[postgis-tickets] [PostGIS] #5302: PostGIS upgrade from 3.2 to 3.3 fails with deprecated function not part of PostGIS error
PostGIS trac at osgeo.org
Sun Dec 11 09:08:17 PST 2022
PostGIS error
  Reporter:  robe                   |      Owner:  strk
      Type:  defect                 |     Status:  new
  Priority:  medium                 |  Milestone:  PostGIS 3.3.3
 Component:  build/upgrade/install  |    Version:  3.3.x
Resolution:                         |   Keywords:
Comment (by robe):
 Oh one last note I should add.  I think the server when I upgraded it to
 3.2.3 was running a PostgreSQL 11 without the CVEE patch.  After failing
 again with 3.3.2 upgrade, I had decided to upgrade the server to
 PostgreSQL 11 to latest version (to rule out the row size thing had
 anything to do with that).  So the above attempt was after I had upgraded
 the server to PostgreSQL 11.18 (I think before it was running something
 like 11.13)
Ticket URL: <https://trac.osgeo.org/postgis/ticket/5302#comment:1>
