[postgis-tickets] [SCM] PostGIS branch master updated. 3.3.0rc2-373-gc23debb38
Mon Dec 5 15:08:56 PST 2022
the project "PostGIS".
       via  c23debb38a4b031fe8041bd3c7e904dca935412c (commit)
      from  8cf36e0e99af15065ab0ba1a83bc0ad41ffb507f (commit)
revisions in full, below.
commit c23debb38a4b031fe8041bd3c7e904dca935412c
Author: Paul Ramsey <pramsey at cleverelephant.ca>
Date:   Mon Dec 5 15:07:32 2022 -0800
    Convert GeoJSON output to use stringbuffer instead of count-n-fill procedure. Much less code.
    Performance for large-amounts-of-small objects is about 10% faster. Performance for larger
    objects (natural earth admin for example) is 3%-5% slower.
diff --git a/liblwgeom/lwout_geojson.c b/liblwgeom/lwout_geojson.c
index 721839986..aa14748a1 100644
--- a/liblwgeom/lwout_geojson.c
+++ b/liblwgeom/lwout_geojson.c
@@ -25,763 +25,383 @@
 #include "liblwgeom_internal.h"
+#include "stringbuffer.h"
 #include <string.h>	/* strlen */
 #include <assert.h>
-static lwvarlena_t *asgeojson_point(const LWPOINT *point, const char *srs, GBOX *bbox, int precision);
-static lwvarlena_t *asgeojson_line(const LWLINE *line, const char *srs, GBOX *bbox, int precision);
-static lwvarlena_t *asgeojson_triangle(const LWTRIANGLE *tri, const char *srs, GBOX *bbox, int precision);
-static lwvarlena_t *asgeojson_poly(const LWPOLY *poly, const char *srs, GBOX *bbox, int precision);
-static lwvarlena_t *asgeojson_multipoint(const LWMPOINT *mpoint, const char *srs, GBOX *bbox, int precision);
-static lwvarlena_t *asgeojson_multiline(const LWMLINE *mline, const char *srs, GBOX *bbox, int precision);
-static lwvarlena_t *asgeojson_multipolygon(const LWMPOLY *mpoly, const char *srs, GBOX *bbox, int precision);
-static lwvarlena_t *asgeojson_collection(const LWCOLLECTION *col, const char *srs, GBOX *bbox, int precision);
-static size_t asgeojson_geom_size(const LWGEOM *geom, GBOX *bbox, int precision);
-static size_t asgeojson_geom_buf(const LWGEOM *geom, char *output, GBOX *bbox, int precision);
-static size_t pointArray_to_geojson(POINTARRAY *pa, char *buf, int precision);
-static size_t pointArray_geojson_size(POINTARRAY *pa, int precision);
+typedef struct geojson_opts {
+	const char *srs;
+	GBOX       *bbox;
+	int         precision;
+	int         hasz;
+	int         isCollectionElement;
+} geojson_opts;
- * Takes a GEOMETRY and returns a GeoJson representation
-lwvarlena_t *
-lwgeom_to_geojson(const LWGEOM *geom, const char *srs, int precision, int has_bbox)
-	int type = geom->type;
-	GBOX *bbox = NULL;
-	GBOX tmp = {0};
+enum {
+	geojson_tagged,
+	geojson_untagged
-	if (has_bbox)
-		/* Whether these are geography or geometry,
-		   the GeoJSON expects a cartesian bounding box */
-		lwgeom_calculate_gbox_cartesian(geom, &tmp);
-		bbox = &tmp;
+static void asgeojson_geometry(stringbuffer_t *sb, const LWGEOM *geom, const geojson_opts *opts);
-	switch (type)
-	case POINTTYPE:
-		return asgeojson_point((LWPOINT*)geom, srs, bbox, precision);
-	case LINETYPE:
-		return asgeojson_line((LWLINE*)geom, srs, bbox, precision);
-	case POLYGONTYPE:
-		return asgeojson_poly((LWPOLY*)geom, srs, bbox, precision);
-	case MULTIPOINTTYPE:
-		return asgeojson_multipoint((LWMPOINT*)geom, srs, bbox, precision);
-	case MULTILINETYPE:
-		return asgeojson_multiline((LWMLINE*)geom, srs, bbox, precision);
