[postgis-tickets] [PostGIS] #5225: ST_SIMPLIFYPRESERVETOPOLOGY instability on some MULTILINESTRING
PostGIS trac at osgeo.org
Wed Aug 24 09:09:15 PDT 2022
 Reporter:  cactusbone  |      Owner:  pramsey
     Type:  defect      |     Status:  new
 Priority:  low         |  Milestone:  PostGIS GEOS
Component:  postgis     |    Version:  3.2.x
 Keywords:              |
 I have a question.
 It seems ST_SIMPLIFYPRESERVETOPOLOGY (from postgis, which documentation
 says it is performed by the geos module) sends varying data with some
 MULTILINESTRING inputs
 It also seems that the longer the MULTILINESTRING, the greater the chance
 of variation.
 My question: is this a bug or something to be expected ?
 example SQL : (run a few times, check that diff is sometimes not empty)
 SELECT ST_ASTEXT(A), a,
         ST_ASTEXT(ST_DIFFERENCE(A,A)) AS DIFF
 FROM (
                 SELECT ST_SIMPLIFYPRESERVETOPOLOGY(WAY,1222) AS A
         FROM (SELECT ST_GEOMFROMTEXT(
         'MULTILINESTRING((194310.3864375258
 6269374.922168917,194229.76886229333 6269419.62067134,194119.46237886624
 6269472.9675241215,194042.57400657536 6269505.525209331,193958.79495780432
 6269533.572399087,193858.273457618 6269561.687510971,193767.74844770491
 6269582.053220367,193573.44027652525 6269621.462109578,193479.14153587425
 6269645.72817361,193389.2065192624 6269674.369340893,193292.52554150842
 6269711.7098361235,193217.87469098245 6269746.35423054,193155.7695470689
 6269778.590772032,193093.35270858108 6269814.473358343,193040.4759504543
 6269849.186005235,192970.65636582876 6269900.4158241125,192894.84779259854
 6269962.719570645,192836.52751137194 6270015.289773788,192778.54118861773
 6270073.778748463,192625.0316108138 6270239.666467283,192568.5592331344
 6270298.716632978,192512.55439731627 6270357.292362772,192453.93355346454
 6270412.985471226,192393.4425421675 6270465.931574068,192347.57891196062
 6270503.173810453,192301.4481149759 6270537.770570481,192237.51733141334
 6270581.932522803,192171.7275123545 6270622.940256508,192058.01465250918
 6270680.941609077,191985.70151128987 6270713.673542163,191909.31407670752
 6270741.572103306,191822.22883905994 6270769.640353469,191449.74269091658
 6270869.872750556,191380.12348137447 6270888.596497581,191124.12204839717
 6270957.488032467,190824.78393765405 6271035.233363513,190464.67651688692
 6271132.212507669,189704.9321241719 6271338.029749751,189668.1076366175
 6271348.087531609,189348.69862168434 6271433.655485189,189138.50515916848
 6271492.849680412,188856.3881736511 6271578.910977546,188790.843257472
 6271599.11193322,188320.0842628563 6271744.641655042,187820.53804792152
 6271896.195374541,187692.69874469453 6271935.632014541,187619.1610890765
 6271957.055092225,187607.1385840708 6271960.379660216,187539.91274358073
 6271978.970125731,187150.99583859628 6272106.017375912,187088.7459793447
 6272125.86338048,186794.37271789095 6272204.755950004,186715.3581433259
 6272226.9430276,186386.019429814 6272324.902724626,186341.98143925617
 6272338.33728588,186228.48008644333 6272372.704076362,186148.8198588317
 6272397.130705383,185908.72598108876 6272470.3262004275,184829.45012200074
 6272795.583095043,184445.90994842158 6272911.174952552,184084.39990207044
 6273020.101453073,183928.0962050476 6273064.4969112985,182967.9099372102
 6273321.187642189,182437.8733137471 6273462.573600028,182195.7756851699
 6273527.329633407,181451.6494170132 6273725.926944476,181349.51378421034
 6273753.394341246,180894.95177550512 6273876.39644083,180646.27516502203
 6273951.606744456,180527.5417961419 6273987.405251751,180453.04679290304
 6274011.0052037,180394.06972668075 6274031.602196206,180335.10379240758
 6274053.403845108,180288.73922449216 6274073.542850133,180239.85883608487
 6274096.091127523,180172.97808601626 6274130.278434857,180095.22142169712
 6274176.291545229,180053.242841719 6274204.93110029,180002.03587595408
 6274241.205747136,179936.64680706212 6274291.97015417,179876.75692101536
 6274344.431552935,179788.01302295495 6274433.304484509,179730.2493391823
 6274498.560004091,179617.97250076823 6274621.352372588,179525.2990246828
 6274717.490354004,179439.85018354992 6274796.916150924,179358.47563578002
 6274869.0125483805,179299.48743760868 6274917.065843037,178963.19125592217
 6275182.958891726,178872.84435719438 6275259.249852135,178787.77400233014
 6275335.965722783,178712.68900579007 6275410.527225275,178494.07978977027
 6275641.953757119,177877.44773441908 6276298.935552551,177659.651150682
