[postgis-tickets] [PostGIS] #5302: PostGIS upgrade from 3.2 to 3.3 fails with deprecated function not part of PostGIS error
PostGIS trac at osgeo.org
Thu Dec 15 01:27:25 PST 2022
PostGIS error
  Reporter:  robe                   |      Owner:  strk
      Type:  defect                 |     Status:  new
  Priority:  medium                 |  Milestone:  PostGIS 3.3.3
 Component:  build/upgrade/install  |    Version:  3.3.x
Resolution:                         |   Keywords:
Comment (by strk):
 Can you check if `SELECT proname FROM pg_proc WHERE proname like
 'deprecated_by_postgis%'` yelds any results prior to upgrade ?
 It feels like you did not cleanup after upgrade to 3.1
Ticket URL: <https://trac.osgeo.org/postgis/ticket/5302#comment:2>
