[postgis-tickets] [PostGIS] #5302: PostGIS upgrade from 3.2 to 3.3 fails with deprecated function not part of PostGIS error
PostGIS trac at osgeo.org
Fri Dec 23 20:23:34 PST 2022
PostGIS error
  Reporter:  robe                   |      Owner:  strk
      Type:  defect                 |     Status:  closed
  Priority:  medium                 |  Milestone:  PostGIS 3.3.3
 Component:  build/upgrade/install  |    Version:  3.3.x
Resolution:  wontfix                |   Keywords:
Changes (by robe):
 * status:  new => closed
 * resolution:   => wontfix
Comment:
 Yes it did. But wuery needs to be below because the deprecated part is at
 the end of the name.
 SELECT proname FROM pg_proc WHERE proname like '%deprecated_by_postgis%'
 I wonder if we should add this to the upgrade instructions.
 Note there was a pgis_geom_intersection which relied on
 st_intersection_deprecated_by_postgis_301.  On trying to drop
 st_intersection_deprecated_by_postgis_301, that failed.
 So had to drop both
 DROP FUNCTION pgis_geom_intersection(geometry);
 DROP FUNCTION st_intersection_deprecated_by_postgis_301(geometry,geometry)
 Only thing that puzzles me is that helper function pgis_geom_intersection,
 why it was there in the first place.  I couldn't find it listed in any
 versions of our source code.
 It's possible maybe I created it and overwrote the ST_Intersection to use
 it for some reason a very long time ago.
Ticket URL: <https://trac.osgeo.org/postgis/ticket/5302#comment:3>