 6276529.351169971,177237.7168847283 6276979.118426997,176836.78860668722
 6277406.437319403,176724.22233759708 6277523.229470048,176645.04078379582
 6277599.507615941,176614.50584747124 6277629.007448478,176501.08241830196
 6277727.538993572,176424.34989329817 6277788.915985597,176350.85676547643
 6277843.928209411,176274.5249906395 6277897.243390758,176156.33708726428
 6277973.049636971,176064.33152812364 6278026.925783878,175960.02516525035
 6278082.7034044145,175832.28604956504 6278145.356064293,175696.1868401212
 6278204.512415867,175593.32763062822 6278243.808757859,175473.42540709476
 6278283.529652145,175334.88830080253 6278323.9127527755,175224.9714355933
 6278350.359629461,175125.2736996388 6278371.238801115,175012.75195834498
 6278390.997674488,174923.1286363073 6278402.914130773,174785.29284280707
 6278416.494158423,174676.0216306444 6278421.977100771,174100.86721756277
 6278440.191358953,173698.97045995184 6278452.939665534,173540.2399980297
 6278455.129456483,173327.2190204477 6278456.521416915,173064.77218895347
 6278454.569277345,172730.62447343933 6278444.333283348,172564.44673758312
 6278438.375023896,172464.9493767121 6278432.926021066,172257.23833884092
 6278419.142266356,172119.8255594057 6278408.668664824,171877.5052918469
 6278387.432925874,171702.3329411346 6278369.490380695,171082.127530129
 6278305.138576055,170505.1140815511 6278245.047911142,170402.29939985444
 6278235.083765929,170292.12649981634 6278227.3433137005,170194.47704249248
 6278221.521004526,170041.15670782293 6278214.340727894,169855.24202624903
 6278210.2498401515,169705.57297087752 6278210.131017717,169622.81806142177
 6278211.387140695,169526.35972264942 6278213.848463291,169378.70555006122
 6278219.6028685635,169239.1331725046 6278228.310869838,169075.88313925627
 6278241.890616841,168886.91830363468 6278260.9871729845,168734.08777472458
 6278281.526628219,168578.49652244285 6278304.18798594,168370.69642897905
 6278340.038887247,168134.54326121017 6278389.571774863,168031.3500932448
 6278412.437122872,167946.24634253338 6278433.265522698,167775.02583374424
 6278477.027397188,167221.3672143348 6278632.35162899,166564.38184357106
 6278819.168873168,166459.41869570207 6278848.757844283,166041.4919314169
 6278967.029884336,165837.27632555665 6279028.602620861,165678.90208600505
 6279078.563955241,165512.601898709 6279134.518284295,165331.74112201715
 6279198.536874455,165093.95155773364 6279292.927407073,164927.9074052664
 6279363.551229157,164822.33200019805 6279410.390767568,164716.75659512973
 6279459.743182722,164550.01112987046 6279542.473213391,164382.6311435137
 6279628.973055033,164171.31335414085 6279747.323929873,163970.61544418964
 6279867.83266412,163782.9196507631 6279988.529877836,163630.74590684866
 6280090.722325979,163479.24007987903 6280199.5886100065,163379.94309409146
 6280273.819513355,163247.127809626 6280378.001954607,163115.57043540652
 6280484.698602745,163059.6880510283 6280531.968840754,162875.54334935802
 6280694.275525646,162783.88288063885 6280779.377839527,162689.60640388602
 6280869.388223054,162596.5767054301 6280961.284363624,162447.34179607264
 6281113.020460335,162357.3288558172 6281210.998327417,162269.20834690524
 6281309.588642108,162101.57232571964 6281505.567054671,162010.35713496362
 6281621.668706291,161854.3873964132 6281821.407357725,161723.431147444
 6281998.836028648,161601.6030967198 6282162.155893708,161215.4580470561
 6282692.4535129145,161104.21647990638 6282844.135795295,160829.9141226427
 6283218.198562569,160702.65368076783 6283385.584448484,160574.558342712
 6283548.625397618,160460.78982312127 6283687.600801415,160371.35574421793
 6283794.543099508,160231.61638742514 6283954.27963882,160087.1570842227
 6284113.3397397725,159955.12103619284 6284254.006129454,159817.01807591468
 6284395.35434521,159744.50455961193 6284466.955143437,159590.92819011354
 6284616.189126318,159504.75577229046 6284696.999112322,159389.42877982865
 6284802.459260868,159281.02585969414 6284898.169562886,159107.41198185296
 6285047.326225455,158927.04101092063 6285194.650745688,158757.7018015259
 6285325.923272096),(159612.02323361888 6284563.8677484,159743.35796885678
 6284436.870843225,159804.50576514952 6284376.057057197,159943.10966313622
 6284232.942543113,160062.97849082242 6284104.710601479,160212.85905322648
 6283940.435912305,160278.87151126692 6283866.104831385,160358.70985006384
 6283774.160091971,160552.72859056742 6283538.077492254,160684.97614562983
 6283370.620643681,160811.55753861085 6283201.910250149,161138.15779264923
