[postgis-tickets] [PostGIS] #5225: ST_SIMPLIFYPRESERVETOPOLOGY instability on some MULTILINESTRING
PostGIS trac at osgeo.org
Wed Aug 24 09:09:52 PDT 2022
  Reporter:  cactusbone  |      Owner:  pramsey
      Type:  defect      |     Status:  new
  Priority:  low         |  Milestone:  PostGIS GEOS
 Component:  postgis     |    Version:  3.2.x
Resolution:              |   Keywords:
Description changed by cactusbone:
Old description:
> I have a question.
> It seems ST_SIMPLIFYPRESERVETOPOLOGY (from postgis, which documentation
> says it is performed by the geos module) sends varying data with some
> MULTILINESTRING inputs
> It also seems that the longer the MULTILINESTRING, the greater the chance
> of variation.
> My question: is this a bug or something to be expected ?
> example SQL : (run a few times, check that diff is sometimes not empty)
> SELECT ST_ASTEXT(A), a,
>         ST_ASTEXT(ST_DIFFERENCE(A,A)) AS DIFF
> FROM (
>                 SELECT ST_SIMPLIFYPRESERVETOPOLOGY(WAY,1222) AS A
>         FROM (SELECT ST_GEOMFROMTEXT(
>         'MULTILINESTRING((194310.3864375258
> 6269374.922168917,194229.76886229333 6269419.62067134,194119.46237886624
> 6269472.9675241215,194042.57400657536
> 6269505.525209331,193958.79495780432 6269533.572399087,193858.273457618
> 6269561.687510971,193767.74844770491 6269582.053220367,193573.44027652525
> 6269621.462109578,193479.14153587425 6269645.72817361,193389.2065192624
> 6269674.369340893,193292.52554150842
> 6269711.7098361235,193217.87469098245 6269746.35423054,193155.7695470689
> 6269778.590772032,193093.35270858108 6269814.473358343,193040.4759504543
> 6269849.186005235,192970.65636582876
> 6269900.4158241125,192894.84779259854
> 6269962.719570645,192836.52751137194 6270015.289773788,192778.54118861773
> 6270073.778748463,192625.0316108138 6270239.666467283,192568.5592331344
> 6270298.716632978,192512.55439731627 6270357.292362772,192453.93355346454
> 6270412.985471226,192393.4425421675 6270465.931574068,192347.57891196062
> 6270503.173810453,192301.4481149759 6270537.770570481,192237.51733141334
> 6270581.932522803,192171.7275123545 6270622.940256508,192058.01465250918
> 6270680.941609077,191985.70151128987 6270713.673542163,191909.31407670752
> 6270741.572103306,191822.22883905994 6270769.640353469,191449.74269091658
> 6270869.872750556,191380.12348137447 6270888.596497581,191124.12204839717
> 6270957.488032467,190824.78393765405 6271035.233363513,190464.67651688692
> 6271132.212507669,189704.9321241719 6271338.029749751,189668.1076366175
> 6271348.087531609,189348.69862168434 6271433.655485189,189138.50515916848
> 6271492.849680412,188856.3881736511 6271578.910977546,188790.843257472
> 6271599.11193322,188320.0842628563 6271744.641655042,187820.53804792152
> 6271896.195374541,187692.69874469453 6271935.632014541,187619.1610890765
> 6271957.055092225,187607.1385840708 6271960.379660216,187539.91274358073
> 6271978.970125731,187150.99583859628 6272106.017375912,187088.7459793447
> 6272125.86338048,186794.37271789095 6272204.755950004,186715.3581433259
> 6272226.9430276,186386.019429814 6272324.902724626,186341.98143925617
> 6272338.33728588,186228.48008644333 6272372.704076362,186148.8198588317
> 6272397.130705383,185908.72598108876
> 6272470.3262004275,184829.45012200074
> 6272795.583095043,184445.90994842158 6272911.174952552,184084.39990207044
> 6273020.101453073,183928.0962050476 6273064.4969112985,182967.9099372102
> 6273321.187642189,182437.8733137471 6273462.573600028,182195.7756851699
> 6273527.329633407,181451.6494170132 6273725.926944476,181349.51378421034
> 6273753.394341246,180894.95177550512 6273876.39644083,180646.27516502203
> 6273951.606744456,180527.5417961419 6273987.405251751,180453.04679290304
> 6274011.0052037,180394.06972668075 6274031.602196206,180335.10379240758
> 6274053.403845108,180288.73922449216 6274073.542850133,180239.85883608487
> 6274096.091127523,180172.97808601626 6274130.278434857,180095.22142169712
> 6274176.291545229,180053.242841719 6274204.93110029,180002.03587595408
> 6274241.205747136,179936.64680706212 6274291.97015417,179876.75692101536
> 6274344.431552935,179788.01302295495 6274433.304484509,179730.2493391823
> 6274498.560004091,179617.97250076823 6274621.352372588,179525.2990246828
> 6274717.490354004,179439.85018354992 6274796.916150924,179358.47563578002
> 6274869.0125483805,179299.48743760868
> 6274917.065843037,178963.19125592217 6275182.958891726,178872.84435719438
> 6275259.249852135,178787.77400233014 6275335.965722783,178712.68900579007
> 6275410.527225275,178494.07978977027 6275641.953757119,177877.44773441908
> 6276298.935552551,177659.651150682 6276529.351169971,177237.7168847283
> 6276979.118426997,176836.78860668722 6277406.437319403,176724.22233759708
> 6277523.229470048,176645.04078379582 6277599.507615941,176614.50584747124
> 6277629.007448478,176501.08241830196 6277727.538993572,176424.34989329817
> 6277788.915985597,176350.85676547643 6277843.928209411,176274.5249906395
> 6277897.243390758,176156.33708726428 6277973.049636971,176064.33152812364
> 6278026.925783878,175960.02516525035
> 6278082.7034044145,175832.28604956504 6278145.356064293,175696.1868401212
> 6278204.512415867,175593.32763062822 6278243.808757859,175473.42540709476
> 6278283.529652145,175334.88830080253 6278323.9127527755,175224.9714355933
> 6278350.359629461,175125.2736996388 6278371.238801115,175012.75195834498
> 6278390.997674488,174923.1286363073 6278402.914130773,174785.29284280707
> 6278416.494158423,174676.0216306444 6278421.977100771,174100.86721756277
> 6278440.191358953,173698.97045995184 6278452.939665534,173540.2399980297
> 6278455.129456483,173327.2190204477 6278456.521416915,173064.77218895347
> 6278454.569277345,172730.62447343933 6278444.333283348,172564.44673758312
> 6278438.375023896,172464.9493767121 6278432.926021066,172257.23833884092
> 6278419.142266356,172119.8255594057 6278408.668664824,171877.5052918469
> 6278387.432925874,171702.3329411346 6278369.490380695,171082.127530129
> 6278305.138576055,170505.1140815511 6278245.047911142,170402.29939985444
> 6278235.083765929,170292.12649981634
