[postgis-tickets] [PostGIS] #5308: PG16 build failure error: too few arguments to function ‘stringToQualifiedNameList’
PostGIS trac at osgeo.org
Fri Dec 30 16:27:34 PST 2022
  Reporter:  robe     |      Owner:  pramsey
      Type:  defect   |     Status:  new
  Priority:  blocker  |  Milestone:  PostGIS 3.3.3
 Component:  postgis  |    Version:  3.3.x
Resolution:           |   Keywords:  PostgreSQL 16 pg16
Old description:
> 21:42:28 ---- Making all in libpgcommon
> 21:42:28 make[1]: Entering directory
> '/var/lib/jenkins/workspace/postgis/branches/3.4/libpgcommon'
> 21:42:28 gcc -I./../liblwgeom -I../liblwgeom
> -I/var/lib/jenkins/workspace/geos/rel-3.12w64/include
> -I/usr/include/libxml2 -I/usr/include -I/usr/include/json-c  -DNDEBUG
> -std=gnu99 -g -O2 -fno-math-errno -fno-signed-zeros -Wall
> -I/var/lib/jenkins/workspace/pg/rel/pg16w64/include/postgresql/server
> -fPIC -DPIC  -c -o gserialized_gist.o gserialized_gist.c
> 21:42:29 gcc -I./../liblwgeom -I../liblwgeom
> -fPIC -DPIC  -c -o lwgeom_transform.o lwgeom_transform.c
> -fPIC -DPIC  -c -o lwgeom_cache.o lwgeom_cache.c
> -fPIC -DPIC  -c -o lwgeom_pg.o lwgeom_pg.c
> 21:42:30 lwgeom_pg.c: In function ‘postgis_get_full_version_schema’:
> 21:42:30 lwgeom_pg.c:104:16: error: too few arguments to function
> 21:42:30   104 |  List* names = stringToQualifiedNameList(proname);
> 21:42:30       |                ^~~~~~~~~~~~~~~~~~~~~~~~~
> 21:42:30 In file included from lwgeom_pg.c:38:
> 21:42:30
> /var/lib/jenkins/workspace/pg/rel/pg16w64/include/postgresql/server/utils/regproc.h:28:14:
> note: declared here
> 21:42:30    28 | extern List *stringToQualifiedNameList(const char
> *string, Node *escontext);
> 21:42:30 make[1]: *** [Makefile:69: lwgeom_pg.o] Error 1
> 21:42:30 make[1]: Leaving directory
> 21:42:30 make: *** [GNUmakefile:25: all] Error 1
> 21:42:30 Build step 'Execute shell' marked build as failure
> 21:42:30 Triggering a new build of PostgreSQL stop
> 21:42:30 Finished: FAILURE
> this failure started showing on debbie in last two runs on Dec 30th.
> Last successful run against PG16 was 12/27.
New description:
 21:42:30
 note: declared here
 this failure started showing on debbie in last two runs on Dec 30th.  Last
Comment (by robe):
 smoking gun here -
 https://git.postgresql.org/gitweb/?p=postgresql.git;a=commitdiff;h=858e776c84f48841e7e16fba7b690b76e54f3675#patch10
 Commit: Convert the reg* input functions to report (most) errors softly.
 This is not really complete, but it catches most cases of practical
 interest.  The main omissions are:
 * regtype, regprocedure, and regoperator parse type names by
 calling the main grammar, so any grammar-detected syntax error
 will still be a hard error.  Also, if one includes a type
 modifier in such a type specification, errors detected by the
 typmodin function will be hard errors.
 * Lookup errors are handled just by passing missing_ok = true
 to the relevant catalog lookup function.  Because we've used
 quite a restrictive definition of "missing_ok", this means that
 edge cases such as "the named schema exists, but you lack
 USAGE permission on it" are still hard errors.
 It would make sense to me to replace most/all missing_ok
 parameters with an escontext parameter and then allow these
 additional lookup failure cases to be trapped too.  But that's
 a job for some other day.
 Discussion: https://postgr.es/m/3342239.1671988406@sss.pgh.pa.us
Ticket URL: <https://trac.osgeo.org/postgis/ticket/5308#comment:1>