-	case MULTIPOLYGONTYPE:
-		return asgeojson_multipolygon((LWMPOLY*)geom, srs, bbox, precision);
-	case TRIANGLETYPE:
-		return asgeojson_triangle((LWTRIANGLE *)geom, srs, bbox, precision);
-	case TINTYPE:
-	case COLLECTIONTYPE:
-		return asgeojson_collection((LWCOLLECTION*)geom, srs, bbox, precision);
-	default:
-		lwerror("lwgeom_to_geojson: '%s' geometry type not supported",
-		        lwtype_name(type));
-	/* Never get here */
-	return NULL;
- * Handle SRS
-static size_t
-asgeojson_srs_size(const char *srs)
-	int size;
-	size = sizeof("'crs':{'type':'name',");
-	size += sizeof("'properties':{'name':''}},");
-	size += strlen(srs) * sizeof(char);
-	return size;
-static size_t
-asgeojson_srs_buf(char *output, const char *srs)
+static void
+coordinate_to_geojson(stringbuffer_t *sb, const POINTARRAY *pa, uint32_t i, const geojson_opts *opts)
-	char *ptr = output;
-	ptr += sprintf(ptr, "\"crs\":{\"type\":\"name\",");
-	ptr += sprintf(ptr, "\"properties\":{\"name\":\"%s\"}},", srs);
-	return (ptr-output);
+	if (!FLAGS_GET_Z(pa->flags))
+		const POINT2D *pt = getPoint2d_cp(pa, i);
+		stringbuffer_append_char(sb, '[');
+		stringbuffer_append_double(sb, pt->x, opts->precision);
+		stringbuffer_append_char(sb, ',');
+		stringbuffer_append_double(sb, pt->y, opts->precision);
+		stringbuffer_append_char(sb, ']');
+	else
+		const POINT3D *pt = getPoint3d_cp(pa, i);
+		stringbuffer_append_double(sb, pt->z, opts->precision);
- * Handle Bbox
-static size_t
-asgeojson_bbox_size(int hasz, int precision)
+static void
+pointArray_to_geojson(stringbuffer_t *sb, const POINTARRAY *pa, const geojson_opts *opts)
-	int size;
-	if (!hasz)
+	if (!pa || pa->npoints == 0)
-		size = sizeof("\"bbox\":[,,,],");
-		size += 2 * 2 * (OUT_MAX_BYTES_DOUBLE + precision);
+		stringbuffer_append_len(sb, "[]", 2);
+		return;
-	else
+	for (uint32_t i = 0; i < pa->npoints; i++)
-		size = sizeof("\"bbox\":[,,,,,],");
-		size += 2 * 3 * (OUT_MAX_BYTES_DOUBLE + precision);
+		if (i) stringbuffer_append_char(sb, ',');
+		coordinate_to_geojson(sb, pa, i, opts);
-	return size;
+	return;
-static size_t
-asgeojson_bbox_buf(char *output, GBOX *bbox, int hasz, int precision)
+static void
+asgeojson_srs(stringbuffer_t *sb, const geojson_opts *opts)
+	if (!opts->srs) return;
+	stringbuffer_append_len(sb, "\"crs\":{\"type\":\"name\",", 21);
+	stringbuffer_aprintf(sb, "\"properties\":{\"name\":\"%s\"}},", opts->srs);
+	return;
-	if (!hasz)
-		ptr += sprintf(ptr, "\"bbox\":[%.*f,%.*f,%.*f,%.*f],",
-		               precision, bbox->xmin, precision, bbox->ymin,
-		               precision, bbox->xmax, precision, bbox->ymax);
-	else
-		ptr += sprintf(ptr, "\"bbox\":[%.*f,%.*f,%.*f,%.*f,%.*f,%.*f],",
-		               precision, bbox->xmin, precision, bbox->ymin, precision, bbox->zmin,
-		               precision, bbox->xmax, precision, bbox->ymax, precision, bbox->zmax);
+static void
+asgeojson_bbox(stringbuffer_t *sb, const geojson_opts *opts)
+	if (!opts->bbox) return;
+	if (!opts->hasz)
+		stringbuffer_aprintf(sb, "\"bbox\":[%.*f,%.*f,%.*f,%.*f],",
+			opts->precision, opts->bbox->xmin,
+			opts->precision, opts->bbox->ymin,
+			opts->precision, opts->bbox->xmax,
+			opts->precision, opts->bbox->ymax);
+	else
+		stringbuffer_aprintf(sb, "\"bbox\":[%.*f,%.*f,%.*f,%.*f,%.*f,%.*f],",