> 6278227.3433137005,170194.47704249248
> 6278221.521004526,170041.15670782293 6278214.340727894,169855.24202624903
> 6278210.2498401515,169705.57297087752
> 6278210.131017717,169622.81806142177 6278211.387140695,169526.35972264942
> 6278213.848463291,169378.70555006122 6278219.6028685635,169239.1331725046
> 6278228.310869838,169075.88313925627 6278241.890616841,168886.91830363468
> 6278260.9871729845,168734.08777472458
> 6278281.526628219,168578.49652244285 6278304.18798594,168370.69642897905
> 6278340.038887247,168134.54326121017 6278389.571774863,168031.3500932448
> 6278412.437122872,167946.24634253338 6278433.265522698,167775.02583374424
> 6278477.027397188,167221.3672143348 6278632.35162899,166564.38184357106
> 6278819.168873168,166459.41869570207 6278848.757844283,166041.4919314169
> 6278967.029884336,165837.27632555665 6279028.602620861,165678.90208600505
> 6279078.563955241,165512.601898709 6279134.518284295,165331.74112201715
> 6279198.536874455,165093.95155773364 6279292.927407073,164927.9074052664
> 6279363.551229157,164822.33200019805 6279410.390767568,164716.75659512973
> 6279459.743182722,164550.01112987046 6279542.473213391,164382.6311435137
> 6279628.973055033,164171.31335414085 6279747.323929873,163970.61544418964
> 6279867.83266412,163782.9196507631 6279988.529877836,163630.74590684866
> 6280090.722325979,163479.24007987903
> 6280199.5886100065,163379.94309409146 6280273.819513355,163247.127809626
> 6280378.001954607,163115.57043540652 6280484.698602745,163059.6880510283
> 6280531.968840754,162875.54334935802 6280694.275525646,162783.88288063885
> 6280779.377839527,162689.60640388602 6280869.388223054,162596.5767054301
> 6280961.284363624,162447.34179607264 6281113.020460335,162357.3288558172
> 6281210.998327417,162269.20834690524 6281309.588642108,162101.57232571964
> 6281505.567054671,162010.35713496362 6281621.668706291,161854.3873964132
> 6281821.407357725,161723.431147444 6281998.836028648,161601.6030967198
> 6282162.155893708,161215.4580470561 6282692.4535129145,161104.21647990638
> 6282844.135795295,160829.9141226427 6283218.198562569,160702.65368076783
> 6283385.584448484,160574.558342712 6283548.625397618,160460.78982312127
> 6283687.600801415,160371.35574421793 6283794.543099508,160231.61638742514
> 6283954.27963882,160087.1570842227 6284113.3397397725,159955.12103619284
> 6284254.006129454,159817.01807591468 6284395.35434521,159744.50455961193
> 6284466.955143437,159590.92819011354 6284616.189126318,159504.75577229046
> 6284696.999112322,159389.42877982865 6284802.459260868,159281.02585969414
> 6284898.169562886,159107.41198185296 6285047.326225455,158927.04101092063
> 6285194.650745688,158757.7018015259
> 6285325.923272096),(159612.02323361888 6284563.8677484,159743.35796885678
> 6284436.870843225,159804.50576514952 6284376.057057197,159943.10966313622
> 6284232.942543113,160062.97849082242 6284104.710601479,160212.85905322648
> 6283940.435912305,160278.87151126692 6283866.104831385,160358.70985006384
> 6283774.160091971,160552.72859056742 6283538.077492254,160684.97614562983
> 6283370.620643681,160811.55753861085 6283201.910250149,161138.15779264923
> 6282756.753832039,161584.226124207 6282147.686750394,161704.9855078195
> 6281984.995507281,161836.4315625482 6281805.648176685,161986.86872240627
> 6281612.872298865,162079.47540679717 6281496.176424808,162250.50667245197
> 6281295.324729303,162338.95000788724
> 6281195.4440528685,162430.53255296283
> 6281096.515461827,162580.01236520006 6280943.94763531,162596.9329278006
> 6280927.239206045,162672.95300806337 6280852.187522901,162769.03286056704
> 6280761.03967867,162860.51521810095 6280675.92056996,163020.51472221813
> 6280534.855322192,163099.85212330648 6280467.05722754,163230.44101795607
> 6280360.683402378,163363.5346011485 6280256.823770906,163467.76304037822
> 6280179.112405164,163648.79079630628 6280051.332500253,163770.30715245623
> 6279968.682376769,163963.03458686662 6279844.963376556,164159.33537693147
> 6279726.662066799,164358.04066799747 6279615.085483966,164543.98874541855
> 6279518.976647851,164709.18686975574 6279437.961534301,164812.15739873954
> 6279390.289969728,164916.3747060202 6279343.246819833,165085.1461860119
> 6279271.332933188,165186.24654755034 6279231.420650729,165324.78365384255
> 6279176.721946358,165504.15274935775 6279112.499804153,165669.88520725077
> 6279057.46234304,166039.34346524457 6278943.365158198,166557.42437539648
> 6278795.793149981,166583.84049056174 6278788.238917756,167189.73021505136
> 6278618.109211654,167769.8717413205 6278455.129456483,167928.78031442792
> 6278413.489575424,168027.06429284927 6278389.860349767,168103.07324116293
> 6278372.376123329,168372.9228187949 6278316.477766411,168581.99195445376
> 6278280.134696615,168742.52579212672 6278256.30214721,168872.51356152602
> 6278239.7348305425,169075.40446544587 6278218.839009227,169235.6711363409
> 6278205.5648425175,169378.816869552 6278196.09300741,169525.63614595926
> 6278190.508364088,169700.730573028 6278186.570259162,169851.34584407127
> 6278186.315640371,170044.14007017616 6278190.372567335,170194.27666740905
> 6278198.07903647,170293.64044489112 6278203.986202594,170401.4199758772
> 6278212.354695007,170499.50357921512 6278220.723195708,171085.58956629265
> 6278281.98494721,171705.6279980621 6278347.032546713,171877.6166113377
> 6278364.924119366,172140.3417415589 6278387.178301031,172250.04709973568
> 6278395.292349814,172467.320481866 6278410.0096924985,172565.3706893567
> 6278415.8321315665,172732.4612450374 6278421.960125714,172873.4807759743
> 6278427.290295983,173072.53115746178 6278431.551039599,173317.93497491552
> 6278433.367373186,173696.47690335807
> 6278430.8211112525,174099.07497376102
> 6278417.376860977,174673.76184498132 6278398.178101262,174785.28171085802
> 6278392.304749357,174919.56641260194 6278379.845108834,174999.9724808019
> 6278368.6416330505,175050.34455038584
> 6278360.748284028,175121.71147593344 6278348.424489337,175222.12165662897
> 6278327.290751028,175329.82326397148 6278301.030669535,175465.9781331607
> 6278262.582798295,175584.2884879758 6278220.960840882,175688.11617703867