 6282756.753832039,161584.226124207 6282147.686750394,161704.9855078195
 6281984.995507281,161836.4315625482 6281805.648176685,161986.86872240627
 6281612.872298865,162079.47540679717 6281496.176424808,162250.50667245197
 6281295.324729303,162338.95000788724 6281195.4440528685,162430.53255296283
 6281096.515461827,162580.01236520006 6280943.94763531,162596.9329278006
 6280927.239206045,162672.95300806337 6280852.187522901,162769.03286056704
 6280761.03967867,162860.51521810095 6280675.92056996,163020.51472221813
 6280534.855322192,163099.85212330648 6280467.05722754,163230.44101795607
 6280360.683402378,163363.5346011485 6280256.823770906,163467.76304037822
 6280179.112405164,163648.79079630628 6280051.332500253,163770.30715245623
 6279968.682376769,163963.03458686662 6279844.963376556,164159.33537693147
 6279726.662066799,164358.04066799747 6279615.085483966,164543.98874541855
 6279518.976647851,164709.18686975574 6279437.961534301,164812.15739873954
 6279390.289969728,164916.3747060202 6279343.246819833,165085.1461860119
 6279271.332933188,165186.24654755034 6279231.420650729,165324.78365384255
 6279176.721946358,165504.15274935775 6279112.499804153,165669.88520725077
 6279057.46234304,166039.34346524457 6278943.365158198,166557.42437539648
 6278795.793149981,166583.84049056174 6278788.238917756,167189.73021505136
 6278618.109211654,167769.8717413205 6278455.129456483,167928.78031442792
 6278413.489575424,168027.06429284927 6278389.860349767,168103.07324116293
 6278372.376123329,168372.9228187949 6278316.477766411,168581.99195445376
 6278280.134696615,168742.52579212672 6278256.30214721,168872.51356152602
 6278239.7348305425,169075.40446544587 6278218.839009227,169235.6711363409
 6278205.5648425175,169378.816869552 6278196.09300741,169525.63614595926
 6278190.508364088,169700.730573028 6278186.570259162,169851.34584407127
 6278186.315640371,170044.14007017616 6278190.372567335,170194.27666740905
 6278198.07903647,170293.64044489112 6278203.986202594,170401.4199758772
 6278212.354695007,170499.50357921512 6278220.723195708,171085.58956629265
 6278281.98494721,171705.6279980621 6278347.032546713,171877.6166113377
 6278364.924119366,172140.3417415589 6278387.178301031,172250.04709973568
 6278395.292349814,172467.320481866 6278410.0096924985,172565.3706893567
 6278415.8321315665,172732.4612450374 6278421.960125714,172873.4807759743
 6278427.290295983,173072.53115746178 6278431.551039599,173317.93497491552
 6278433.367373186,173696.47690335807 6278430.8211112525,174099.07497376102
 6278417.376860977,174673.76184498132 6278398.178101262,174785.28171085802
 6278392.304749357,174919.56641260194 6278379.845108834,174999.9724808019
 6278368.6416330505,175050.34455038584 6278360.748284028,175121.71147593344
 6278348.424489337,175222.12165662897 6278327.290751028,175329.82326397148
 6278301.030669535,175465.9781331607 6278262.582798295,175584.2884879758
 6278220.960840882,175688.11617703867 6278181.596706854,175823.68105292672
 6278123.068570675,175954.45919071068 6278060.959254745,176051.79695346032
 6278008.423854744,176149.13471620996 6277951.679200016,176247.7081253074
 6277886.770436193,176332.1439590741 6277828.889349307,176413.15115252437
 6277768.157069202,176490.89668489437 6277706.525623646,176554.3265307484
 6277652.481784668,176627.05155408365 6277584.842605183,176657.0632888015
 6277557.413671906,176711.01984598898 6277504.507992098,176760.8241861699
 6277453.130223573,176820.9701070455 6277390.431777683,177286.2855785614
 6276892.20443966,177861.65149867552 6276284.154003537,178398.8570973457
 6275710.3070790805,178695.34542912449 6275395.866013061,178775.66244173184
 6275316.536399705,178858.2392400023 6275241.313948316,178944.2780744364
 6275168.569570697,179282.555743059 6274899.63970496,179341.2990383506
 6274851.1623121975,179428.87408175768 6274776.724518886,179508.23374674423
 6274703.390274527,179556.8135725264 6274653.3699657265,179603.24493213627
 6274605.046692117,179711.58106057628 6274482.339396265,179772.46169009112
 6274415.709673763,179860.53767120678 6274326.463656855,179922.175273259
 6274271.881528828,179987.39736291478 6274218.419549947,180033.8621183719
 6274184.910548036,180080.6942281486 6274154.099350101,180113.37763064553
 6274134.21464984,180161.62349795533 6274106.525452321,180227.2797336252
 6274070.115652964,180274.1897670455 6274047.771040161,180324.66202417118
 6274025.0023307055,180385.19756326458 6274002.216716409,180442.14861475438
