[postgis-tickets] [PostGIS] #5222: extension "postgis_raster" has no installation script nor update path for version "unpackaged"
PostGIS trac at osgeo.org
Tue Aug 30 16:43:59 PDT 2022
  Reporter:  marc3932  |      Owner:  robe
      Type:  patch     |     Status:  new
  Priority:  blocker   |  Milestone:  PostGIS Packaging
 Component:  raster    |    Version:  3.2.x
Resolution:            |   Keywords:  postgis_raster windows
Comment (by marc3932):
 I tried but the upgrade still fails, see details below.
 --create an empty file named "postgis--unpackaged.sql" in your
 share/extension folder of your PostgreSQL install.
 --This file just has text
 -- Nothing to do here
 --C:\Program Files\PostgreSQL\11\share\extension folder
 --And then try your upgrade again.
 --SELECT postgis_extensions_upgrade();
 NOTICE:  Extension postgis_sfcgal is not available or not packagable for
 some reason
 NOTICE:  Packaging extension postgis_raster
 ERROR:  extension "postgis_raster" has no installation script nor update
 CONTEXT:  SQL statement "CREATE EXTENSION postgis_raster SCHEMA public
 VERSION unpackaged;ALTER EXTENSION postgis_raster UPDATE TO "3.2.2""
 PL/pgSQL function postgis_extensions_upgrade() line 71 at EXECUTE
 SQL state: 22023
 --SELECT * FROM pg_available_extensions WHERE name LIKE 'postgis';
 "postgis"       "3.2.2" "3.2.2" "PostGIS geometry and geography spatial
 types and functions"
 --only the postgis extension is installed!!!
 --CREATE EXTENSION postgis_raster;
 ERROR: PostGIS Raster is already installed in schema 'public'CONTEXT:
 PL/pgSQL function inline_code_block line 10 at RAISESQL state: P0001
 --SELECT postgis_full_version();
 "POSTGIS=""3.2.2 3.2.2"" [EXTENSION] PGSQL=""110""
 GEOS=""3.10.3-CAPI-1.16.1"" PROJ=""7.2.1"" GDAL=""GDAL 2.2.4, released
 2018/03/19 GDAL_DATA not found"" LIBXML=""2.9.9"" LIBJSON=""0.12""
 LIBPROTOBUF=""1.2.1"" WAGYU=""0.5.0 (Internal)"" RASTER (raster lib from
 ""2.5.2 r17328"" need upgrade) [UNPACKAGED!] (raster procs from ""2.5.2
 r17328"" need upgrade)"
Ticket URL: <https://trac.osgeo.org/postgis/ticket/5222#comment:8>