> 6278181.596706854,175823.68105292672 6278123.068570675,175954.45919071068
> 6278060.959254745,176051.79695346032 6278008.423854744,176149.13471620996
> 6277951.679200016,176247.7081253074 6277886.770436193,176332.1439590741
> 6277828.889349307,176413.15115252437 6277768.157069202,176490.89668489437
> 6277706.525623646,176554.3265307484 6277652.481784668,176627.05155408365
> 6277584.842605183,176657.0632888015 6277557.413671906,176711.01984598898
> 6277504.507992098,176760.8241861699 6277453.130223573,176820.9701070455
> 6277390.431777683,177286.2855785614 6276892.20443966,177861.65149867552
> 6276284.154003537,178398.8570973457 6275710.3070790805,178695.34542912449
> 6275395.866013061,178775.66244173184 6275316.536399705,178858.2392400023
> 6275241.313948316,178944.2780744364 6275168.569570697,179282.555743059
> 6274899.63970496,179341.2990383506 6274851.1623121975,179428.87408175768
> 6274776.724518886,179508.23374674423 6274703.390274527,179556.8135725264
> 6274653.3699657265,179603.24493213627
> 6274605.046692117,179711.58106057628 6274482.339396265,179772.46169009112
> 6274415.709673763,179860.53767120678 6274326.463656855,179922.175273259
> 6274271.881528828,179987.39736291478 6274218.419549947,180033.8621183719
> 6274184.910548036,180080.6942281486 6274154.099350101,180113.37763064553
> 6274134.21464984,180161.62349795533 6274106.525452321,180227.2797336252
> 6274070.115652964,180274.1897670455 6274047.771040161,180324.66202417118
> 6274025.0023307055,180385.19756326458
> 6274002.216716409,180442.14861475438 6273980.992048297,180512.50253293573
> 6273958.885196452,180622.23015501068 6273925.954068508,180758.819170214
> 6273887.695757958,181342.9348023045 6273730.813046822,181445.46005332508
> 6273703.7698630225,182199.37130472253 6273502.49257374,182963.31244224045
> 6273298.794114928,183938.78287616375 6273037.642466021,184079.81353904973
> 6272997.267655166,184238.04306326332 6272948.394035007,184438.81889685805
> 6272888.1548454845,185007.9731893859 6272716.159139401,185901.1673876639
> 6272446.119879661,185976.12993276407 6272423.898300745,186121.39073630024
> 6272380.829315267,186199.8821092586 6272357.556209243,186287.8356389343
> 6272331.484299947,186334.95717938713 6272317.506939917,186380.0304412093
> 6272304.157225641,186534.40831104142 6272258.391783233,187140.94368857768
> 6272080.624735446,187160.71403014255 6272073.754996126,187539.9238755298
> 6271955.324960422,187600.55960216493 6271936.378344127,187674.38668845902
> 6271913.293043615,188332.00658032027 6271715.4507022835,188782.3273164263
> 6271579.470701108,188845.1115092337 6271560.0669725705,189141.16569499843
> 6271470.308346317,189362.03469668137 6271405.008357309,189660.70489047974
> 6271327.564920277,189695.74826618144 6271318.185594663,190457.64112506877
> 6271112.86068684,190816.96930940036 6271015.305118234,190957.20960390175
> 6270978.976471972,191363.30310631558 6270868.855156802,191382.17176000506
> 6270863.7502299575,191434.1802261037 6270849.63961765,191820.4365952582
> 6270744.9131529685,191901.21001777778 6270719.338045002,191985.0892540905
> 6270686.9791996395,192040.4595688111 6270663.354607214,192160.21707700647
> 6270601.4866406545,192224.78238166656
> 6270561.2591377525,192288.2122275206 6270517.639987497,192333.53039222254
> 6270484.077816298,192375.79840287674 6270448.616364298,192436.43412951185
> 6270396.28089196,192495.3110081924 6270340.316552183,192562.12496656654
> 6270270.209020157,192607.55445075926 6270222.555224079,192756.95633935288
> 6270062.772818872,192822.64597087 6269995.906593106,192877.8047785581
> 6269946.151545336,192950.19584342095 6269885.764165967,193028.06382723083
> 6269828.853568001,193081.4526550153 6269795.378919636,193143.23497240557
> 6269758.885938274,193203.2473098922 6269726.344235049,193277.89816041818
> 6269691.106408963,193383.50696133377 6269650.425386225,193473.76480446896
> 6269622.140405321,193562.74247346004 6269598.857935085,193760.70192393768
> 6269560.042655652,193859.23080523883 6269538.235634942,193947.90791160477
> 6269513.155934936,194042.86343725142 6269480.309949474,194138.18631721768
> 6269439.375585526,194224.10270021195 6269397.305304478,194320.43858754443
> 6269340.66930346,194475.90738838635 6269233.418035558,194494.54227114512
> 6269220.615801189,194664.23770291038 6269112.128240871,194828.89036174273
> 6269037.198367567,195010.69735410626 6268978.30961655,195148.03220989797
> 6268949.297773971,195257.4258735005 6268935.122532327,195372.96437299484
> 6268930.30702502,195454.81759457514 6268931.917845822,195574.4415193816
> 6268933.816919159,195727.56147896775 6268938.327220044,195820.25721895127
> 6268939.463273653,195941.77357510122 6268941.85407354,195965.09500842242
> 6268942.464490643,196037.35248989632 6268942.277974303,196407.6901718674
> 6268913.825802466,196571.5524623151 6268895.682930008,196777.5714439262
> 6268865.060562559,197081.7074247225 6268811.0732258195,197359.3048389137
> 6268768.921292356,197475.16616493132 6268757.28970169,197670.76564220418
> 6268743.233471346,198172.98352491803 6268730.66935761,198995.62342993126
> 6268720.665555703,199347.37075693987 6268728.414262247,199766.67788291088
> 6268759.137868818,200210.07454668958 6268814.12526456,200531.89919457294
> 6268876.590566079,200935.03159853164 6268964.35475524,201114.24484675977
> 6268993.722728287,201231.23049963443 6269013.934464141,201370.8140091401
> 6269028.9067794895,201490.69396877536
> 6269036.316644114,201616.45159752454 6269038.826164957,201729.85276279564
> 6269034.231029387,201869.69230713014 6269026.32943679,202013.5616170314
> 6269008.321972242,202197.13858929859 6268977.800933472,202565.27214535192
> 6268895.954225012,202962.90536646548
> 6268805.5965146255,203348.71645765682
> 6268718.393507428,203397.96420038375 6268706.863719617,203489.92523172806
> 6268685.499742586,203619.6903621458 6268658.896579973,203844.1883792286
> 6268616.202833018,204131.44832522067 6268588.548658428,204371.29730008382
> 6268588.718211642,204675.25516969484 6268610.488872914,204941.39780828342
> 6268652.775660202,205011.76285841386 6268673.444379371,205136.97502165815