 6273980.992048297,180512.50253293573 6273958.885196452,180622.23015501068
 6273925.954068508,180758.819170214 6273887.695757958,181342.9348023045
 6273730.813046822,181445.46005332508 6273703.7698630225,182199.37130472253
 6273502.49257374,182963.31244224045 6273298.794114928,183938.78287616375
 6273037.642466021,184079.81353904973 6272997.267655166,184238.04306326332
 6272948.394035007,184438.81889685805 6272888.1548454845,185007.9731893859
 6272716.159139401,185901.1673876639 6272446.119879661,185976.12993276407
 6272423.898300745,186121.39073630024 6272380.829315267,186199.8821092586
 6272357.556209243,186287.8356389343 6272331.484299947,186334.95717938713
 6272317.506939917,186380.0304412093 6272304.157225641,186534.40831104142
 6272258.391783233,187140.94368857768 6272080.624735446,187160.71403014255
 6272073.754996126,187539.9238755298 6271955.324960422,187600.55960216493
 6271936.378344127,187674.38668845902 6271913.293043615,188332.00658032027
 6271715.4507022835,188782.3273164263 6271579.470701108,188845.1115092337
 6271560.0669725705,189141.16569499843 6271470.308346317,189362.03469668137
 6271405.008357309,189660.70489047974 6271327.564920277,189695.74826618144
 6271318.185594663,190457.64112506877 6271112.86068684,190816.96930940036
 6271015.305118234,190957.20960390175 6270978.976471972,191363.30310631558
 6270868.855156802,191382.17176000506 6270863.7502299575,191434.1802261037
 6270849.63961765,191820.4365952582 6270744.9131529685,191901.21001777778
 6270719.338045002,191985.0892540905 6270686.9791996395,192040.4595688111
 6270663.354607214,192160.21707700647 6270601.4866406545,192224.78238166656
 6270561.2591377525,192288.2122275206 6270517.639987497,192333.53039222254
 6270484.077816298,192375.79840287674 6270448.616364298,192436.43412951185
 6270396.28089196,192495.3110081924 6270340.316552183,192562.12496656654
 6270270.209020157,192607.55445075926 6270222.555224079,192756.95633935288
 6270062.772818872,192822.64597087 6269995.906593106,192877.8047785581
 6269946.151545336,192950.19584342095 6269885.764165967,193028.06382723083
 6269828.853568001,193081.4526550153 6269795.378919636,193143.23497240557
 6269758.885938274,193203.2473098922 6269726.344235049,193277.89816041818
 6269691.106408963,193383.50696133377 6269650.425386225,193473.76480446896
 6269622.140405321,193562.74247346004 6269598.857935085,193760.70192393768
 6269560.042655652,193859.23080523883 6269538.235634942,193947.90791160477
 6269513.155934936,194042.86343725142 6269480.309949474,194138.18631721768
 6269439.375585526,194224.10270021195 6269397.305304478,194320.43858754443
 6269340.66930346,194475.90738838635 6269233.418035558,194494.54227114512
 6269220.615801189,194664.23770291038 6269112.128240871,194828.89036174273
 6269037.198367567,195010.69735410626 6268978.30961655,195148.03220989797
 6268949.297773971,195257.4258735005 6268935.122532327,195372.96437299484
 6268930.30702502,195454.81759457514 6268931.917845822,195574.4415193816
 6268933.816919159,195727.56147896775 6268938.327220044,195820.25721895127
 6268939.463273653,195941.77357510122 6268941.85407354,195965.09500842242
 6268942.464490643,196037.35248989632 6268942.277974303,196407.6901718674
 6268913.825802466,196571.5524623151 6268895.682930008,196777.5714439262
 6268865.060562559,197081.7074247225 6268811.0732258195,197359.3048389137
 6268768.921292356,197475.16616493132 6268757.28970169,197670.76564220418
 6268743.233471346,198172.98352491803 6268730.66935761,198995.62342993126
 6268720.665555703,199347.37075693987 6268728.414262247,199766.67788291088
 6268759.137868818,200210.07454668958 6268814.12526456,200531.89919457294
 6268876.590566079,200935.03159853164 6268964.35475524,201114.24484675977
 6268993.722728287,201231.23049963443 6269013.934464141,201370.8140091401
 6269028.9067794895,201490.69396877536 6269036.316644114,201616.45159752454
 6269038.826164957,201729.85276279564 6269034.231029387,201869.69230713014
 6269026.32943679,202013.5616170314 6269008.321972242,202197.13858929859
 6268977.800933472,202565.27214535192 6268895.954225012,202962.90536646548
 6268805.5965146255,203348.71645765682 6268718.393507428,203397.96420038375
 6268706.863719617,203489.92523172806 6268685.499742586,203619.6903621458
 6268658.896579973,203844.1883792286 6268616.202833018,204131.44832522067
 6268588.548658428,204371.29730008382 6268588.718211642,204675.25516969484
 6268610.488872914,204941.39780828342 6268652.775660202,205011.76285841386
 6268673.444379371,205136.97502165815 6268706.69416403,205236.40559083468
