[postgis-tickets] [PostGIS] #5296: woodie skip doc build is not working correctly
PostGIS trac at osgeo.org
Thu Dec 1 19:59:30 PST 2022
  Reporter:  robe       |      Owner:  robe
      Type:  defect     |     Status:  new
  Priority:  blocker    |  Milestone:  PostGIS 3.4.0
 Component:  buildbots  |    Version:  master
Resolution:             |   Keywords:
Comment (by robe):
 Okay I did another test changing a file in root of docs, and that does
 make it build as seen here:
 https://woodie.osgeo.org/postgis/postgis/build/11/6
 So it seems the wehn clause you have is not set to search subfolders.
 Will only trigger if changes happen in main doc folder.
Ticket URL: <https://trac.osgeo.org/postgis/ticket/5296#comment:1>