> 6268706.69416403,205236.40559083468 6268736.841200623,205346.28906019675
> 6268772.973701606,205514.38149129457 6268842.237984302,205880.70053964798
> 6269000.77648296,206415.36805392808 6269237.284144589,206920.04609738846
> 6269441.325643939,207099.98292230672 6269503.846450623,207507.6237656426
> 6269626.668030797,207670.59550016397 6269669.010772909,207843.78636394013
> 6269708.640515808,208195.21086442543 6269775.453596626,208326.70144695044
> 6269795.412835121,208401.7530476433 6269804.53610511,208587.40056243923
> 6269826.15727683,208844.6265098152 6269851.678809498,209191.79860575218
> 6269865.550345944,209374.51841794027 6269862.04006501,210445.4453152188
> 6269847.066274299,210891.858737198 6269838.536482385,211903.04046376777
> 6269819.865934097,211997.6842948402 6269818.136239613,212192.64925101554
> 6269814.931218413,212407.40681265394 6269808.080277704,212479.0297730303
> 6269801.093680517,212650.52858054647 6269780.625697236,212924.0071735783
> 6269723.664934162,213171.13644313932 6269647.220428596,213310.74221654324
> 6269590.3114362415,213451.52797654943
> 6269524.686822251,213657.66940960046 6269410.09084941,213828.21086949573
> 6269294.6825062595,213881.0430998262 6269257.089502756,214002.68190741603
> 6269159.029694296,214111.9642515278 6269056.952388293,214243.57728549268
> 6268925.338916485,214374.81183318887 6268788.657730618,214873.33390880836
> 6268207.147302767,215218.01244815157 6267810.013090632,215882.93489860886
> 6267037.414654649,216116.60564173307 6266750.062595269,216274.74611035397
> 6266549.306755744,216459.60325676532
> 6266299.9747393485,216683.26637766714 6265986.527581096,216817.5844752583
> 6265785.0440774225,217058.769284011 6265410.989382424,217213.72601519522
> 6265167.233065622,217368.43784349976 6264940.143649308,217465.0075017629
> 6264806.035119937,217572.3306228367 6264677.623069013,217658.02436684936
> 6264585.649580556,217711.70262530987 6264529.503367279,217716.7120023956
> 6264524.385318675,217819.73819112475
> 6264423.8213760685,218037.39005952372
> 6264242.168710179,218235.13800296892 6264110.545412234,218316.47915489157
> 6264061.960376094,218399.21180044912 6264015.256642067,218491.45113052044
> 6263968.7056804495,218519.58156584387 6263954.80992066,218626.33695751466
> 6263902.701024731,218868.96891964765 6263798.060552794,219003.18682969714
> 6263742.902412033,219524.27336610042 6263522.578458384,219917.03079351725
> 6263360.025015918,220398.06457713316 6263157.553507509,220812.79647203258
> 6262984.230630194,221226.7046027001 6262802.134449159,221473.62236522866
> 6262688.324208363,221777.62476263603 6262540.71374249,221856.95103177536
> 6262498.677762082,221929.31983274 6262464.012213491,222114.2103749986
> 6262367.962615812,222255.61952415327 6262288.670419796,222381.59979188404
> 6262211.056278395,222434.3429666219 6262170.733124265,222484.49239722424
> 6262128.885348189,222542.9351298907 6262075.178181773,222597.90469444444
> 6262018.862263656,222674.04722614703
> 6261927.527586906),(212490.06153456794
> 6198000.715026029,212379.49901631207 6197893.050431567,212340.8711530068
> 6197854.040638241,212310.31395278405 6197824.245347578,212241.1066253579
> 6197762.149741283,212189.75494425494 6197720.618408016,212145.14922429406
> 6197687.427115726,212111.6309256162 6197664.038597945,212062.349787042
> 6197631.318320755,212029.2545024292 6197610.889228954,211996.00337052924
> 6197590.880536372,211946.154502552 6197563.8268411225,211885.16255354637
> 6197533.5785913365,211819.5842415201 6197503.4481459,211775.4015356242
> 6197485.4573616,211727.4896267868 6197467.0294574825,211667.66653243446
> 6197446.92022078,211615.80278167388 6197431.636560121,211558.41758416998
> 6197414.469796878,211474.1153337922 6197390.611248074,211228.5556690513
> 6197324.248180438,210481.3347190506 6197120.454419101,209765.6617127406
> 6196925.240006449,209577.96591931404 6196872.246564336,209373.60559811577
> 6196811.015339376,209173.5422092621 6196747.19545404,208980.7702470554
> 6196679.374741058,208855.96996592707 6196631.56095884,208734.5204014716
> 6196583.814693298,208336.28605510772 6196426.169858823,208073.10451497426
> 6196315.784907852,207715.27914376836
> 6196180.6720451135,207378.07014225743
> 6196062.170566912,206998.59313009222
> 6195938.5266493885,206917.69725613273
> 6195916.252443212,206501.23990912602 6195782.726103228,206074.01796735957
> 6195639.6536853695,205728.7828305624 6195515.713326804,205494.16587176654
> 6195425.326928047,205105.83896008326 6195256.49167308,205032.43488785418
> 6195226.503762168,204922.08387663082 6195178.126626321,204769.09750043362
> 6195112.066561723,204479.92285919993 6194989.764344907,204439.89237031064
> 6194973.157197529,204396.65588008653 6194955.844112794,204320.33523719865
> 6194926.243862112,204097.5515402741 6194843.007365857,204040.51143319166
> 6194821.66049573,203908.72028804146 6194776.042245602,203860.04027471755
> 6194759.502748834,203805.86107854848 6194742.34137406,203665.11984633855
> 6194695.412502371,203435.89075089706 6194625.322226611,203163.3138457406
> 6194546.509174163,202803.61830708943 6194456.637300373,202659.47069846117
> 6194421.677112061,202233.5177988898 6194319.839574057,201938.05360642634
> 6194250.307034981,201636.93438383052 6194178.287587824,201488.12248853804
> 6194143.177277796,201408.89640694048 6194124.672572378,201340.34586451
> 6194105.764536182,201184.33159816323 6194069.242732725,201132.23407647194
> 6194055.343311639,201081.4835206193 6194042.704438166,201023.70870489758
> 6194027.695800286,200964.11938147596 6194012.888872159,200889.20136417207
> 6193991.880221502,200718.41500139705 6193941.896648272,200622.92514219458
> 6193909.728491724,200503.95800238382 6193874.636095934,200456.98117726902
> 6193859.07313529,200414.7242985639 6193844.804311923,200306.24345478584
> 6193806.552554789,200149.65032708697 6193748.923145034,200057.88967082606
> 6193713.881831132,199998.3226113026 6193691.478994754,199907.66401800056
> 6193654.858131102,199882.28317409966 6193643.648380099,199852.04880040025
> 6193630.758025001,199781.7839378115 6193599.565799282,199765.854118679