+			opts->precision, opts->bbox->zmin,
+			opts->precision, opts->bbox->ymax,
+			opts->precision, opts->bbox->zmax);
+	return;
  * Point Geometry
-static size_t
-asgeojson_point_size(const LWPOINT *point, const char *srs, GBOX *bbox, int precision)
+static void
+asgeojson_point_coords(stringbuffer_t *sb, const LWPOINT *point, const geojson_opts *opts, int tagged)
-	int size;
-	size = pointArray_geojson_size(point->point, precision);
-	size += sizeof("{'type':'Point',");
-	size += sizeof("'coordinates':}");
-	if ( lwpoint_is_empty(point) )
-		size += 2; /* [] */
-	if (srs) size += asgeojson_srs_size(srs);
-	if (bbox) size += asgeojson_bbox_size(FLAGS_GET_Z(point->flags), precision);
-	return size;
+	if (tagged == geojson_tagged) stringbuffer_append_len(sb, "\"coordinates\":", 14);
+	if (lwgeom_is_empty((LWGEOM*)point))
+	else
+		coordinate_to_geojson(sb, point->point, 0, opts);
+	return;
-static size_t
-asgeojson_point_buf(const LWPOINT *point, const char *srs, char *output, GBOX *bbox, int precision)
+static void
+asgeojson_line_coords(stringbuffer_t *sb, const LWLINE *line, const geojson_opts *opts, int tagged)
-	ptr += sprintf(ptr, "{\"type\":\"Point\",");
-	if (srs) ptr += asgeojson_srs_buf(ptr, srs);
-	if (bbox) ptr += asgeojson_bbox_buf(ptr, bbox, FLAGS_GET_Z(point->flags), precision);
-	ptr += sprintf(ptr, "\"coordinates\":");
-		ptr += sprintf(ptr, "[]");
-	ptr += pointArray_to_geojson(point->point, ptr, precision);
-	ptr += sprintf(ptr, "}");
+	if (lwgeom_is_empty((LWGEOM*)line))
+	else
+		pointArray_to_geojson(sb, line->points, opts);
+	return;
-asgeojson_point(const LWPOINT *point, const char *srs, GBOX *bbox, int precision)
+static void
+asgeojson_poly_coords(stringbuffer_t *sb, const LWPOLY *poly, const geojson_opts *opts, int tagged)
-	uint32_t size = asgeojson_point_size(point, srs, bbox, precision);
-	lwvarlena_t *output = (lwvarlena_t *)lwalloc(size + LWVARHDRSZ);
-	size = asgeojson_point_buf(point, srs, output->data, bbox, precision);
-	LWSIZE_SET(output->size, size + LWVARHDRSZ);
-	return output;
+	uint32_t i;
+	if (lwgeom_is_empty((LWGEOM*)poly))
+	else
+		for (i = 0; i < poly->nrings; i++)
+			pointArray_to_geojson(sb, poly->rings[i], opts);
+	return;
- * Triangle Geometry
+ * Point Geometry
-static size_t
-asgeojson_triangle_size(const LWTRIANGLE *tri, const char *srs, GBOX *bbox, int precision)
+static void
+asgeojson_point(stringbuffer_t *sb, const LWPOINT *point, const geojson_opts *opts)
-	int size;
-	size = sizeof("{'type':'Polygon',");
-	if (srs)
-		size += asgeojson_srs_size(srs);
-	if (bbox)
-		size += asgeojson_bbox_size(FLAGS_GET_Z(tri->flags), precision);
-	size += sizeof("'coordinates':[[]]}");
-	size += pointArray_geojson_size(tri->points, precision);
-	return size;
-static size_t
-asgeojson_triangle_buf(const LWTRIANGLE *tri, const char *srs, char *output, GBOX *bbox, int precision)
-	ptr += sprintf(ptr, "{\"type\":\"Polygon\",");
-	if (srs)
-		ptr += asgeojson_srs_buf(ptr, srs);
-	if (bbox)
-		ptr += asgeojson_bbox_buf(ptr, bbox, FLAGS_GET_Z(tri->flags), precision);
-	ptr += sprintf(ptr, "\"coordinates\":[[");
-	ptr += pointArray_to_geojson(tri->points, ptr, precision);
-	ptr += sprintf(ptr, "]]}");
-	return (ptr - output);
+	stringbuffer_append_len(sb, "{\"type\":\"Point\",", 16);
