[postgis-tickets] [PostGIS] #5308: PG16 build failure error: too few arguments to function ‘stringToQualifiedNameList’
PostGIS trac at osgeo.org
Fri Dec 30 16:19:40 PST 2022
 Reporter:  robe                |      Owner:  pramsey
     Type:  defect              |     Status:  new
 Priority:  blocker             |  Milestone:  PostGIS 3.3.3
Component:  postgis             |    Version:  3.3.x
 Keywords:  PostgreSQL 16 pg16  |
 21:42:28 ---- Making all in libpgcommon
 21:42:28 make[1]: Entering directory
 '/var/lib/jenkins/workspace/postgis/branches/3.4/libpgcommon'
 21:42:28 gcc -I./../liblwgeom -I../liblwgeom
 -I/var/lib/jenkins/workspace/geos/rel-3.12w64/include
 -I/usr/include/libxml2 -I/usr/include -I/usr/include/json-c  -DNDEBUG
 -std=gnu99 -g -O2 -fno-math-errno -fno-signed-zeros -Wall
 -I/var/lib/jenkins/workspace/pg/rel/pg16w64/include/postgresql/server
 -fPIC -DPIC  -c -o gserialized_gist.o gserialized_gist.c
 21:42:29 gcc -I./../liblwgeom -I../liblwgeom
 -fPIC -DPIC  -c -o lwgeom_transform.o lwgeom_transform.c
 -fPIC -DPIC  -c -o lwgeom_cache.o lwgeom_cache.c
 -fPIC -DPIC  -c -o lwgeom_pg.o lwgeom_pg.c
 21:42:30 lwgeom_pg.c: In function ‘postgis_get_full_version_schema’:
 21:42:30 lwgeom_pg.c:104:16: error: too few arguments to function
 21:42:30   104 |  List* names = stringToQualifiedNameList(proname);
 21:42:30       |                ^~~~~~~~~~~~~~~~~~~~~~~~~
 21:42:30 In file included from lwgeom_pg.c:38:
 21:42:30
 /var/lib/jenkins/workspace/pg/rel/pg16w64/include/postgresql/server/utils/regproc.h:28:14:
 note: declared here
 21:42:30    28 | extern List *stringToQualifiedNameList(const char
 *string, Node *escontext);
 21:42:30 make[1]: *** [Makefile:69: lwgeom_pg.o] Error 1
 21:42:30 make[1]: Leaving directory
 21:42:30 make: *** [GNUmakefile:25: all] Error 1
 21:42:30 Build step 'Execute shell' marked build as failure
 21:42:30 Triggering a new build of PostgreSQL stop
 21:42:30 Finished: FAILURE
 this failure started showing on debbie in last two runs on Dec 30th.  Last
 successful run against PG16 was 12/27.
Ticket URL: <https://trac.osgeo.org/postgis/ticket/5308>
