[postgis-tickets] [SCM] PostGIS branch master updated. 3.3.0rc2-393-g4dfc3f42e
Tue Dec 13 17:43:13 PST 2022
the project "PostGIS".
       via  4dfc3f42e1885bdb4d2d50a32e75a2479e991705 (commit)
      from  f0e94e2845427dbfb17773cc1f17c7ca777642b9 (commit)
revisions in full, below.
commit 4dfc3f42e1885bdb4d2d50a32e75a2479e991705
Author: Paul Ramsey <pramsey at cleverelephant.ca>
Date:   Tue Dec 13 17:43:08 2022 -0800
    Fix compile warnings/errors against pg16devel
diff --git a/postgis/flatgeobuf.c b/postgis/flatgeobuf.c
index 545442f31..e98d6a65b 100644
--- a/postgis/flatgeobuf.c
+++ b/postgis/flatgeobuf.c
@@ -425,6 +425,9 @@ static void decode_properties(struct flatgeobuf_decode_ctx *ctx, Datum *values,
 			fsec_t fsec;
 			int tzp;
 			TimestampTz dttz;
+#if POSTGIS_PGSQL_VERSION >= 160
+			DateTimeErrorExtra extra;
+#endif
 			if (offset + sizeof(len) > size)
 				elog(ERROR, "flatgeobuf: decode_properties: Invalid size for string value");
 			memcpy(&len, data + offset, sizeof(uint32_t));
@@ -432,7 +435,12 @@ static void decode_properties(struct flatgeobuf_decode_ctx *ctx, Datum *values,
 			buf = palloc0(len + 1);
 			memcpy(buf, (const char *) data + offset, len);
 			ParseDateTime((const char *) buf, workbuf, sizeof(workbuf), field, ftype, MAXDATEFIELDS, &nf);
+			DecodeDateTime(field, ftype, nf, &dtype, tm, &fsec, &tzp, &extra);
+#else
 			DecodeDateTime(field, ftype, nf, &dtype, tm, &fsec, &tzp);
+#endif
 			tm2timestamp(tm, fsec, &tzp, &dttz);
 			values[ci] = TimestampTzGetDatum(dttz);
 			offset += len;
diff --git a/postgis/gserialized_gist_2d.c b/postgis/gserialized_gist_2d.c
index 0d6a0e938..576c82838 100644
--- a/postgis/gserialized_gist_2d.c
+++ b/postgis/gserialized_gist_2d.c
@@ -1453,11 +1453,11 @@ fallbackSplit(GistEntryVector *entryvec, GIST_SPLITVEC *v)
 	if (v->spl_ldatum_exists)
 		adjustBox(unionL, (BOX2DF *) DatumGetPointer(v->spl_ldatum));
-	v->spl_ldatum = BoxPGetDatum(unionL);
+	v->spl_ldatum = PointerGetDatum(unionL);
 	if (v->spl_rdatum_exists)
 		adjustBox(unionR, (BOX2DF *) DatumGetPointer(v->spl_rdatum));
-	v->spl_rdatum = BoxPGetDatum(unionR);
+	v->spl_rdatum = PointerGetDatum(unionR);
 	v->spl_ldatum_exists = v->spl_rdatum_exists = false;
diff --git a/postgis/gserialized_gist_nd.c b/postgis/gserialized_gist_nd.c
index 58c86e3d5..29b6472de 100644
--- a/postgis/gserialized_gist_nd.c
+++ b/postgis/gserialized_gist_nd.c
@@ -1508,7 +1508,7 @@ gserialized_gist_picksplit_constructsplit(GIST_SPLITVEC *v,
 		else
-			float p1, p2;
+			float p1 = 0.0, p2 = 0.0;
 			GISTENTRY oldUnion, addon;
 			gistentryinit(oldUnion,
diff --git a/postgis/gserialized_spgist_2d.c b/postgis/gserialized_spgist_2d.c
index 8ab682be3..098224a58 100644
--- a/postgis/gserialized_spgist_2d.c
+++ b/postgis/gserialized_spgist_2d.c
@@ -372,7 +372,7 @@ PGDLLEXPORT Datum gserialized_spgist_picksplit_2d(PG_FUNCTION_ARGS)
 	/* Fill the output */
 	out->hasPrefix = true;
-	out->prefixDatum = BoxPGetDatum(centroid);
+	out->prefixDatum = PointerGetDatum(centroid);
 	out->nNodes = 16;
