[postgis-tickets] [SCM] PostGIS branch master updated. 3.3.0rc2-422-gee06f4120
Tue Dec 27 01:30:49 PST 2022
the project "PostGIS".
       via  ee06f41209c87366494b454f33179f56788cabc5 (commit)
       via  4006eaf167f18def6dcf4e29ea7e6c590eaf19d4 (commit)
      from  732064a157813018763ce97a1ad68409c420a1e7 (commit)
revisions in full, below.
commit ee06f41209c87366494b454f33179f56788cabc5
Author: Teramoto Ikuhiro <yellow at affrc.go.jp>
Date:   Tue Dec 27 02:18:35 2022 +0000
    Translated using Weblate (Japanese)
    Currently translated at 100.0% (637 of 637 strings)
    Translation: postgis/extras_topology.xml
    Translate-URL: https://weblate.osgeo.org/projects/postgis/extras_topologyxml/ja/
diff --git a/doc/po/ja/extras_topology.xml.po b/doc/po/ja/extras_topology.xml.po
index f446dd495..ce086bce7 100644
--- a/doc/po/ja/extras_topology.xml.po
+++ b/doc/po/ja/extras_topology.xml.po
@@ -9,7 +9,7 @@ msgstr ""
 "Project-Id-Version: PostGIS\n"
 "Report-Msgid-Bugs-To: https://bugs.kde.org\n"
 "POT-Creation-Date: 2022-12-20 01:55+0000\n"
-"PO-Revision-Date: 2022-12-01 10:30+0000\n"
+"PO-Revision-Date: 2022-12-27 09:30+0000\n"
 "Last-Translator: Teramoto Ikuhiro <yellow at affrc.go.jp>\n"
 "Language-Team: Japanese <https://weblate.osgeo.org/projects/postgis/"
 "extras_topologyxml/ja/>\n"
@@ -796,6 +796,8 @@ msgid ""
 "Valid <varname>feature_type</varname>s are: POINT, MULTIPOINT, LINE, "
 "MULTILINE, POLYGON, MULTIPOLYGON, COLLECTION"
 msgstr ""
+"妥当な<varname>feature_type</varname>: POINT, MULTIPOINT, LINE, MULTILINE, "
+"POLYGON, MULTIPOLYGON, COLLECTION"
 #. Tag: para
 #: extras_topology.xml:289 extras_topology.xml:383 extras_topology.xml:474
commit 4006eaf167f18def6dcf4e29ea7e6c590eaf19d4
Date:   Tue Dec 27 07:57:14 2022 +0000
    Currently translated at 100.0% (304 of 304 strings)
    Translation: postgis/reference_relationship.xml
    Translate-URL: https://weblate.osgeo.org/projects/postgis/reference_relationshipxml/ja/
diff --git a/doc/po/ja/reference_relationship.xml.po b/doc/po/ja/reference_relationship.xml.po
index 82a8ab0b1..1ebf17fe1 100644
--- a/doc/po/ja/reference_relationship.xml.po
+++ b/doc/po/ja/reference_relationship.xml.po
@@ -11,7 +11,7 @@ msgstr ""
 "Project-Id-Version: PACKAGE VERSION\n"
 "POT-Creation-Date: 2022-11-27 05:42+0000\n"
 "reference_relationshipxml/ja/>\n"
@@ -2435,16 +2435,16 @@ msgstr ""
 #. Tag: para
 #: reference_relationship.xml:1224
-#, fuzzy, no-c-format
+#, no-c-format
 msgid ""
 "<code>1</code>: <emphasis role=\"bold\">OGC-Mod2</emphasis> - line endpoints "
 "are in the Boundary if they occur an odd number of times. This is the rule "
 "defined by the OGC SFS standard, and is the default for <function>ST_Relate</"
 "function>."
 msgstr ""
-"<code>1</code>: <emphasis role=\"bold\">OGC-Mod2</emphasis> - 線の端点が奇数"
-"番目なら境界上にあるとみなします。これはOGC SFS標準で定義された規則で、"
-"<function>ST_Relate</function>のデフォルトです。"
+"<code>1</code>: <emphasis role=\"bold\">OGC-Mod2</emphasis> - "
+"線の端点が奇数回出現する場合に境界内にあるとします。これはOGC "
+"SFS標準で定義された規則で、<function>ST_Relate</function>のデフォルトです。"
 #. Tag: para
 #: reference_relationship.xml:1227
@@ -2458,29 +2458,29 @@ msgstr ""
 #. Tag: para
 #: reference_relationship.xml:1229
+#, no-c-format
 msgid ""
 "<code>3</code>: <emphasis role=\"bold\">MultivalentEndpoint</emphasis> - "
 "endpoints are in the Boundary if they occur more than once. In other words, "
 "the boundary is all the \"attached\" or \"inner\" endpoints (but not the "
 "\"unattached/outer\" ones)."
 msgstr ""
-"<code>3</code>: <emphasis role=\"bold\">MultivalentEndpoint</emphasis> - 線の"
-"端点が境界線上にあるのが2回目以降の場合には、境界にあるとします。言い換える"
-"と、境界は「取り付けられた」または「内部の」端点 (「取り付けられてない」「外"
-"部の」端点ではない)です。"
+"<code>3</code>: <emphasis role=\"bold\">MultivalentEndpoint</emphasis> - 端点"
+"が2回以上出現する場合に境界内にあるとします。言い換えると、境界は全ての「接続"
+"された」または「内部の」端点です "
+"(「接続していない」や「外部の」端点ではない)。"
 #. Tag: para
 #: reference_relationship.xml:1232
+#, no-c-format
 msgid ""
 "<code>4</code>: <emphasis role=\"bold\">MonovalentEndpoint</emphasis> - "
 "endpoints are in the Boundary if they occur only once. In other words, the "
 "boundary is all the \"unattached\" or \"outer\" endpoints."
 msgstr ""
-"<code>4</code>: <emphasis role=\"bold\">MonovalentEndpoint</emphasis> - 線の"
-"端点が境界線上にあるのが1回目の場合に限って、境界にあるとします。言い換えると"
-"「属していない」または「外部」の端点です。"
+"<code>4</code>: <emphasis role=\"bold\">MonovalentEndpoint</emphasis> - 端点"
+"が1回だけ出現する場合に限って、境界内にあるとします。言い換えると境界は全ての"
+"「接続していない」または「外部の」端点です。"
 #. Tag: para
 #: reference_relationship.xml:1237
Summary of changes:
 doc/po/ja/extras_topology.xml.po        |  4 +++-
 doc/po/ja/reference_relationship.xml.po | 28 ++++++++++++++--------------
 2 files changed, 17 insertions(+), 15 deletions(-)
hooks/post-receive
