[postgis-tickets] [PostGIS] #5302: PostGIS upgrade from 3.2 to 3.3 fails with deprecated function not part of PostGIS error
PostGIS trac at osgeo.org
Sun Dec 11 09:04:56 PST 2022
PostGIS error
 Reporter:  robe                   |      Owner:  strk
     Type:  defect                 |     Status:  new
 Priority:  medium                 |  Milestone:  PostGIS 3.3.3
Component:  build/upgrade/install  |    Version:  3.3.x
 Keywords:                         |
 strk suggests this may be an issue, or maybe not.
 So I am documenting as best I can remember
 This system was running PostGIS 3.0.1 and PostgreSQL 11 on a Windows 2012
 (maybe 2016, can't recall, but probably not important) server.
 I tried to upgrade it first to PostGIS 3.3.2 as noted in #5301
 and got a ERROR:  row is too big: size 8824, maximum size 8160 which I
 think is a separate issue (has to do most likely with how we try to update
 spatial_ref_sys in 3.3)
 So since I couldn't upgrade to 3.3, I decided to do the next best thing to
 upgrade to 3.2.3.
 Then ran the usual
 SELECT postgis_extensions_upgrade();
 That was all successful. So like a monkey I decided, let me try again to
 upgrade to 3.3.2.
 The example NOTICE I received was
 NOTICE:  Updating extension postgis from 3.2.3 to 3.3.2
 WARNING:  Deprecated function
 st_intersection_deprecated_by_postgis_301(geometry,geometry) left behind:
 cannot drop function
 st_intersection_deprecated_by_postgis_301(geometry,geometry) because other
 objects depend on it
 DETAIL:  function pgis_geom_intersection(geometry) depends on function
 view assessing.vwparcel_electdist depends on function
 materialized view assessing.vwparceltime_for_pdr depends on function
 materialized view sf_staging.mvw_dbamp_parcels depends on function
 HINT:  Replace the view changing all occurrences of
 st_intersection_deprecated_by_postgis_301(geometry,geometry) in its
 definition with st_intersection and upgrade again
 st_intersection_deprecated_by_postgis_301(geometry,geometry) could not be
 rewritten as a wrapper: function
 st_intersection_deprecated_by_postgis_301(geometry,geometry) is not a
 member of extension "postgis" (55000)
 CONTEXT:  SQL statement "ALTER EXTENSION postgis UPDATE TO "3.3.2";"
 PL/pgSQL function postgis_extensions_upgrade() line 82 at EXECUTE
 SQL state: 54000
Ticket URL: <https://trac.osgeo.org/postgis/ticket/5302>