+	asgeojson_srs(sb, opts);
+	asgeojson_bbox(sb, opts);
+	asgeojson_point_coords(sb, point, opts, geojson_tagged);
+	stringbuffer_append_char(sb, '}');
+	return;
-asgeojson_triangle(const LWTRIANGLE *tri, const char *srs, GBOX *bbox, int precision)
-	uint32_t size = asgeojson_triangle_size(tri, srs, bbox, precision);
-	size = asgeojson_triangle_buf(tri, srs, output->data, bbox, precision);
-	return output;
+ * Triangle Geometry
+static void
+asgeojson_triangle(stringbuffer_t *sb, const LWTRIANGLE *tri, const geojson_opts *opts)
+	stringbuffer_append_len(sb, "{\"type\":\"Polygon\",", 18);
+	stringbuffer_append_len(sb, "\"coordinates\":[", 15);
+	if (lwtriangle_is_empty(tri))
+	else
+		pointArray_to_geojson(sb, tri->points, opts);
+	stringbuffer_append_len(sb, "]}", 2);
+	return;
  * Line Geometry
-static size_t
-asgeojson_line_size(const LWLINE *line, const char *srs, GBOX *bbox, int precision)
-	int size;
-	size = sizeof("{'type':'LineString',");
-	if (bbox) size += asgeojson_bbox_size(FLAGS_GET_Z(line->flags), precision);
-	size += sizeof("'coordinates':[]}");
-	size += pointArray_geojson_size(line->points, precision);
-	return size;
-static size_t
-asgeojson_line_buf(const LWLINE *line, const char *srs, char *output, GBOX *bbox, int precision)
-	char *ptr=output;
-	ptr += sprintf(ptr, "{\"type\":\"LineString\",");
-	if (bbox) ptr += asgeojson_bbox_buf(ptr, bbox, FLAGS_GET_Z(line->flags), precision);
-	ptr += sprintf(ptr, "\"coordinates\":[");
-	ptr += pointArray_to_geojson(line->points, ptr, precision);
-	ptr += sprintf(ptr, "]}");
-asgeojson_line(const LWLINE *line, const char *srs, GBOX *bbox, int precision)
+static void
+asgeojson_line(stringbuffer_t *sb, const LWLINE *line, const geojson_opts *opts)
-	uint32_t size = asgeojson_line_size(line, srs, bbox, precision);
-	size = asgeojson_line_buf(line, srs, output->data, bbox, precision);
-	return output;
+	const char tmpl[] = "{\"type\":\"LineString\",";
+	stringbuffer_append_len(sb, tmpl, sizeof(tmpl)-1);
+	asgeojson_line_coords(sb, line, opts, geojson_tagged);
+	return;
  * Polygon Geometry
-static size_t
-asgeojson_poly_size(const LWPOLY *poly, const char *srs, GBOX *bbox, int precision)
+static void
+asgeojson_poly(stringbuffer_t *sb, const LWPOLY *poly, const geojson_opts *opts)
-	size_t size;
-	uint32_t i;
-	size = sizeof("{\"type\":\"Polygon\",");
-	if (bbox) size += asgeojson_bbox_size(FLAGS_GET_Z(poly->flags), precision);
-	size += sizeof("\"coordinates\":[");
-	for (i=0; i<poly->nrings; i++)
-		size += pointArray_geojson_size(poly->rings[i], precision);
-		size += sizeof("[]");
-	size += sizeof(",") * i;
-	size += sizeof("]}");
-	return size;
-static size_t
-asgeojson_poly_buf(const LWPOLY *poly, const char *srs, char *output, GBOX *bbox, int precision)
-	uint32_t i;
-	char *ptr=output;
-	if (bbox) ptr += asgeojson_bbox_buf(ptr, bbox, FLAGS_GET_Z(poly->flags), precision);
-		if (i) ptr += sprintf(ptr, ",");
-		ptr += sprintf(ptr, "[");
-		ptr += pointArray_to_geojson(poly->rings[i], ptr, precision);
-		ptr += sprintf(ptr, "]");
-asgeojson_poly(const LWPOLY *poly, const char *srs, GBOX *bbox, int precision)
-	uint32_t size = asgeojson_poly_size(poly, srs, bbox, precision);
-	size = asgeojson_poly_buf(poly, srs, output->data, bbox, precision);