 	out->nodeLabels = NULL; /* We don't need node labels. */
@@ -564,7 +564,7 @@ PGDLLEXPORT Datum gserialized_spgist_leaf_consistent_2d(PG_FUNCTION_ARGS)
 	int i;
 	/* Quick sanity check on entry key. */
-	if (DatumGetPointer(key) == NULL)
+	if (key == NULL)
 		POSTGIS_DEBUG(4, "[SPGIST] null index entry, returning false");
 		PG_RETURN_BOOL(false); /* NULL entry! */
diff --git a/postgis/lwgeom_box3d.c b/postgis/lwgeom_box3d.c
index 8aec40375..96288e624 100644
--- a/postgis/lwgeom_box3d.c
+++ b/postgis/lwgeom_box3d.c
@@ -464,7 +464,7 @@ PG_FUNCTION_INFO_V1(BOX3D_combine);
 Datum BOX3D_combine(PG_FUNCTION_ARGS)
 	BOX3D *box = (BOX3D *)PG_GETARG_POINTER(0);
-	GSERIALIZED *geom = PG_ARGISNULL(1) ? NULL : (GSERIALIZED *)PG_DETOAST_DATUM(PG_GETARG_POINTER(1));
+	GSERIALIZED *geom = PG_ARGISNULL(1) ? NULL : (GSERIALIZED *)PG_DETOAST_DATUM(PG_GETARG_DATUM(1));
 	LWGEOM *lwgeom = NULL;
 	BOX3D *result = NULL;
 	GBOX gbox;
diff --git a/postgis/lwgeom_geos.c b/postgis/lwgeom_geos.c
index e481008d3..d94043d53 100644
--- a/postgis/lwgeom_geos.c
+++ b/postgis/lwgeom_geos.c
@@ -2477,8 +2477,7 @@ Datum relate_pattern(PG_FUNCTION_ARGS)
 		HANDLE_GEOS_ERROR("Second argument geometry could not be converted to GEOS");
-	patt =  DatumGetCString(DirectFunctionCall1(textout,
-	                        PointerGetDatum(PG_GETARG_DATUM(2))));
+	patt =  DatumGetCString(DirectFunctionCall1(textout, PG_GETARG_DATUM(2)));
 	** Need to make sure 't' and 'f' are upper-case before handing to GEOS
diff --git a/postgis/lwgeom_triggers.c b/postgis/lwgeom_triggers.c
index 9df48c9af..4293637c4 100644
--- a/postgis/lwgeom_triggers.c
+++ b/postgis/lwgeom_triggers.c
@@ -110,8 +110,7 @@ Datum cache_bbox(PG_FUNCTION_ARGS)
 	if ( ! isnull )
-		out = PointerGetDatum(DirectFunctionCall1(LWGEOM_addBBOX, in));
+		out = DirectFunctionCall1(LWGEOM_addBBOX, in);
 		rettuple = SPI_modifytuple(trigdata->tg_relation, rettuple,
 		                           1, &attno, &out, NULL);
diff --git a/raster/rt_pg/rtpg_mapalgebra.c b/raster/rt_pg/rtpg_mapalgebra.c
index 8f278d5f5..b7010be6c 100644
--- a/raster/rt_pg/rtpg_mapalgebra.c
+++ b/raster/rt_pg/rtpg_mapalgebra.c
@@ -5904,7 +5904,7 @@ Datum RASTER_mapAlgebraFctNgb(PG_FUNCTION_ARGS)
     memcpy((void *)VARDATA(txtCallbackParam), (void *)VARDATA(txtNodataMode), VARSIZE(txtNodataMode) - VARHDRSZ);
     /* pass the nodata mode into the user function */
-    cbdata->args[1].value = CStringGetDatum(txtCallbackParam);
+    cbdata->args[1].value = PointerGetDatum(txtCallbackParam);
     strFromText = text_to_cstring(txtNodataMode);
     strFromText = rtpg_strtoupper(strFromText);
Summary of changes:
 postgis/flatgeobuf.c            | 8 ++++++++
 postgis/gserialized_gist_2d.c   | 4 ++--
 postgis/gserialized_gist_nd.c   | 2 +-
 postgis/gserialized_spgist_2d.c | 4 ++--
 postgis/lwgeom_box3d.c          | 2 +-
 postgis/lwgeom_geos.c           | 3 +--
 postgis/lwgeom_triggers.c       | 3 +--
 raster/rt_pg/rtpg_mapalgebra.c  | 2 +-
 8 files changed, 17 insertions(+), 11 deletions(-)
hooks/post-receive