> 6193592.776127363,199526.86230389492 6193485.284914192,199499.21054238186
> 6193472.7309163585,199394.03588748036 6193424.985559544,199020.4142805309
> 6193258.156209193,198857.6985808384 6193193.65713112,198534.29319618578
> 6193069.365861583,198394.4425199022 6193021.286667081,198375.74084544892
> 6193015.421729742,198159.32462339773 6192945.244454814,197966.2409666168
> 6192883.638157201,197677.7453742769 6192795.531507291,197673.94937964086
> 6192794.6240622755,197522.10959419888
> 6192747.537881321,197285.61133600856 6192673.195347736,197012.8340557687
> 6192588.2500511715,196679.29859745392
> 6192495.844646442,196342.17865153556 6192413.388078894,196240.06528263088
> 6192391.391954001,196167.58516217538 6192376.537460241,195831.57841116496
> 6192314.817652284,194658.80531175964 6192153.185458943,194042.79664555693
> 6192070.866634535,193426.9549585904 6191979.256582095,192988.79031087898
> 6191898.6701241145,192768.21073987213
> 6191854.075693898,192551.63867053378 6191805.583296708,192222.4001445636
> 6191732.811613842,191578.17198744477 6191587.639761255,190985.30664337796
> 6191453.643633212,190757.43564572415 6191397.979153161,190516.66271908736
> 6191332.637280303,190274.14207644516 6191260.004051219,190008.6339589541
> 6191166.638582807,189832.66010790807 6191103.045809532,189506.87248615248
> 6190971.846262171,189370.4170543381 6190911.027078318,189254.22176984805
> 6190857.684643403,189119.83688056245 6190793.237347289,188957.42174349504
> 6190710.242851276,188742.1298483009 6190594.320718837,188531.26846884025
> 6190474.384973415,188113.51981574032
> 6190218.475056823),(188204.74613844542
> 6190253.283595123,188541.92174410916 6190454.426646578,188750.4565462122
> 6190576.176527881,188965.8041011518 6190693.42564406,189127.42886983452
> 6190774.471112138,189260.91207124476 6190839.825502848,189377.39678641086
> 6190893.184626676,189514.19730864666 6190953.8356740605,189839.0164508324
> 6191085.774195124,190014.7342670496 6191150.744545293,190279.73031488297
> 6191241.219985933,190538.85982555154 6191318.658317842,190810.07863292028
> 6191390.653580105,190989.77055495876 6191437.026580091,191582.42439199306
> 6191569.291828281,192261.58460532286 6191718.22710756,192557.19351312437
> 6191786.176333629,192775.04575660682 6191835.189502212,192992.80894449662
> 6191879.380567987,193430.10530017983 6191959.126698984,194044.73360469672
> 6192050.988580879,194660.00756226023 6192134.298603812,195836.8326911304
> 6192296.182491913,196171.15851782984 6192357.71732437,196246.9002993656
> 6192373.159914935,196347.23255641756 6192394.651880307,196685.8107876653
> 6192475.612718563,197017.70984946546 6192570.168827414,197292.43522079417
> 6192654.576207245,197526.96312399744 6192729.002600291,197682.89946670068
> 6192776.592813748,197961.43196461452 6192863.690987247,198096.13968042345
> 6192903.030817104,198165.8479455582 6192924.893825473,198382.62038997991
> 6192996.7514260365,198540.39350428124
> 6193050.493779081,198873.33896929485 6193177.994583501,199030.2215276698
> 6193242.980900124,199395.08229069386 6193404.650589195,199538.8402811043
> 6193469.82350049,199773.4795037983 6193575.297788921,199789.36479513452
> 6193581.331172849,199820.723495691 6193595.36426899,199891.18873336315
> 6193625.817007487,199915.07789608737 6193635.967944528,200004.9461210048
> 6193670.303074583,200064.95845849146 6193695.092351473,200159.0122962627
> 6193730.92348808,200310.99679704275 6193786.149447056,200422.96194088264
> 6193826.165802465,200463.87185374915 6193839.611071189,200510.74849132219
> 6193855.42609571,200628.39092919254 6193892.753703668,200721.8436417135
> 6193922.316747496,200893.4649006695 6193972.56911555,200968.67234864942
> 6193992.670145828,201027.8497899551 6194008.014860586,201083.55406314804
> 6194022.8553941585,201138.41230821097
> 6194037.258971866,201189.69719761945 6194049.763381143,201411.9465609882
> 6194103.663645866,201493.031678082 6194122.97504919,201642.9790321806
> 6194159.31220363,201941.86073301145 6194230.306240591,202255.09151620558
> 6194300.326034044,202664.54686724136 6194400.39852927,202837.5930156795
> 6194439.106764922,203168.4679381644 6194523.263749096,203445.46422710526
> 6194602.026162016,203544.5163100131 6194632.66739151,203672.2442937493
> 6194674.956839473,203865.63964510447 6194740.862236623,204047.00135950488
> 6194802.280273382,204104.97655030998 6194824.333053703,204333.71583999204
> 6194906.039775093,204468.23431266664 6194958.197345543,204544.04288589687
> 6194988.957519183,204614.67510280517 6195017.784777341,204737.99483470593
> 6195070.144740824,204851.76335429668 6195121.025822879,204968.28146531
> 6195172.478722892,205110.74814962727 6195237.900500616,205503.0602990809
> 6195403.625594119,205734.4378606947 6195496.432383454,206084.40407585062
> 6195621.465118841,206507.6630437448 6195761.897998581,206924.91075913614
> 6195893.927863353,207384.72704780684 6196043.443147057,207720.80059051173
> 6196161.860308602,208083.39043592356 6196298.485903498,208236.52152745883
> 6196359.646195032,208345.10255877854 6196404.499596358,208731.15855284967
> 6196561.471550474,208811.66480859133 6196592.422450956,208985.97999922454
> 6196659.855791187,209181.13419853422 6196729.021332928,209374.61860548198
> 6196791.294338468,209579.6579755741 6196852.542234097,209771.3835345674
> 6196905.720492717,210481.1343439671 6197100.177870892,211234.67824104498
> 6197305.4843564965,211596.0992318035 6197403.002889102,211707.1070280225
> 6197433.032096752,211758.9262509868 6197446.735269826,211853.89290858255
> 6197472.6452561505,211909.9088763497 6197488.736053101,211991.0162573417
> 6197515.049699872,212032.62748300022
> 6197529.0388410585,212078.90299532298
> 6197546.979275725,212142.61113990398 6197573.663009996,212210.04848742654
> 6197605.760946121,212285.33385905004 6197644.584646139,212343.40923739687
> 6197677.574001187,212396.99844026475 6197709.974985597,212446.14599544997
> 6197742.981408434,212509.27527867886 6197788.497862243,212569.9666650594
> 6197837.024353374,212630.29069712025 6197885.43341908),(196631.9766819177