-	return output;
+	asgeojson_poly_coords(sb, poly, opts, geojson_tagged);
+	return;
  * Multipoint Geometry
-static size_t
-asgeojson_multipoint_size(const LWMPOINT *mpoint, const char *srs, GBOX *bbox, int precision)
+static void
+asgeojson_multipoint(stringbuffer_t *sb, const LWMPOINT *mpoint, const geojson_opts *opts)
-	LWPOINT * point;
-	int size;
 	uint32_t i, ngeoms = mpoint->ngeoms;
-	size = sizeof("{'type':'MultiPoint',");
-	if (bbox) size += asgeojson_bbox_size(FLAGS_GET_Z(mpoint->flags), precision);
+	stringbuffer_append_len(sb, "{\"type\":\"MultiPoint\",", 21);
 	if (lwgeom_is_empty((LWGEOM*)mpoint))
 		ngeoms = 0;
-	for (i=0; i<ngeoms; i++)
-		point = mpoint->geoms[i];
-		size += pointArray_geojson_size(point->point, precision);
-	return size;
-static size_t
-asgeojson_multipoint_buf(const LWMPOINT *mpoint, const char *srs, char *output, GBOX *bbox, int precision)
-	LWPOINT *point;
-	uint32_t i, ngeoms = mpoint->ngeoms;
-	char *ptr=output;
-	ptr += sprintf(ptr, "{\"type\":\"MultiPoint\",");
-	if (bbox) ptr += asgeojson_bbox_buf(ptr, bbox, FLAGS_GET_Z(mpoint->flags), precision);
-	if (lwgeom_is_empty((LWGEOM*)mpoint))
-		ngeoms = 0;
+	for (i=0; i < ngeoms; i++)
+		asgeojson_point_coords(sb, mpoint->geoms[i], opts, geojson_untagged);
-asgeojson_multipoint(const LWMPOINT *mpoint, const char *srs, GBOX *bbox, int precision)
-	uint32_t size = asgeojson_multipoint_size(mpoint, srs, bbox, precision);
-	size = asgeojson_multipoint_buf(mpoint, srs, output->data, bbox, precision);
-	return output;
+	return;
- * Multiline Geometry
+ * Multipoint Geometry
-static size_t
-asgeojson_multiline_size(const LWMLINE *mline, const char *srs, GBOX *bbox, int precision)
+static void
+asgeojson_multiline(stringbuffer_t *sb, const LWMLINE *mline, const geojson_opts *opts)
-	LWLINE * line;
-	int size;
 	uint32_t i, ngeoms = mline->ngeoms;
-	size = sizeof("{'type':'MultiLineString',");
-	if (bbox) size += asgeojson_bbox_size(FLAGS_GET_Z(mline->flags), precision);
+	stringbuffer_append_len(sb, "{\"type\":\"MultiLineString\",", 26);
 	if (lwgeom_is_empty((LWGEOM*)mline))
 		ngeoms = 0;
-	for (i=0 ; i<ngeoms; i++)
-		line = mline->geoms[i];
-	return size;
-static size_t
-asgeojson_multiline_buf(const LWMLINE *mline, const char *srs, char *output, GBOX *bbox, int precision)
-	LWLINE *line;
-	uint32_t i, ngeoms = mline->ngeoms;
-	char *ptr=output;
-	ptr += sprintf(ptr, "{\"type\":\"MultiLineString\",");
-	if (bbox) ptr += asgeojson_bbox_buf(ptr, bbox, FLAGS_GET_Z(mline->flags), precision);
-	if (lwgeom_is_empty((LWGEOM*)mline))
-		ngeoms = 0;
-asgeojson_multiline(const LWMLINE *mline, const char *srs, GBOX *bbox, int precision)
-	uint32_t size = asgeojson_multiline_size(mline, srs, bbox, precision);
-	size = asgeojson_multiline_buf(mline, srs, output->data, bbox, precision);
-	return output;
- * MultiPolygon Geometry
-static size_t
-asgeojson_multipolygon_size(const LWMPOLY *mpoly, const char *srs, GBOX *bbox, int precision)
-	LWPOLY *poly;
-	int size;
-	uint32_t i, j, ngeoms = mpoly->ngeoms;
-	size = sizeof("{'type':'MultiPolygon',");
-	if (bbox) size += asgeojson_bbox_size(FLAGS_GET_Z(mpoly->flags), precision);
-	if (lwgeom_is_empty((LWGEOM*)mpoly))
-		ngeoms = 0;
-		poly = mpoly->geoms[i];
-		for (j=0 ; j <poly->nrings ; j++)
