[postgis-tickets] [SCM] PostGIS branch spatial-ref-sys-view updated. 3.2.0-459-g17f9bfb6b
Tue Feb 1 17:34:52 PST 2022
the project "PostGIS".
The branch, spatial-ref-sys-view has been updated
       via  17f9bfb6bdfba2905597d3dc21ec978442e43de9 (commit)
      from  7afbc96406cde4e7a4198f21cad5bfaf8144e0ac (commit)
revisions in full, below.
commit 17f9bfb6bdfba2905597d3dc21ec978442e43de9
Author: Sandro Santilli <strk at kbt.io>
Date:   Wed Feb 2 02:31:15 2022 +0100
    Enhance spatial_ref_sys view trigger
     - Raise an exception if an attempt is made to insert records with SRID
       already known (system or user)
     - Raise an exception if an attempt is made to delete records which
       only exist as system ones (no user override)
     - Raise notices about overrides addition/removal
     - Test all these cases
diff --git a/postgis/postgis.sql.in b/postgis/postgis.sql.in
index 2388d287d..feac5fd24 100644
--- a/postgis/postgis.sql.in
+++ b/postgis/postgis.sql.in
@@ -2088,18 +2088,48 @@ CREATE OR REPLACE FUNCTION spatial_ref_sys_trigger()
 RETURNS trigger AS $BODY$
 BEGIN
 	IF ( TG_OP = 'INSERT' ) THEN
-		INSERT INTO spatial_ref_sys_user VALUES (NEW.*);
-		RETURN NEW;
+		IF EXISTS ( SELECT 1 FROM spatial_ref_sys_postgis WHERE srid = NEW.srid )
+		THEN
+			RAISE unique_violation
+			USING MESSAGE = format('Duplicate system SRID value (%s) already exists.', NEW.srid);
+		ELSE
+			BEGIN
+				INSERT INTO spatial_ref_sys_user VALUES (NEW.*);
+				RETURN NEW;
+			EXCEPTION
+			WHEN unique_violation THEN
+				USING MESSAGE = format('Duplicate user override for SRID value (%s) already exists.', NEW.srid);
+			END;
+		END IF;
 	ELSIF ( TG_OP = 'DELETE' ) THEN
 		DELETE FROM spatial_ref_sys_user WHERE srid = OLD.srid;
 		IF NOT FOUND THEN
+			IF EXISTS ( SELECT 1 FROM spatial_ref_sys_postgis WHERE srid = OLD.srid )
+			THEN
+				RAISE EXCEPTION 'System SRID (%) cannot be deleted', OLD.srid;
+			END IF;
 			RETURN NULL;
 		ELSE
+			RAISE NOTICE 'User override for SRID value % deleted', OLD.srid;
 			RETURN OLD;
 		END IF;
 	ELSIF ( TG_OP = 'UPDATE' ) THEN
-		RETURN NULL;
+		BEGIN
+			RAISE NOTICE 'User override for SRID value % added', OLD.srid;
+		EXCEPTION
+			UPDATE spatial_ref_sys_user
+			SET
+				auth_name = NEW.auth_name,
+				auth_srid = NEW.auth_srid,
+				srtext = NEW.srtext,
+				proj4text = NEW.proj4text
+			WHERE srid = NEW.srid;
+			RAISE NOTICE 'SRID override % updated', OLD.srid;
+		END;
+		RETURN NEW;
 	ELSE
 		RAISE EXCEPTION 'Unsupported trigger operation %', TG_OP;
 	END IF;
diff --git a/regress/core/spatial_ref_sys.sql b/regress/core/spatial_ref_sys.sql
index b2ac0fc62..15b17d953 100644
--- a/regress/core/spatial_ref_sys.sql
+++ b/regress/core/spatial_ref_sys.sql
@@ -1,23 +1,44 @@
-BEGIN;
 -- https://trac.osgeo.org/postgis/ticket/5024
 SELECT '#5024', 'spatial_ref_sys entries' AS table_name, count(*) FROM spatial_ref_sys;
 INSERT INTO spatial_ref_sys(srid,auth_name,auth_srid,srtext,proj4text)
- SELECT srid,'overridden',0,srtext,proj4text
- FROM spatial_ref_sys WHERE srid = 4326;
-SELECT 'inserted_overridden_srid', srid, auth_name
- WHERE srid = 4326;
+ SELECT srid,'inserted_duplicate',0,srtext,proj4text
+ FROM spatial_ref_sys WHERE srid = 4326
+ RETURNING 'insert-duplicate-return', srid, auth_name;
-DELETE FROM spatial_ref_sys WHERE srid = 4326;
-SELECT 'deleted_overridden_srid', srid, auth_name
+UPDATE spatial_ref_sys
+	SET auth_name = 'updated'
+	WHERE srid = 4326
+	RETURNING 'update-return', srid, auth_name;
-UPDATE spatial_ref_sys SET auth_name = 'overridden' WHERE srid = 4326;
-SELECT 'updated_overridden_srid', srid, auth_name
+DELETE FROM spatial_ref_sys WHERE srid = 4326
+RETURNING 'delete-return', srid, auth_name;
+SELECT 'select-after-delete', srid, auth_name
  WHERE srid = 4326;
-ROLLBACK;
+RETURNING 'delete-again-return', srid, auth_name;
+-- Insert, update and delete a custom SRID
+INSERT INTO spatial_ref_sys(srid,auth_name,auth_srid,srtext,proj4text)
+ SELECT 901000,'inserted_custom',0,srtext,proj4text
+ RETURNING 'insert-unallocated-return', srid, auth_name;
+ RETURNING 'insert-unallocated-duplicate-return', srid, auth_name;
+	SET auth_name = 'updated_custom'
+	WHERE srid = 901000
+	RETURNING 'update-unallocated-return', srid, auth_name;
+DELETE FROM spatial_ref_sys WHERE srid = 901000
+RETURNING 'delete-custom-return', srid, auth_name;
+SELECT 'select-after-delete-custom', srid, auth_name
+ WHERE srid = 901000;
diff --git a/regress/core/spatial_ref_sys_expected b/regress/core/spatial_ref_sys_expected
index 531df8493..472b603d2 100644
--- a/regress/core/spatial_ref_sys_expected
+++ b/regress/core/spatial_ref_sys_expected
@@ -1,4 +1,14 @@
 #5024|spatial_ref_sys entries|8500
-inserted_overridden_srid|4326|overridden
-deleted_overridden_srid|4326|EPSG
-updated_overridden_srid|4326|overridden
+ERROR:  Duplicate system SRID value (4326) already exists.
+NOTICE:  User override for SRID value 4326 added
+update-return|4326|updated
+NOTICE:  User override for SRID value 4326 deleted
+delete-return|4326|updated
+select-after-delete|4326|EPSG
+ERROR:  System SRID (4326) cannot be deleted
+insert-unallocated-return|901000|inserted_custom
+ERROR:  Duplicate user override for SRID value (901000) already exists.
+NOTICE:  SRID override 901000 updated
+update-unallocated-return|901000|updated_custom
+NOTICE:  User override for SRID value 901000 deleted
+delete-custom-return|901000|updated_custom
Summary of changes:
 postgis/postgis.sql.in                | 38 ++++++++++++++++++++++++---
 regress/core/spatial_ref_sys.sql      | 49 +++++++++++++++++++++++++----------
 regress/core/spatial_ref_sys_expected | 16 +++++++++---
 3 files changed, 82 insertions(+), 21 deletions(-)
hooks/post-receive