> 6268913.673198705,196283.42422429487 6268957.199294584,196174.40904696102
> 6268969.509403638,195991.07697757357
> 6268986.5333305355,195876.45129790375
> 6268988.245898784,195746.86427867127 6268985.566831778,195721.3387194324
> 6268983.786439614,195652.521010224 6268976.308796625,195572.19286566757
> 6268967.050771607,195481.43408482382 6268961.370486556,195393.74772192593
> 6268960.709199883,195302.0204615123 6268964.507359918,195173.55776913685
> 6268976.902260108,195047.6220292024 6268998.402622558,194880.38675818368
> 6269047.372106385,194732.28730763233
> 6269108.8726181835,194617.03823881404 6269169.780100242,194446.2407440899
> 6269280.862776473,194310.3864375258 6269374.922168917),(196631.9766819177
> 6268913.673198705,196220.71795513103
> 6268983.0573267415,196106.35944223907 6268998.402622558,195991.5445194349
> 6269007.931980497,195870.78513582237 6269011.831898765,195757.01661623162
> 6269010.05150107,195649.23708524558 6269002.845133285,195504.9224973812
> 6268987.109838621,195374.35586662975 6268981.870398944,195278.09790294082
> 6268987.957644698,195175.8398186981 6268996.622227694,195123.84248454857
> 6269004.845959488,195079.53732721283 6269013.103611632,194983.84709292694
> 6269036.164038138,194885.75235763993 6269066.3292057,194730.49506383055
> 6269133.069385506,194622.70440089543 6269189.195300187,194523.87495696914
> 6269247.1189913,194310.3864375258 6269374.922168917),(222375.4104281959
> 6262244.687291328,222306.75969822367 6262289.144815342,222214.37565281437
> 6262342.988882456,222115.24564626295 6262398.307325896,221924.88931700645
> 6262495.356911591,221788.23351010866 6262561.994431308,221749.14923689113
> 6262582.597442175,221482.4833966958 6262710.0796876205,221236.01091213044
> 6262824.262984011,220819.9988430869 6263007.342401228,220407.61578944323
> 6263180.818252401,219927.29445056838 6263381.409435056,219530.9191397008
> 6263545.623919324,219012.6601183636 6263766.219603694,218879.58879906934
> 6263822.32685951,218705.75228224657 6263893.838307869,218520.03797575616
> 6263979.347814357,218490.1486924782 6263994.362057897,218408.25094310154
> 6264037.557812361,218325.8745199145 6264082.9229123965,218244.90072231152
> 6264132.050353388,218053.4089342489 6264260.657482187,217837.0038441468
> 6264442.852849489,217784.0825582237 6264493.355096953,217728.20017384543
> 6264546.501411833,217658.1579502383 6264620.205192584,217541.57304753052
> 6264753.565079774,217384.59030161385 6264956.820506265,217233.96389862147
> 6265182.18162379,217114.51808500028 6265370.05776213,217054.32763632835
> 6265464.734680305,216838.23424080043 6265799.298788547,216701.3669268701
> 6265999.426621184,216479.58510536267 6266315.416871801,216294.72795895135
> 6266564.749343449,216136.38711524702 6266765.352984541,215902.29335805785
> 6267053.485366645,215235.44508040982 6267830.493258173,214892.12463885426
> 6268223.8306030845,214377.20520224093 6268825.044789955,214251.2694623065
> 6268952.722895732,214128.18350133637 6269077.791658462,214009.2608893219
> 6269184.023561346,213892.23070865095 6269278.014049706,213843.42824388717
> 6269314.742350535,213670.8273734122 6269430.0661824485,213462.23691156376
> 6269544.865912889,213305.5324643741 6269618.477608959,213177.59297360538
> 6269668.671623153,212927.60279313088 6269747.659969178,212654.14646399723
> 6269802.8233715175,212483.09293444428
> 6269824.614116857,212408.41982002018 6269831.159830317,212191.34681297326
> 6269838.383861936,211998.31881593776 6269841.673681193,211873.9415488744
> 6269845.557026199,210892.30401516115 6269862.04006501,210446.35813504332
> 6269870.315512252,209374.51841794027 6269887.171673696,209190.60748720073
> 6269888.273938942,208845.5170657416 6269873.89362822,208584.40606813686
> 6269851.678809498,208322.51583409662 6269819.798102936,208119.68058992218
> 6269787.374869348,207838.4764242293 6269733.17815191,207666.2651719721
> 6269693.32784602,207500.0763041668 6269651.188471549,207094.13864904008
> 6269527.942605048,207010.21488493102 6269499.573248141,206915.03672030274
> 6269469.050436069,206405.47175119657 6269260.463879191,205872.1289388569
> 6269025.413802074,205509.60588513955 6268865.823577013,205338.81952236447
> 6268798.356409601,205229.83774087788 6268760.79952401,205129.21605314984
> 6268728.482084657,205004.1708691418 6268697.33470097,204937.22332737868
> 6268683.159881713,204672.08256420726 6268635.854137745,204370.6739109354
> 6268613.6256161155,204261.52515021258 6268613.47301777,204135.43356299106
> 6268617.254066456,203986.54374405506 6268624.867035082,203844.71158083534
> 6268640.4999231035,203624.3657807591 6268684.635011318,203495.53573406406
> 6268709.915720742,203397.38533903164 6268732.63620819,203350.37511806964
> 6268743.369116401,202970.9426337008 6268826.943839294,202600.93891020207
> 6268911.401098567,202196.83802667345 6268999.894763305,202016.15536116686
> 6269030.53457528,201871.68492601535 6269047.066894041,201731.35557592136
> 6269057.528901179,201616.9970630294 6269060.801460366,201488.60116234847
> 6269057.8171576345,201368.87705000027 6269051.84855534,201231.82049293566
> 6269038.114003561,201055.81324604238 6269011.509731532,200931.7922013496
> 6268991.348869861,200526.58925486208 6268901.057963869,200204.19687757565
> 6268843.136643355,199764.70752792383 6268786.250018328,199346.39114542087
> 6268756.679297957,198995.5343743386 6268745.810727753,198173.98540033516
> 6268752.711674767,197670.8101700005 6268765.411466662,197477.55953398338
> 6268779.162531202,197360.328978229 6268791.52324825,197084.12305767272
> 6268832.776636343,196819.97303796935 6268881.422998699,196631.9766819177
> 6268913.673198705))'
> ) as way ) as t ) as t
> result (screen from pgAdmin)
> ![image](https://user-
> images.githubusercontent.com/1227612/186465718-4fb611c1-aa63-408a-92dd-
> 3119f144aefb.png)
> Version: `POSTGIS="3.2.2 628da50" [EXTENSION] PGSQL="140"
> GEOS="3.9.0-CAPI-1.16.2" PROJ="7.2.1" GDAL="GDAL 3.2.2, released
> 2021/03/05" LIBXML="2.9.10" LIBJSON="0.15" LIBPROTOBUF="1.3.3"
> WAGYU="0.5.0 (Internal)" TOPOLOGY RASTER`
New description:
 I have a question.
 of variation.
