[postgis-tickets] [PostGIS] #5290: RHEL 8 Postgis 3.3.2 requires gdal35-libs >= 3.5.2
PostGIS trac at osgeo.org
Fri Dec 9 15:51:48 PST 2022
  Reporter:  marc3932  |      Owner:  pramsey
      Type:  defect    |     Status:  closed
  Priority:  medium    |  Milestone:  PostGIS 3.3.3
 Component:  postgis   |    Version:  3.3.x
Resolution:  invalid   |   Keywords:
Comment (by marc3932):
 **WORKAROUND:**
 https://www.postgresql.org/download/linux/redhat/
 -- Install the repository RPM:
 # sudo dnf install -y
 https://download.postgresql.org/pub/repos/yum/reporpms/**EL-8-x86_64
 **/pgdg-redhat-repo-latest.noarch.rpm
 # ls -la /etc/yum.repos.d
 # yum install gdal35-libs*
 Updating Subscription Management repositories.
 Red Hat Enterprise Linux 8 for x86_64 - BaseOS (RPMs)
 14 kB/s | 2.4 kB     00:00
 Red Hat Enterprise Linux 8 for x86_64 - AppStream (RPMs)
 15 kB/s | 2.8 kB     00:00
 EPEL8 x86_64
 14 kB/s | 2.7 kB     00:00
 Error:
  Problem: cannot install the best candidate for the job
   - nothing provides **libqhull_r.so.7()(64bit)** needed by
 **gdal35-libs-3.5.3-1.rhel8.x86_64**
 (try to add '--skip-broken' to skip uninstallable packages or '--nobest'
 to use not only best candidate packages)
 [root at lnx8pg12 ~]#
 **--NOTE: Many packages, including libqhull, live in the "CodeReady Linux
 Builder" repo**
 # subscription-manager repos --enable=codeready-builder-for-
 rhel-8-x86_64-rpms
 # subscription-manager repos --list-enable
 # yum install gdal35-libs*    **<== works fine this time!!!**
 --These work fine now!!!
 # yum install postgis33_12
 # yum install postgis33_13
Ticket URL: <https://trac.osgeo.org/postgis/ticket/5290#comment:7>