-			size += pointArray_geojson_size(poly->rings[j], precision);
+		asgeojson_line_coords(sb, mline->geoms[i], opts, geojson_untagged);
-	return size;
+	return;
-static size_t
-asgeojson_multipolygon_buf(const LWMPOLY *mpoly, const char *srs, char *output, GBOX *bbox, int precision)
+static void
+asgeojson_multipolygon(stringbuffer_t *sb, const LWMPOLY *mpoly, const geojson_opts *opts)
-	LWPOLY *poly;
-	char *ptr=output;
+	uint32_t i, ngeoms = mpoly->ngeoms;
-	ptr += sprintf(ptr, "{\"type\":\"MultiPolygon\",");
-	if (bbox) ptr += asgeojson_bbox_buf(ptr, bbox, FLAGS_GET_Z(mpoly->flags), precision);
+	stringbuffer_append_len(sb, "{\"type\":\"MultiPolygon\",", 23);
 		ngeoms = 0;
-		for (j=0 ; j < poly->nrings ; j++)
-			if (j) ptr += sprintf(ptr, ",");
-			ptr += pointArray_to_geojson(poly->rings[j], ptr, precision);
+		asgeojson_poly_coords(sb, mpoly->geoms[i], opts, geojson_untagged);
-asgeojson_multipolygon(const LWMPOLY *mpoly, const char *srs, GBOX *bbox, int precision)
-	uint32_t size = asgeojson_multipolygon_size(mpoly, srs, bbox, precision);
-	size = asgeojson_multipolygon_buf(mpoly, srs, output->data, bbox, precision);
-	return output;
+	return;
  * Collection Geometry
-static size_t
-asgeojson_collection_size(const LWCOLLECTION *col, const char *srs, GBOX *bbox, int precision)
+static void
+asgeojson_collection(stringbuffer_t *sb, const LWCOLLECTION *col, const geojson_opts *opts)
 	uint32_t i, ngeoms = col->ngeoms;
-	size_t size;
-	LWGEOM *subgeom;
-	size = sizeof("{'type':'GeometryCollection',");
-	if (bbox) size += asgeojson_bbox_size(FLAGS_GET_Z(col->flags), precision);
-	size += sizeof("'geometries':");
+	/* subgeometries don't get boxes or srs */
+	geojson_opts subopts = *opts;
+	subopts.bbox = NULL;
+	subopts.srs = NULL;
+	subopts.isCollectionElement = LW_TRUE;
-	if (lwgeom_is_empty((LWGEOM*)col))
-		ngeoms = 0;
-		subgeom = col->geoms[i];
-		size += asgeojson_geom_size(subgeom, NULL, precision);
-	return size;
-static size_t
-asgeojson_collection_buf(const LWCOLLECTION *col, const char *srs, char *output, GBOX *bbox, int precision)
-	uint32_t i, ngeoms = col->ngeoms;
-	char *ptr=output;
-	LWGEOM *subgeom;
-	ptr += sprintf(ptr, "{\"type\":\"GeometryCollection\",");
-	if (col->ngeoms && bbox) ptr += asgeojson_bbox_buf(ptr, bbox, FLAGS_GET_Z(col->flags), precision);
-	ptr += sprintf(ptr, "\"geometries\":[");
+	stringbuffer_append_len(sb, "{\"type\":\"GeometryCollection\",", 29);
+	if (col->ngeoms) asgeojson_bbox(sb, opts);
+	stringbuffer_append_len(sb, "\"geometries\":[", 14);
 		ngeoms = 0;
-		ptr += asgeojson_geom_buf(subgeom, ptr, NULL, precision);
+		asgeojson_geometry(sb, col->geoms[i], &subopts);
-asgeojson_collection(const LWCOLLECTION *col, const char *srs, GBOX *bbox, int precision)
-	uint32_t size = asgeojson_collection_size(col, srs, bbox, precision);
-	size = asgeojson_collection_buf(col, srs, output->data, bbox, precision);
-	return output;
+	return;
-static size_t
-asgeojson_geom_size(const LWGEOM *geom, GBOX *bbox, int precision)
+static void
+asgeojson_geometry(stringbuffer_t *sb, const LWGEOM *geom, const geojson_opts *opts)
 	switch (geom->type)
 	case POINTTYPE:
-		return asgeojson_point_size((LWPOINT *)geom, NULL, bbox, precision);
-	case LINETYPE:
-		return asgeojson_line_size((LWLINE *)geom, NULL, bbox, precision);