 FROM (
 6269472.9675241215,194042.57400657536 6269505.525209331,193958.79495780432
 6269533.572399087,193858.273457618 6269561.687510971,193767.74844770491
 6269582.053220367,193573.44027652525 6269621.462109578,193479.14153587425
 6269645.72817361,193389.2065192624 6269674.369340893,193292.52554150842
 6269849.186005235,192970.65636582876 6269900.4158241125,192894.84779259854
 6272397.130705383,185908.72598108876 6272470.3262004275,184829.45012200074
 6274869.0125483805,179299.48743760868 6274917.065843037,178963.19125592217
 6275182.958891726,178872.84435719438 6275259.249852135,178787.77400233014
 6275335.965722783,178712.68900579007 6275410.527225275,178494.07978977027
 6275641.953757119,177877.44773441908 6276298.935552551,177659.651150682
 6276529.351169971,177237.7168847283 6276979.118426997,176836.78860668722
 6277406.437319403,176724.22233759708 6277523.229470048,176645.04078379582
 6277599.507615941,176614.50584747124 6277629.007448478,176501.08241830196
 6277727.538993572,176424.34989329817 6277788.915985597,176350.85676547643
 6277843.928209411,176274.5249906395 6277897.243390758,176156.33708726428
 6277973.049636971,176064.33152812364 6278026.925783878,175960.02516525035
 6278235.083765929,170292.12649981634 6278227.3433137005,170194.47704249248
 6278210.2498401515,169705.57297087752 6278210.131017717,169622.81806142177
 6278211.387140695,169526.35972264942 6278213.848463291,169378.70555006122
 6278219.6028685635,169239.1331725046 6278228.310869838,169075.88313925627
 6278241.890616841,168886.91830363468 6278260.9871729845,168734.08777472458
 6280090.722325979,163479.24007987903 6280199.5886100065,163379.94309409146
 6280273.819513355,163247.127809626 6280378.001954607,163115.57043540652
 6280484.698602745,163059.6880510283 6280531.968840754,162875.54334935802
 6280694.275525646,162783.88288063885 6280779.377839527,162689.60640388602
 6280869.388223054,162596.5767054301 6280961.284363624,162447.34179607264
 6281113.020460335,162357.3288558172 6281210.998327417,162269.20834690524
 6281309.588642108,162101.57232571964 6281505.567054671,162010.35713496362
 6281621.668706291,161854.3873964132 6281821.407357725,161723.431147444
 6281998.836028648,161601.6030967198 6282162.155893708,161215.4580470561
 6282692.4535129145,161104.21647990638 6282844.135795295,160829.9141226427
 6283218.198562569,160702.65368076783 6283385.584448484,160574.558342712
 6283548.625397618,160460.78982312127 6283687.600801415,160371.35574421793
 6283794.543099508,160231.61638742514 6283954.27963882,160087.1570842227
 6284113.3397397725,159955.12103619284 6284254.006129454,159817.01807591468
 6284395.35434521,159744.50455961193 6284466.955143437,159590.92819011354
 6284616.189126318,159504.75577229046 6284696.999112322,159389.42877982865
 6284802.459260868,159281.02585969414 6284898.169562886,159107.41198185296
 6285047.326225455,158927.04101092063 6285194.650745688,158757.7018015259
 6281295.324729303,162338.95000788724 6281195.4440528685,162430.53255296283
 6278433.367373186,173696.47690335807 6278430.8211112525,174099.07497376102
 6278368.6416330505,175050.34455038584 6278360.748284028,175121.71147593344
 6278348.424489337,175222.12165662897 6278327.290751028,175329.82326397148
 6278301.030669535,175465.9781331607 6278262.582798295,175584.2884879758
 6278220.960840882,175688.11617703867 6278181.596706854,175823.68105292672
 6278123.068570675,175954.45919071068 6278060.959254745,176051.79695346032
 6278008.423854744,176149.13471620996 6277951.679200016,176247.7081253074
 6277886.770436193,176332.1439590741 6277828.889349307,176413.15115252437
 6277768.157069202,176490.89668489437 6277706.525623646,176554.3265307484
 6277652.481784668,176627.05155408365 6277584.842605183,176657.0632888015
 6277557.413671906,176711.01984598898 6277504.507992098,176760.8241861699
 6277453.130223573,176820.9701070455 6277390.431777683,177286.2855785614
 6276892.20443966,177861.65149867552 6276284.154003537,178398.8570973457
 6275710.3070790805,178695.34542912449 6275395.866013061,178775.66244173184
 6275316.536399705,178858.2392400023 6275241.313948316,178944.2780744364
 6275168.569570697,179282.555743059 6274899.63970496,179341.2990383506
 6274851.1623121975,179428.87408175768 6274776.724518886,179508.23374674423
 6274703.390274527,179556.8135725264 6274653.3699657265,179603.24493213627
 6274025.0023307055,180385.19756326458 6274002.216716409,180442.14861475438
 6273980.992048297,180512.50253293573 6273958.885196452,180622.23015501068
 6273925.954068508,180758.819170214 6273887.695757958,181342.9348023045
 6273730.813046822,181445.46005332508 6273703.7698630225,182199.37130472253
 6273502.49257374,182963.31244224045 6273298.794114928,183938.78287616375
 6273037.642466021,184079.81353904973 6272997.267655166,184238.04306326332
 6272948.394035007,184438.81889685805 6272888.1548454845,185007.9731893859
 6272716.159139401,185901.1673876639 6272446.119879661,185976.12993276407
 6272423.898300745,186121.39073630024 6272380.829315267,186199.8821092586
 6272357.556209243,186287.8356389343 6272331.484299947,186334.95717938713
 6272317.506939917,186380.0304412093 6272304.157225641,186534.40831104142
 6272258.391783233,187140.94368857768 6272080.624735446,187160.71403014255
 6272073.754996126,187539.9238755298 6271955.324960422,187600.55960216493
 6271936.378344127,187674.38668845902 6271913.293043615,188332.00658032027
 6271715.4507022835,188782.3273164263 6271579.470701108,188845.1115092337
 6271560.0669725705,189141.16569499843 6271470.308346317,189362.03469668137
 6271405.008357309,189660.70489047974 6271327.564920277,189695.74826618144
 6271318.185594663,190457.64112506877 6271112.86068684,190816.96930940036
 6271015.305118234,190957.20960390175 6270978.976471972,191363.30310631558
 6270868.855156802,191382.17176000506 6270863.7502299575,191434.1802261037
 6270849.63961765,191820.4365952582 6270744.9131529685,191901.21001777778
 6270719.338045002,191985.0892540905 6270686.9791996395,192040.4595688111
 6270663.354607214,192160.21707700647 6270601.4866406545,192224.78238166656
 6269028.9067794895,201490.69396877536 6269036.316644114,201616.45159752454
 6269038.826164957,201729.85276279564 6269034.231029387,201869.69230713014
 6269026.32943679,202013.5616170314 6269008.321972242,202197.13858929859
 6268977.800933472,202565.27214535192 6268895.954225012,202962.90536646548
 6268805.5965146255,203348.71645765682 6268718.393507428,203397.96420038375
 6268706.863719617,203489.92523172806 6268685.499742586,203619.6903621458
 6268658.896579973,203844.1883792286 6268616.202833018,204131.44832522067
 6268588.548658428,204371.29730008382 6268588.718211642,204675.25516969484
 6268610.488872914,204941.39780828342 6268652.775660202,205011.76285841386
 6268673.444379371,205136.97502165815 6268706.69416403,205236.40559083468
 6268736.841200623,205346.28906019675 6268772.973701606,205514.38149129457
 6268842.237984302,205880.70053964798 6269000.77648296,206415.36805392808
 6269237.284144589,206920.04609738846 6269441.325643939,207099.98292230672