 6268736.841200623,205346.28906019675 6268772.973701606,205514.38149129457
 6268842.237984302,205880.70053964798 6269000.77648296,206415.36805392808
 6269237.284144589,206920.04609738846 6269441.325643939,207099.98292230672
 6269503.846450623,207507.6237656426 6269626.668030797,207670.59550016397
 6269669.010772909,207843.78636394013 6269708.640515808,208195.21086442543
 6269775.453596626,208326.70144695044 6269795.412835121,208401.7530476433
 6269804.53610511,208587.40056243923 6269826.15727683,208844.6265098152
 6269851.678809498,209191.79860575218 6269865.550345944,209374.51841794027
 6269862.04006501,210445.4453152188 6269847.066274299,210891.858737198
 6269838.536482385,211903.04046376777 6269819.865934097,211997.6842948402
 6269818.136239613,212192.64925101554 6269814.931218413,212407.40681265394
 6269808.080277704,212479.0297730303 6269801.093680517,212650.52858054647
 6269780.625697236,212924.0071735783 6269723.664934162,213171.13644313932
 6269647.220428596,213310.74221654324 6269590.3114362415,213451.52797654943
 6269524.686822251,213657.66940960046 6269410.09084941,213828.21086949573
 6269294.6825062595,213881.0430998262 6269257.089502756,214002.68190741603
 6269159.029694296,214111.9642515278 6269056.952388293,214243.57728549268
 6268925.338916485,214374.81183318887 6268788.657730618,214873.33390880836
 6268207.147302767,215218.01244815157 6267810.013090632,215882.93489860886
 6267037.414654649,216116.60564173307 6266750.062595269,216274.74611035397
 6266549.306755744,216459.60325676532 6266299.9747393485,216683.26637766714
 6265986.527581096,216817.5844752583 6265785.0440774225,217058.769284011
 6265410.989382424,217213.72601519522 6265167.233065622,217368.43784349976
 6264940.143649308,217465.0075017629 6264806.035119937,217572.3306228367
 6264677.623069013,217658.02436684936 6264585.649580556,217711.70262530987
 6264529.503367279,217716.7120023956 6264524.385318675,217819.73819112475
 6264423.8213760685,218037.39005952372 6264242.168710179,218235.13800296892
 6264110.545412234,218316.47915489157 6264061.960376094,218399.21180044912
 6264015.256642067,218491.45113052044 6263968.7056804495,218519.58156584387
 6263954.80992066,218626.33695751466 6263902.701024731,218868.96891964765
 6263798.060552794,219003.18682969714 6263742.902412033,219524.27336610042
 6263522.578458384,219917.03079351725 6263360.025015918,220398.06457713316
 6263157.553507509,220812.79647203258 6262984.230630194,221226.7046027001
 6262802.134449159,221473.62236522866 6262688.324208363,221777.62476263603
 6262540.71374249,221856.95103177536 6262498.677762082,221929.31983274
 6262464.012213491,222114.2103749986 6262367.962615812,222255.61952415327
 6262288.670419796,222381.59979188404 6262211.056278395,222434.3429666219
 6262170.733124265,222484.49239722424 6262128.885348189,222542.9351298907
 6262075.178181773,222597.90469444444 6262018.862263656,222674.04722614703
 6261927.527586906),(212490.06153456794
 6198000.715026029,212379.49901631207 6197893.050431567,212340.8711530068
 6197854.040638241,212310.31395278405 6197824.245347578,212241.1066253579
 6197762.149741283,212189.75494425494 6197720.618408016,212145.14922429406
 6197687.427115726,212111.6309256162 6197664.038597945,212062.349787042
 6197631.318320755,212029.2545024292 6197610.889228954,211996.00337052924
 6197590.880536372,211946.154502552 6197563.8268411225,211885.16255354637
 6197533.5785913365,211819.5842415201 6197503.4481459,211775.4015356242
 6197485.4573616,211727.4896267868 6197467.0294574825,211667.66653243446
 6197446.92022078,211615.80278167388 6197431.636560121,211558.41758416998
 6197414.469796878,211474.1153337922 6197390.611248074,211228.5556690513
 6197324.248180438,210481.3347190506 6197120.454419101,209765.6617127406
 6196925.240006449,209577.96591931404 6196872.246564336,209373.60559811577
 6196811.015339376,209173.5422092621 6196747.19545404,208980.7702470554
 6196679.374741058,208855.96996592707 6196631.56095884,208734.5204014716
 6196583.814693298,208336.28605510772 6196426.169858823,208073.10451497426
 6196315.784907852,207715.27914376836 6196180.6720451135,207378.07014225743
 6196062.170566912,206998.59313009222 6195938.5266493885,206917.69725613273
 6195916.252443212,206501.23990912602 6195782.726103228,206074.01796735957
 6195639.6536853695,205728.7828305624 6195515.713326804,205494.16587176654
 6195425.326928047,205105.83896008326 6195256.49167308,205032.43488785418
 6195226.503762168,204922.08387663082 6195178.126626321,204769.09750043362
