[postgis-tickets] [PostGIS] #2914: [raster] ST_Rescale: Could not create GDAL transformation object for output dataset creation
PostGIS trac at osgeo.org
Tue Dec 20 06:34:09 PST 2022
dataset creation
  Reporter:  strk    |      Owner:  Bborie Park
      Type:  defect  |     Status:  new
  Priority:  medium  |  Milestone:  PostGIS Fund Me
 Component:  raster  |    Version:  2.1.x
Resolution:          |   Keywords:
Comment (by arthurbazin):
 Hi, is there any workaround ?
 Because none of the ST_Rescale, ST_Resize and ST_Resample functions work
 on my server...
 POSTGIS="3.2.1 3.2.1" [EXTENSION] PGSQL="130" GEOS="3.10.2-CAPI-1.16.0"
 PROJ="7.2.1" GDAL="GDAL 3.4.2, released 2022/03/08" LIBXML="2.9.9"
 LIBJSON="0.12" LIBPROTOBUF="1.2.1" WAGYU="0.5.0 (Internal)" RASTER
 Constraints are good but nothing can be done...
 If you have a workaround, it would be a pleasure to have the information.
 Note that I have a standalone version of GDAL on the same machine. If you
 know some troubles that can be linked, I can try to change some
 parameters.
 Thank you really much.
Ticket URL: <https://trac.osgeo.org/postgis/ticket/2914#comment:12>