 6269503.846450623,207507.6237656426 6269626.668030797,207670.59550016397
 6269669.010772909,207843.78636394013 6269708.640515808,208195.21086442543
 6269775.453596626,208326.70144695044 6269795.412835121,208401.7530476433
 6269804.53610511,208587.40056243923 6269826.15727683,208844.6265098152
 6269851.678809498,209191.79860575218 6269865.550345944,209374.51841794027
 6269862.04006501,210445.4453152188 6269847.066274299,210891.858737198
 6269838.536482385,211903.04046376777 6269819.865934097,211997.6842948402
 6269818.136239613,212192.64925101554 6269814.931218413,212407.40681265394
 6269808.080277704,212479.0297730303 6269801.093680517,212650.52858054647
 6269780.625697236,212924.0071735783 6269723.664934162,213171.13644313932
 6269647.220428596,213310.74221654324 6269590.3114362415,213451.52797654943
 6266549.306755744,216459.60325676532 6266299.9747393485,216683.26637766714
 6265986.527581096,216817.5844752583 6265785.0440774225,217058.769284011
 6265410.989382424,217213.72601519522 6265167.233065622,217368.43784349976
 6264940.143649308,217465.0075017629 6264806.035119937,217572.3306228367
 6264677.623069013,217658.02436684936 6264585.649580556,217711.70262530987
 6264529.503367279,217716.7120023956 6264524.385318675,217819.73819112475
 6264423.8213760685,218037.39005952372 6264242.168710179,218235.13800296892
 6264110.545412234,218316.47915489157 6264061.960376094,218399.21180044912
 6264015.256642067,218491.45113052044 6263968.7056804495,218519.58156584387
 6263954.80992066,218626.33695751466 6263902.701024731,218868.96891964765
 6263798.060552794,219003.18682969714 6263742.902412033,219524.27336610042
 6263522.578458384,219917.03079351725 6263360.025015918,220398.06457713316
 6263157.553507509,220812.79647203258 6262984.230630194,221226.7046027001
 6262802.134449159,221473.62236522866 6262688.324208363,221777.62476263603
 6262540.71374249,221856.95103177536 6262498.677762082,221929.31983274
 6262464.012213491,222114.2103749986 6262367.962615812,222255.61952415327
 6262288.670419796,222381.59979188404 6262211.056278395,222434.3429666219
 6262170.733124265,222484.49239722424 6262128.885348189,222542.9351298907
 6262075.178181773,222597.90469444444 6262018.862263656,222674.04722614703
 6196315.784907852,207715.27914376836 6196180.6720451135,207378.07014225743
 6196062.170566912,206998.59313009222 6195938.5266493885,206917.69725613273
 6192794.6240622755,197522.10959419888 6192747.537881321,197285.61133600856
 6192673.195347736,197012.8340557687 6192588.2500511715,196679.29859745392
 6191898.6701241145,192768.21073987213 6191854.075693898,192551.63867053378
 6191805.583296708,192222.4001445636 6191732.811613842,191578.17198744477
 6191587.639761255,190985.30664337796 6191453.643633212,190757.43564572415
 6191397.979153161,190516.66271908736 6191332.637280303,190274.14207644516
 6191260.004051219,190008.6339589541 6191166.638582807,189832.66010790807
 6191103.045809532,189506.87248615248 6190971.846262171,189370.4170543381
 6190911.027078318,189254.22176984805 6190857.684643403,189119.83688056245
 6190793.237347289,188957.42174349504 6190710.242851276,188742.1298483009
 6190594.320718837,188531.26846884025 6190474.384973415,188113.51981574032
 6192996.7514260365,198540.39350428124 6193050.493779081,198873.33896929485
 6193177.994583501,199030.2215276698 6193242.980900124,199395.08229069386
 6193404.650589195,199538.8402811043 6193469.82350049,199773.4795037983
 6193575.297788921,199789.36479513452 6193581.331172849,199820.723495691
 6193595.36426899,199891.18873336315 6193625.817007487,199915.07789608737
 6193635.967944528,200004.9461210048 6193670.303074583,200064.95845849146
 6193695.092351473,200159.0122962627 6193730.92348808,200310.99679704275
 6193786.149447056,200422.96194088264 6193826.165802465,200463.87185374915
 6193839.611071189,200510.74849132219 6193855.42609571,200628.39092919254
 6193892.753703668,200721.8436417135 6193922.316747496,200893.4649006695
 6193972.56911555,200968.67234864942 6193992.670145828,201027.8497899551
 6194008.014860586,201083.55406314804 6194022.8553941585,201138.41230821097
 6197515.049699872,212032.62748300022 6197529.0388410585,212078.90299532298
 6268969.509403638,195991.07697757357 6268986.5333305355,195876.45129790375
 6269047.372106385,194732.28730763233 6269108.8726181835,194617.03823881404
 6269169.780100242,194446.2407440899 6269280.862776473,194310.3864375258
 6269374.922168917),(196631.9766819177 6268913.673198705,196220.71795513103
 6269802.8233715175,212483.09293444428 6269824.614116857,212408.41982002018
 6269831.159830317,212191.34681297326 6269838.383861936,211998.31881593776
 6269841.673681193,211873.9415488744 6269845.557026199,210892.30401516115
 6269862.04006501,210446.35813504332 6269870.315512252,209374.51841794027
 6269887.171673696,209190.60748720073 6269888.273938942,208845.5170657416
 6269873.89362822,208584.40606813686 6269851.678809498,208322.51583409662
 6269819.798102936,208119.68058992218 6269787.374869348,207838.4764242293
 6269733.17815191,207666.2651719721 6269693.32784602,207500.0763041668
 6269651.188471549,207094.13864904008 6269527.942605048,207010.21488493102
 6269499.573248141,206915.03672030274 6269469.050436069,206405.47175119657
 6269260.463879191,205872.1289388569 6269025.413802074,205509.60588513955
 6268865.823577013,205338.81952236447 6268798.356409601,205229.83774087788
 6268760.79952401,205129.21605314984 6268728.482084657,205004.1708691418
 6268697.33470097,204937.22332737868 6268683.159881713,204672.08256420726
 6268635.854137745,204370.6739109354 6268613.6256161155,204261.52515021258
 6268613.47301777,204135.43356299106 6268617.254066456,203986.54374405506
 6268624.867035082,203844.71158083534 6268640.4999231035,203624.3657807591
 6268684.635011318,203495.53573406406 6268709.915720742,203397.38533903164
 6268732.63620819,203350.37511806964 6268743.369116401,202970.9426337008
 6268826.943839294,202600.93891020207 6268911.401098567,202196.83802667345
 6268999.894763305,202016.15536116686 6269030.53457528,201871.68492601535
 6269047.066894041,201731.35557592136 6269057.528901179,201616.9970630294
 6269060.801460366,201488.60116234847 6269057.8171576345,201368.87705000027
 6269051.84855534,201231.82049293566 6269038.114003561,201055.81324604238
 6269011.509731532,200931.7922013496 6268991.348869861,200526.58925486208
 6268901.057963869,200204.19687757565 6268843.136643355,199764.70752792383
 6268786.250018328,199346.39114542087 6268756.679297957,198995.5343743386
 6268745.810727753,198173.98540033516 6268752.711674767,197670.8101700005
 6268765.411466662,197477.55953398338 6268779.162531202,197360.328978229
 6268791.52324825,197084.12305767272 6268832.776636343,196819.97303796935
 6268881.422998699,196631.9766819177 6268913.673198705))'
 3119f144aefb.png)
 (not sur if this should be here or on geos side, so I opened both
 https://github.com/libgeos/geos/issues/667)
Ticket URL: <https://trac.osgeo.org/postgis/ticket/5225#comment:1>