 6195112.066561723,204479.92285919993 6194989.764344907,204439.89237031064
 6194973.157197529,204396.65588008653 6194955.844112794,204320.33523719865
 6194926.243862112,204097.5515402741 6194843.007365857,204040.51143319166
 6194821.66049573,203908.72028804146 6194776.042245602,203860.04027471755
 6194759.502748834,203805.86107854848 6194742.34137406,203665.11984633855
 6194695.412502371,203435.89075089706 6194625.322226611,203163.3138457406
 6194546.509174163,202803.61830708943 6194456.637300373,202659.47069846117
 6194421.677112061,202233.5177988898 6194319.839574057,201938.05360642634
 6194250.307034981,201636.93438383052 6194178.287587824,201488.12248853804
 6194143.177277796,201408.89640694048 6194124.672572378,201340.34586451
 6194105.764536182,201184.33159816323 6194069.242732725,201132.23407647194
 6194055.343311639,201081.4835206193 6194042.704438166,201023.70870489758
 6194027.695800286,200964.11938147596 6194012.888872159,200889.20136417207
 6193991.880221502,200718.41500139705 6193941.896648272,200622.92514219458
 6193909.728491724,200503.95800238382 6193874.636095934,200456.98117726902
 6193859.07313529,200414.7242985639 6193844.804311923,200306.24345478584
 6193806.552554789,200149.65032708697 6193748.923145034,200057.88967082606
 6193713.881831132,199998.3226113026 6193691.478994754,199907.66401800056
 6193654.858131102,199882.28317409966 6193643.648380099,199852.04880040025
 6193630.758025001,199781.7839378115 6193599.565799282,199765.854118679
 6193592.776127363,199526.86230389492 6193485.284914192,199499.21054238186
 6193472.7309163585,199394.03588748036 6193424.985559544,199020.4142805309
 6193258.156209193,198857.6985808384 6193193.65713112,198534.29319618578
 6193069.365861583,198394.4425199022 6193021.286667081,198375.74084544892
 6193015.421729742,198159.32462339773 6192945.244454814,197966.2409666168
 6192883.638157201,197677.7453742769 6192795.531507291,197673.94937964086
 6192794.6240622755,197522.10959419888 6192747.537881321,197285.61133600856
 6192673.195347736,197012.8340557687 6192588.2500511715,196679.29859745392
 6192495.844646442,196342.17865153556 6192413.388078894,196240.06528263088
 6192391.391954001,196167.58516217538 6192376.537460241,195831.57841116496
 6192314.817652284,194658.80531175964 6192153.185458943,194042.79664555693
 6192070.866634535,193426.9549585904 6191979.256582095,192988.79031087898
 6191898.6701241145,192768.21073987213 6191854.075693898,192551.63867053378
 6191805.583296708,192222.4001445636 6191732.811613842,191578.17198744477
 6191587.639761255,190985.30664337796 6191453.643633212,190757.43564572415
 6191397.979153161,190516.66271908736 6191332.637280303,190274.14207644516
 6191260.004051219,190008.6339589541 6191166.638582807,189832.66010790807
 6191103.045809532,189506.87248615248 6190971.846262171,189370.4170543381
 6190911.027078318,189254.22176984805 6190857.684643403,189119.83688056245
 6190793.237347289,188957.42174349504 6190710.242851276,188742.1298483009
 6190594.320718837,188531.26846884025 6190474.384973415,188113.51981574032
 6190218.475056823),(188204.74613844542
 6190253.283595123,188541.92174410916 6190454.426646578,188750.4565462122
 6190576.176527881,188965.8041011518 6190693.42564406,189127.42886983452
 6190774.471112138,189260.91207124476 6190839.825502848,189377.39678641086
 6190893.184626676,189514.19730864666 6190953.8356740605,189839.0164508324
 6191085.774195124,190014.7342670496 6191150.744545293,190279.73031488297
 6191241.219985933,190538.85982555154 6191318.658317842,190810.07863292028
 6191390.653580105,190989.77055495876 6191437.026580091,191582.42439199306
 6191569.291828281,192261.58460532286 6191718.22710756,192557.19351312437
 6191786.176333629,192775.04575660682 6191835.189502212,192992.80894449662
 6191879.380567987,193430.10530017983 6191959.126698984,194044.73360469672
 6192050.988580879,194660.00756226023 6192134.298603812,195836.8326911304
 6192296.182491913,196171.15851782984 6192357.71732437,196246.9002993656
 6192373.159914935,196347.23255641756 6192394.651880307,196685.8107876653
 6192475.612718563,197017.70984946546 6192570.168827414,197292.43522079417
 6192654.576207245,197526.96312399744 6192729.002600291,197682.89946670068
 6192776.592813748,197961.43196461452 6192863.690987247,198096.13968042345
 6192903.030817104,198165.8479455582 6192924.893825473,198382.62038997991
 6192996.7514260365,198540.39350428124 6193050.493779081,198873.33896929485
 6193177.994583501,199030.2215276698 6193242.980900124,199395.08229069386
