEXT:  SQL statement "CREATE EXTENSION postgis_raster SCHEMA public
 VERSION unpackaged;ALTER EXTENSION postgis_raster UPDATE TO "3.2.2""
 PL/pgSQL function postgis_extensions_upgrade() line 71 at EXECUTE
 SQL state: 22023
 -- I followed you suggestion and installed Postgis 3.2.3 for PostgreSQL 11
 -- I checked and PostGIS 3.2.3 has the empty file "C:\Program
 Files\PostgreSQL\11\share\extension\postgis--unpackaged.sql"
 -- This file just has text "-- Nothing to do here"
 C:\Program Files\PostgreSQL\11\share\extension>dir postgis--unpa*.*
 08/19/2022  04:24 PM         1,465,258 postgis--unpackaged--3.2.3.sql
 -- I was able to upgrade the postgis extension
 -- and upgrade the raster extension and then
 -- remove the raster extension and
 -- if I want I can reinstall postgis_raster extension
 -- SELECT postgis_full_version();
 "POSTGIS=""3.2.3 3.2.3"" [EXTENSION] PGSQL=""110""
 GEOS=""3.10.3-CAPI-1.16.1"" PROJ=""7.2.1""
 GDAL=""GDAL 2.2.4, released 2018/03/19 GDAL_DATA not found""
 LIBXML=""2.9.9"" LIBJSON=""0.12""
 LIBPROTOBUF=""1.2.1"" WAGYU=""0.5.0 (Internal)"" (core procs from ""3.2.2
 3.2.2"" need upgrade)   <== !!! 3.2.2 NEED UPGRADE !!!
 RASTER (raster lib from ""2.5.2 r17328"" need upgrade) [UNPACKAGED!]
 (raster procs from ""2.5.2 r17328"" need upgrade)"
 -- ALTER EXTENSION postgis UPDATE;
 Query returned successfully in 599 msec.
 NOTICE:  version "3.2.3" of extension "postgis" is already installed
 ALTER EXTENSION
 Query returned successfully in 160 msec.
 "Upgrade completed, run SELECT postgis_full_version(); for details"
 NOTICE:  Updating extension postgis from 3.2.2 to 3.2.3
 some reason
 WARNING:  'postgis.gdal_datapath' is already set and cannot be changed
 until you reconnect
 WARNING:  'postgis.gdal_enabled_drivers' is already set and cannot be
 changed until you reconnect
 WARNING:  'postgis.enable_outdb_rasters' is already set and cannot be
 NOTICE:  Extension postgis_topology is not available or not packagable for
 some reason
 NOTICE:  Extension postgis_tiger_geocoder is not available or not
 packagable for some reason
 Successfully run. Total query runtime: 1 secs 884 msec.
 1 rows affected.
 GDAL=""GDAL 3.4.3, released 2022/04/22 GDAL_DATA not found""
 LIBXML=""2.9.9"" LIBJSON=""0.12"" LIBPROTOBUF=""1.2.1"" WAGYU=""0.5.0
 (Internal)"" RASTER"
 -- SELECT * FROM pg_available_extensions WHERE name LIKE 'postgis';
 "postgis"       "3.2.3" "3.2.3" "PostGIS geometry and geography spatial
 types and functions"
 -- CREATE EXTENSION postgis_raster;
 ERROR:  extension "postgis_raster" already exists
 SQL state: 42710
 -- NOTE: if postgis_raster already exists then pg_available_extensions
 should have showed that, seems another bug to fix !!!
 -- DROP EXTENSION postgis_raster;
 DROP EXTENSION
 Query returned successfully in 125 msec.
 (Internal)"""
 --NOTE: RASTER EXTENSION REMOVED !!!
 -- Try to install postgis_raster extension
 CREATE EXTENSION
 Query returned successfully in 252 msec.
 --NOTE: pg_available_extensions still does not show postgis_raster but in
 pgAdmin when expand the "Extensions" I can see "postgis" and
 "postgis_raster".
 DROP EXTENSION
Ticket URL: <https://trac.osgeo.org/postgis/ticket/5222#comment:9>