-		return asgeojson_triangle_size((LWTRIANGLE *)geom, NULL, bbox, precision);
-	case POLYGONTYPE:
-		return asgeojson_poly_size((LWPOLY *)geom, NULL, bbox, precision);
-		return asgeojson_multipoint_size((LWMPOINT *)geom, NULL, bbox, precision);
-		return asgeojson_multiline_size((LWMLINE *)geom, NULL, bbox, precision);
-		return asgeojson_multipolygon_size((LWMPOLY *)geom, NULL, bbox, precision);
-	default:
-		lwerror("GeoJson: geometry not supported.");
-		return 0;
-static size_t
-asgeojson_geom_buf(const LWGEOM *geom, char *output, GBOX *bbox, int precision)
-	char *ptr=output;
-	switch (type)
-	case POINTTYPE:
-		ptr += asgeojson_point_buf((LWPOINT*)geom, NULL, ptr, bbox, precision);
+		asgeojson_point(sb, (LWPOINT*)geom, opts);
 		break;
 	case LINETYPE:
-		ptr += asgeojson_line_buf((LWLINE*)geom, NULL, ptr, bbox, precision);
+		asgeojson_line(sb, (LWLINE*)geom, opts);
 		break;
 	case POLYGONTYPE:
-		ptr += asgeojson_poly_buf((LWPOLY*)geom, NULL, ptr, bbox, precision);
-		break;
-		ptr += asgeojson_triangle_buf((LWTRIANGLE *)geom, NULL, ptr, bbox, precision);
+		asgeojson_poly(sb, (LWPOLY*)geom, opts);
 		break;
-		ptr += asgeojson_multipoint_buf((LWMPOINT*)geom, NULL, ptr, bbox, precision);
+		asgeojson_multipoint(sb, (LWMPOINT*)geom, opts);
 		break;
 	case MULTILINETYPE:
-		ptr += asgeojson_multiline_buf((LWMLINE*)geom, NULL, ptr, bbox, precision);
+		asgeojson_multiline(sb, (LWMLINE*)geom, opts);
 		break;
-		ptr += asgeojson_multipolygon_buf((LWMPOLY*)geom, NULL, ptr, bbox, precision);
+		asgeojson_multipolygon(sb, (LWMPOLY*)geom, opts);
+		break;
+	case TRIANGLETYPE:
+		asgeojson_triangle(sb, (LWTRIANGLE *)geom, opts);
+		break;
+	case TINTYPE:
+	case COLLECTIONTYPE:
+		if (opts->isCollectionElement) {
+			lwerror("GeoJson: geometry not supported.");
+		asgeojson_collection(sb, (LWCOLLECTION*)geom, opts);
 		break;
 	default:
-		if (bbox) lwfree(bbox);
+		lwerror("lwgeom_to_geojson: '%s' geometry type not supported", lwtype_name(geom->type));
-static size_t
-pointArray_to_geojson(POINTARRAY *pa, char *output, int precision)
+ * Takes a GEOMETRY and returns a GeoJson representation
+lwvarlena_t *
+lwgeom_to_geojson(const LWGEOM *geom, const char *srs, int precision, int has_bbox)
+	GBOX static_bbox = {0};
+	geojson_opts opts;
+	stringbuffer_t sb;
-	if (!FLAGS_GET_Z(pa->flags))
-		for (uint32_t i = 0; i < pa->npoints; i++)
-			if (i)
-				*ptr = ',';
-				ptr++;
-			const POINT2D *pt = getPoint2d_cp(pa, i);
-			*ptr = '[';
-			ptr++;
-			ptr += lwprint_double(pt->x, precision, ptr);
-			*ptr = ',';
-			ptr++;
-			ptr += lwprint_double(pt->y, precision, ptr);
-			*ptr = ']';
-			ptr++;
-	else
+	memset(&opts, 0, sizeof(opts));
+	opts.precision = precision;
+	opts.hasz = FLAGS_GET_Z(geom->flags);
+	opts.srs = srs;
+	if (has_bbox)
-			if (i)
-				*ptr = ',';
-				ptr++;
-			const POINT3D *pt = getPoint3d_cp(pa, i);
-			*ptr = '[';
-			ptr++;
-			*ptr = ',';
-			ptr++;
-			*ptr = ',';
-			ptr++;
-			ptr += lwprint_double(pt->z, precision, ptr);
-			*ptr = ']';
-			ptr++;
+		/* Whether these are geography or geometry,
+		   the GeoJSON expects a cartesian bounding box */
+		lwgeom_calculate_gbox_cartesian(geom, &static_bbox);
+		opts.bbox = &static_bbox;
-	*ptr = '\0';
- * Returns maximum size of rendered pointarray in bytes.