 6193404.650589195,199538.8402811043 6193469.82350049,199773.4795037983
 6193575.297788921,199789.36479513452 6193581.331172849,199820.723495691
 6193595.36426899,199891.18873336315 6193625.817007487,199915.07789608737
 6193635.967944528,200004.9461210048 6193670.303074583,200064.95845849146
 6193695.092351473,200159.0122962627 6193730.92348808,200310.99679704275
 6193786.149447056,200422.96194088264 6193826.165802465,200463.87185374915
 6193839.611071189,200510.74849132219 6193855.42609571,200628.39092919254
 6193892.753703668,200721.8436417135 6193922.316747496,200893.4649006695
 6193972.56911555,200968.67234864942 6193992.670145828,201027.8497899551
 6194008.014860586,201083.55406314804 6194022.8553941585,201138.41230821097
 6194037.258971866,201189.69719761945 6194049.763381143,201411.9465609882
 6194103.663645866,201493.031678082 6194122.97504919,201642.9790321806
 6194159.31220363,201941.86073301145 6194230.306240591,202255.09151620558
 6194300.326034044,202664.54686724136 6194400.39852927,202837.5930156795
 6194439.106764922,203168.4679381644 6194523.263749096,203445.46422710526
 6194602.026162016,203544.5163100131 6194632.66739151,203672.2442937493
 6194674.956839473,203865.63964510447 6194740.862236623,204047.00135950488
 6194802.280273382,204104.97655030998 6194824.333053703,204333.71583999204
 6194906.039775093,204468.23431266664 6194958.197345543,204544.04288589687
 6194988.957519183,204614.67510280517 6195017.784777341,204737.99483470593
 6195070.144740824,204851.76335429668 6195121.025822879,204968.28146531
 6195172.478722892,205110.74814962727 6195237.900500616,205503.0602990809
 6195403.625594119,205734.4378606947 6195496.432383454,206084.40407585062
 6195621.465118841,206507.6630437448 6195761.897998581,206924.91075913614
 6195893.927863353,207384.72704780684 6196043.443147057,207720.80059051173
 6196161.860308602,208083.39043592356 6196298.485903498,208236.52152745883
 6196359.646195032,208345.10255877854 6196404.499596358,208731.15855284967
 6196561.471550474,208811.66480859133 6196592.422450956,208985.97999922454
 6196659.855791187,209181.13419853422 6196729.021332928,209374.61860548198
 6196791.294338468,209579.6579755741 6196852.542234097,209771.3835345674
 6196905.720492717,210481.1343439671 6197100.177870892,211234.67824104498
 6197305.4843564965,211596.0992318035 6197403.002889102,211707.1070280225
 6197433.032096752,211758.9262509868 6197446.735269826,211853.89290858255
 6197472.6452561505,211909.9088763497 6197488.736053101,211991.0162573417
 6197515.049699872,212032.62748300022 6197529.0388410585,212078.90299532298
 6197546.979275725,212142.61113990398 6197573.663009996,212210.04848742654
 6197605.760946121,212285.33385905004 6197644.584646139,212343.40923739687
 6197677.574001187,212396.99844026475 6197709.974985597,212446.14599544997
 6197742.981408434,212509.27527867886 6197788.497862243,212569.9666650594
 6197837.024353374,212630.29069712025 6197885.43341908),(196631.9766819177
 6268913.673198705,196283.42422429487 6268957.199294584,196174.40904696102
 6268969.509403638,195991.07697757357 6268986.5333305355,195876.45129790375
 6268988.245898784,195746.86427867127 6268985.566831778,195721.3387194324
 6268983.786439614,195652.521010224 6268976.308796625,195572.19286566757
 6268967.050771607,195481.43408482382 6268961.370486556,195393.74772192593
 6268960.709199883,195302.0204615123 6268964.507359918,195173.55776913685
 6268976.902260108,195047.6220292024 6268998.402622558,194880.38675818368
 6269047.372106385,194732.28730763233 6269108.8726181835,194617.03823881404
 6269169.780100242,194446.2407440899 6269280.862776473,194310.3864375258
 6269374.922168917),(196631.9766819177 6268913.673198705,196220.71795513103
 6268983.0573267415,196106.35944223907 6268998.402622558,195991.5445194349
 6269007.931980497,195870.78513582237 6269011.831898765,195757.01661623162
 6269010.05150107,195649.23708524558 6269002.845133285,195504.9224973812
 6268987.109838621,195374.35586662975 6268981.870398944,195278.09790294082
 6268987.957644698,195175.8398186981 6268996.622227694,195123.84248454857
 6269004.845959488,195079.53732721283 6269013.103611632,194983.84709292694
 6269036.164038138,194885.75235763993 6269066.3292057,194730.49506383055
 6269133.069385506,194622.70440089543 6269189.195300187,194523.87495696914
 6269247.1189913,194310.3864375258 6269374.922168917),(222375.4104281959
 6262244.687291328,222306.75969822367 6262289.144815342,222214.37565281437
 6262342.988882456,222115.24564626295 6262398.307325896,221924.88931700645
 6262495.356911591,221788.23351010866 6262561.994431308,221749.14923689113
 6262582.597442175,221482.4833966958 6262710.0796876205,221236.01091213044
 6262824.262984011,220819.9988430869 6263007.342401228,220407.61578944323
 6263180.818252401,219927.29445056838 6263381.409435056,219530.9191397008
 6263545.623919324,219012.6601183636 6263766.219603694,218879.58879906934
 6263822.32685951,218705.75228224657 6263893.838307869,218520.03797575616
 6263979.347814357,218490.1486924782 6263994.362057897,218408.25094310154
 6264037.557812361,218325.8745199145 6264082.9229123965,218244.90072231152
 6264132.050353388,218053.4089342489 6264260.657482187,217837.0038441468
 6264442.852849489,217784.0825582237 6264493.355096953,217728.20017384543
 6264546.501411833,217658.1579502383 6264620.205192584,217541.57304753052
 6264753.565079774,217384.59030161385 6264956.820506265,217233.96389862147
 6265182.18162379,217114.51808500028 6265370.05776213,217054.32763632835
 6265464.734680305,216838.23424080043 6265799.298788547,216701.3669268701
 6265999.426621184,216479.58510536267 6266315.416871801,216294.72795895135
 6266564.749343449,216136.38711524702 6266765.352984541,215902.29335805785
 6267053.485366645,215235.44508040982 6267830.493258173,214892.12463885426
 6268223.8306030845,214377.20520224093 6268825.044789955,214251.2694623065
 6268952.722895732,214128.18350133637 6269077.791658462,214009.2608893219
 6269184.023561346,213892.23070865095 6269278.014049706,213843.42824388717
 6269314.742350535,213670.8273734122 6269430.0661824485,213462.23691156376
 6269544.865912889,213305.5324643741 6269618.477608959,213177.59297360538
 6269668.671623153,212927.60279313088 6269747.659969178,212654.14646399723
 6269802.8233715175,212483.09293444428 6269824.614116857,212408.41982002018
 6269831.159830317,212191.34681297326 6269838.383861936,211998.31881593776
 6269841.673681193,211873.9415488744 6269845.557026199,210892.30401516115
 6269862.04006501,210446.35813504332 6269870.315512252,209374.51841794027
 6269887.171673696,209190.60748720073 6269888.273938942,208845.5170657416
 6269873.89362822,208584.40606813686 6269851.678809498,208322.51583409662
 6269819.798102936,208119.68058992218 6269787.374869348,207838.4764242293
 6269733.17815191,207666.2651719721 6269693.32784602,207500.0763041668
 6269651.188471549,207094.13864904008 6269527.942605048,207010.21488493102
 6269499.573248141,206915.03672030274 6269469.050436069,206405.47175119657
 6269260.463879191,205872.1289388569 6269025.413802074,205509.60588513955
 6268865.823577013,205338.81952236447 6268798.356409601,205229.83774087788
 6268760.79952401,205129.21605314984 6268728.482084657,205004.1708691418
 6268697.33470097,204937.22332737868 6268683.159881713,204672.08256420726
 6268635.854137745,204370.6739109354 6268613.6256161155,204261.52515021258
 6268613.47301777,204135.43356299106 6268617.254066456,203986.54374405506
 6268624.867035082,203844.71158083534 6268640.4999231035,203624.3657807591
 6268684.635011318,203495.53573406406 6268709.915720742,203397.38533903164
 6268732.63620819,203350.37511806964 6268743.369116401,202970.9426337008
 6268826.943839294,202600.93891020207 6268911.401098567,202196.83802667345
 6268999.894763305,202016.15536116686 6269030.53457528,201871.68492601535
 6269047.066894041,201731.35557592136 6269057.528901179,201616.9970630294
 6269060.801460366,201488.60116234847 6269057.8171576345,201368.87705000027
 6269051.84855534,201231.82049293566 6269038.114003561,201055.81324604238
 6269011.509731532,200931.7922013496 6268991.348869861,200526.58925486208
 6268901.057963869,200204.19687757565 6268843.136643355,199764.70752792383
 6268786.250018328,199346.39114542087 6268756.679297957,198995.5343743386
 6268745.810727753,198173.98540033516 6268752.711674767,197670.8101700005
 6268765.411466662,197477.55953398338 6268779.162531202,197360.328978229
 6268791.52324825,197084.12305767272 6268832.776636343,196819.97303796935
 6268881.422998699,196631.9766819177 6268913.673198705))'
 ) as way ) as t ) as t
 result (screen from pgAdmin)
 ![image](https://user-
 images.githubusercontent.com/1227612/186465718-4fb611c1-aa63-408a-92dd-
 3119f144aefb.png)
 Version: `POSTGIS="3.2.2 628da50" [EXTENSION] PGSQL="140"
 GEOS="3.9.0-CAPI-1.16.2" PROJ="7.2.1" GDAL="GDAL 3.2.2, released
 2021/03/05" LIBXML="2.9.10" LIBJSON="0.15" LIBPROTOBUF="1.3.3"
 WAGYU="0.5.0 (Internal)" TOPOLOGY RASTER`
Ticket URL: <https://trac.osgeo.org/postgis/ticket/5225>