-static size_t
-pointArray_geojson_size(POINTARRAY *pa, int precision)
-	if (FLAGS_NDIMS(pa->flags) == 2)
-		return (OUT_MAX_BYTES_DOUBLE + precision + sizeof(",")) * 2 * pa->npoints + sizeof(",[]");
-	return (OUT_MAX_BYTES_DOUBLE + precision + sizeof(",,")) * 3 * pa->npoints + sizeof(",[]");
+	/* To avoid taking a copy of the output, we make */
+	/* space for the VARLENA header before starting to */
+	/* serialize the geom */
+	stringbuffer_init_varlena(&sb);
+	/* Now serialize the geometry */
+	asgeojson_geometry(&sb, geom, &opts);
+	/* Leave the initially allocated buffer in place */
+	/* and write the varlena_t metadata into the slot we */
+	/* left at the start */
+	return stringbuffer_getvarlena(&sb);
diff --git a/liblwgeom/stringbuffer.c b/liblwgeom/stringbuffer.c
index d71d5f1ec..0c7101997 100644
--- a/liblwgeom/stringbuffer.c
+++ b/liblwgeom/stringbuffer.c
@@ -56,6 +56,15 @@ stringbuffer_init(stringbuffer_t *s)
 	stringbuffer_init_with_size(s, STRINGBUFFER_STARTSIZE);
+void
+stringbuffer_init_varlena(stringbuffer_t *s)
+	stringbuffer_init_with_size(s, STRINGBUFFER_STARTSIZE + LWVARHDRSZ);
+	/* Zero out LWVARHDRSZ bytes at the front of the buffer */
+	stringbuffer_append_len(s, "\0\0\0\0\0\0\0\0", LWVARHDRSZ);
 * Allocate a new stringbuffer_t. Use stringbuffer_destroy to free.
@@ -130,6 +139,14 @@ stringbuffer_getstringcopy(stringbuffer_t *s)
 	return str;
+lwvarlena_t *
+stringbuffer_getvarlena(stringbuffer_t *s)
+	lwvarlena_t *output = (lwvarlena_t *)(s->str_start);
+	LWSIZE_SET(output->size, (s->str_end - s->str_start));
+	return output;
 lwvarlena_t *
 stringbuffer_getvarlenacopy(stringbuffer_t *s)
diff --git a/liblwgeom/stringbuffer.h b/liblwgeom/stringbuffer.h
index a0324f6a5..aa95ef4ca 100644
--- a/liblwgeom/stringbuffer.h
+++ b/liblwgeom/stringbuffer.h
@@ -47,6 +47,7 @@ stringbuffer_t;
 extern stringbuffer_t *stringbuffer_create_with_size(size_t size);
 extern stringbuffer_t *stringbuffer_create(void);
 extern void stringbuffer_init(stringbuffer_t *s);
+extern void stringbuffer_init_varlena(stringbuffer_t *s);
 extern void stringbuffer_release(stringbuffer_t *s);
 extern void stringbuffer_destroy(stringbuffer_t *sb);
 extern void stringbuffer_clear(stringbuffer_t *sb);
@@ -56,6 +57,7 @@ extern int stringbuffer_aprintf(stringbuffer_t *sb, const char *fmt, ...);
 extern const char *stringbuffer_getstring(stringbuffer_t *sb);
 extern char *stringbuffer_getstringcopy(stringbuffer_t *sb);
 extern lwvarlena_t *stringbuffer_getvarlenacopy(stringbuffer_t *s);
+extern lwvarlena_t * stringbuffer_getvarlena(stringbuffer_t *s);
 extern int stringbuffer_getlength(stringbuffer_t *sb);
 extern char stringbuffer_lastchar(stringbuffer_t *s);
 extern int stringbuffer_trim_trailing_white(stringbuffer_t *s);
@@ -112,4 +114,14 @@ stringbuffer_append_double(stringbuffer_t *s, double d, int precision)
 	stringbuffer_makeroom(s, OUT_MAX_BYTES_DOUBLE);
 	s->str_end += lwprint_double(d, precision, s->str_end);
+inline static void
+stringbuffer_append_char(stringbuffer_t *s, char c)
+	stringbuffer_makeroom(s, 1);
+	*(s->str_end) = c;
+	s->str_end++;
 #endif /* _STRINGBUFFER_H */
Summary of changes:
 liblwgeom/lwout_geojson.c | 868 +++++++++++++---------------------------------
 liblwgeom/stringbuffer.c  |  17 +
 liblwgeom/stringbuffer.h  |  12 +
 3 files changed, 273 insertions(+), 624 deletions(-)
hooks/post-receive
